luisde8cd
How Often Do You Change Your Engine Coolant?
Tue Apr 24, 2007 2:06 am
Guys,
A simple question... what's the recommended mileage-interval in which you have to drain your engine coolant and replace it with a fresh one? Also, what can happen if you don't change your coolant? Overheating perhaps?
Saludos desde Caracas,
Luis
ArmitageShanks
RE: How Often Do You Change Your Engine Coolant?
Tue Apr 24, 2007 2:46 am
My car has over 60,000 miles and I have never changed it. I've not had any problems.
I check it when I check the oil and it still looks as good as new, so I don't think it needs changing unless something changes.
KaiGywer
Tue Apr 24, 2007 2:52 am
When it comes out of my car in the form of steam  Wink Damn Dodge..
MrChips
Tue Apr 24, 2007 4:21 am
Quoting Luisde8cd (Thread starter):
Most modern cars do not require coolant flushes for 100,000 miles (160,000 km) if they use DEX-COOL coolant (red). If you use standard (green or others) coolant, it is a good idea to flush every 15,000 miles (24,000 km) or so.
If you don't change your coolant, some very expensive things can happen. As coolant ages, the corrosion inhibitors break down. As they break down, a sludge starts to form in the low points of your cooling system, consisting of corroded metal. This can play havoc with thermostats, water pumps and radiators, blocking flow or getting into moving parts. If this happens, you are likely to either overheat or blow a head gasket.
[Edited 2007-04-23 21:22:33]
Time...to un-pimp...ze auto!
prebennorholm
Tue Apr 24, 2007 4:42 am
Never (VW Golf 1998, 244,000 miles / 391,000 km).
But it depends on type of coolant and what materials used in the engine.
Refer to the driver's manual.
Be sure to use the recommended type of coolant. Wrong type of coolant may start a runaway chemical eating of the inside of the engine, coolant pump and radiator.
The chemical properties of the car components and the coolant are from the car manufacturer adjusted to fit together.
On most older cars, maybe also newer cars of different make, you have to change coolant every two years in order to avoid chemical reduction of some parts of the engine, typically the top gasket. Those "old" types of coolant are mixed with some chemicals which are "wasted" more easily than the engine components in the chemical processes. But when they are gone (after two years), then all chemical hell breaks lose. Milage is not important. The chemical processes are active at all time, but are just a little faster when the engine is hot.
But most important, use the RTFM system (Read That F¤%&ing Manual).
Users browsing this forum: bgm, ER757, salttee, zanl188 and 42 guests
