andz
Electrical Component Help
Sun Apr 15, 2007 3:37 pm
I am trying to find a supplier of flush mounted electrical and network sockets. My company uses an exhibition stand structure made by Octanorm and every time we have a show it is a major pain to run power and networking. I am looking for sockets that can be permanently mounted in the upright pillars to save time when we build the stand.
So, if anyone can point me at a supplier of such components I will be grateful. It doesn't matter which country's standard they are as long as they can handle 220VAC 15A and have an earth line.
jafa39
RE: Electrical Component Help
Sun Apr 15, 2007 5:52 pm
Have you considered recessed ones, with a flap to cover them when not in use? Should be easy enough to find.
We, the undersigned, do hereby consent.....
andz
Sun Apr 15, 2007 6:08 pm
The problem is the size, the Octanorm columns are round, 120mm diameter, so I need something pretty small, about 30mm across maximum.
jafa39
Sun Apr 15, 2007 6:12 pm
In NZ we have extension cords with round, rubber covered single socket outlets, they have ridges and such that you could easily cut a hole and mount one almost flush, then run the cable down the inside and out wherever the fancy takes you.
andz
Sun Apr 15, 2007 6:40 pm
I'll look at something like that, thanks.
Users browsing this forum: SQ325 and 1 guest
