trav110
Creating HD Partitions In XP/Dual Boot?
Tue May 08, 2007 2:01 am
So...
I've decided that I want to create a partition on my computer's hard drive that will allowe me to Dual-boot XP and Ubuntu. Unfortuantely, it looks like XP and all of the other data on my main HD is scattered onto it, unpartitioned. I followed the Windows Help instructions about partitioning a drive, and I've gone through countless freeware partition utilities, and was continually confronted with the same result: I can't partition my C: drive for "Security Reasons" because it has Windows System files on it.
Do any of you have any ideas as to how to get past this short of reformatting my drive completely and reinstalling Windows? I've got an older iPod that I don't use much anymore, should I consider reformatting it and putting Ubuntu on it, in which case I could just boot my computer from my iPod to run Linux? Is that even possible? What if I were to buy an external HD (which I'm going to need to for school soon anyway), could I partition that HD with a space for my old Windows files and another for Ubuntu?
Also, I'm having trouble making my computer recognize .iso (disk image) files upon startup; I can never get it to boot from a friggin CD (whether its the internal CD drive or the external USB 2.0 drive). I even encounter this problem when I tell the computer WHERE to look as it's booting, it simply tells me that it cannot boot from the CD drive.
I know its kind of a long-winded post with a few various problems, but any tips are greatly appreciated. Thanks!
andessmf
RE: Creating HD Partitions In XP/Dual Boot?
Tue May 08, 2007 2:14 am
Quoting Trav110 (Thread starter):
No, sorry. You can try to 'ghost' your C drive into a new one. Google Norton Ghost for a description.
You could do it, but the access speed may be too slow.
Iso files are image files of a directory content. They don't contain any bootable executables that you can use.
David L
Tue May 08, 2007 2:18 am
It's been a while since I used it but Partition Magic (formerly PowerQuest, now Norton) did the job for me on several occasions. I just don't know what freeware options there are nor how good/safe they are.
Whatever option you take, back up your data first!
Do you have the CD set as bootable in the BIOS?
David L
Tue May 08, 2007 2:20 am
Quoting AndesSMF (Reply 1):
Ah, well, yes... if you want to go into details. D'oh!
trav110
Tue May 08, 2007 2:53 am
I should also mention I have a loose understanding, at best, of computers and hardware and such so go easy on me  Wink
Quoting David L (Reply 2):
Set as bootable? I don't know, when I enter setup I have the correct CD drive chosen to be read, is that what you mean?
How does one go about using/installing anything that's in this format, then?
Thanks!  Smile
StarAC17
Tue May 08, 2007 4:05 am
The way to do this is to get 3rd party partition software such as Partition Magic and use it to shrink your current partition. From that you can create a new one using that software or probably the Ubuntu setup allows you to create a partition (however I am not familiar with it so I'm not sure if it does)
Another way is to reinstall XP and in the setup you have the option of deleting the partition (which will erase everything) and create a smaller partition and I'm pretty sure that you can create more than one in the setup before installing XP and then installing XP on one and when that is up an running you can then install Ubuntu on the other.
If you had Vista one of its new features is basic partition managing making dual booting easy.
I assume you downloaded the ISO for Ubuntu and put it on a CD as one file, If you did this you have a new coaster. What you have to do is use CD burning software such as Nero or Roxio and there is an option to burn an image.
To do this in Nero follow these steps
1) Load Nero and close the Wizard or Menu that comes up
2) Go to the "Recoreder" tab and find "Burn Image"
3) Find the Ubuntu iso file you downloaded
4) The burn menu should come up and click burn and you should be on your way
If you want to boot from a flash drive or I-pod if it works then you can download ISO buster and use that to extract the files from the ISO and put those files on the drive and see if that works.
[Edited 2007-05-07 21:18:06]
Engineers Rule The World!!!!!
hawaiian717
Tue May 08, 2007 11:38 am
Partition Magic will do the trick (I've used it), but as others have mentioned it costs money.
A free option would be to download and burn to CD (using the instructions given by StarAC17) a Knoppix image. Boot from that. It will boot to a Linux desktop right from the CD. Look for a program called QtParted (I can't remember where in the menus it is, but its there somewhere), and use that to resize the Windows partition. That will create the space you need to install Ubuntu.
Users browsing this forum: Scorpius, UltimoTiger777 and 65 guests
