UTA_flyinghigh
Friday's Stupid Thread - Distance To Extinguisher
Fri May 11, 2007 3:48 pm
So how far are you from the nearest fire extinguisher ? Mine is right across my desk, 5 meters at the most.
UTA  checkeredflag
Fly to live, live to fly - Air France/KLM Flying Blue Platinum, BMI Diamond Club Gold, Emirates Skywards
bill142
RE: Friday's Stupid Thread - Distance To Extinguisher
Fri May 11, 2007 4:20 pm
Probably about 20 meters, on the other side of the fire door. I would have thought we have more, but we don't. Clearly they'd rather the building burn.
cabso1
Fri May 11, 2007 6:49 pm
I don't have one in the house anywhere.
PAHS200
Fri May 11, 2007 6:51 pm
Quoting UTA_flyinghigh (Thread starter):
about 200 feet
miamiair
Fri May 11, 2007 7:18 pm
At wok, 25 feet away.
At home, in garage there are two. One for the kitchen is next to the door that leads into the Kitchen; the other is just inside the large garage door.
LHStarAlliance
Fri May 11, 2007 7:31 pm
30 seconds running  Smile
Boycott The Olympic Games In Beijing !
strasserb
Fri May 11, 2007 7:35 pm
5 seconds walking  Smile
Still, even in the most arid desert is an airport somewhere ...
BNE
Fri May 11, 2007 7:46 pm
At work less than 2 metres from my desk; at home there is not one here; and I am not sure even if the next door neighbour has one and they are over 100 metres away.
Glad I don't have one at home as I keep running into it at work; as it hanging off the end of the staircase.
MD11Engineer
Fri May 11, 2007 7:52 pm
From where I'm sitting now (in my office / electronics shop) there is one less than 2 meters behind me. Then I have two in my mechanical shop in my converted barn, since I do some welding work from time to time. I have a fire blanket in my kitchen, smoke detectors all over the house and two smoke hoods under my bed in my bedroom, which is a converted attic. The reason is that the house (built in 1900) is largely made of wood and would be a trap in a fire.
Jan
[Edited 2007-05-11 13:02:27]
don81603
Fri May 11, 2007 7:59 pm
At work, literally at my right foot. At home, 5 meters at most.
Eagles may soar, but weasels don't get sucked into jet engines.
OHLHD
Sat May 12, 2007 1:24 am
I am so bored at the moment at work that I measured the distance with a ruler Big grin
The distance is 7m and 41cm!!!!!!  Smile
Need to go home!
ronglimeng
Sat May 12, 2007 1:32 am
I'm located 17 steps from the nearest fire extinguisher in our house. It is a 9 lb dry chemical extinguisher.
We bought it last year after I took a smaller (3 lb ?) unit next door to put out our neighbour's stove top grease fire. I was not impressed with that very small unit and I thought we should really have a larger unit to give us a better chance of putting out a serious fire.
carmenlu15
Sat May 12, 2007 1:33 am
Shit, I just realized I have no idea where are the extinguishers in the building...  scared
Don't expect to see me around that much (if at all) -- the contact link should still work, though.
futurecaptain
Sat May 12, 2007 1:43 am
At home: I don't own one. I have no idea if any neighbors do. I'm screwed.
At work: Probably no more than 15 seconds running at any time. But of course why would I run to the extinguisher if work was on fire? I'd run out the door and let the place burn down, thats how much I care about work.
1stfl94
Sat May 12, 2007 1:52 am
I don't have one in my house but the smoke is alarm is so senstive you'd never miss a fire!!!
mhodgson
Sat May 12, 2007 2:05 am
Less than 7m. I also have a high-power sprinkler system in my ceiling.
ORFflyer
Sat May 12, 2007 2:08 am
Quoting Mhodgson (Reply 15):
That's what we have, and since we have sprinklers, the city doesn't require fire extinguishers and my bosses won't let me spend the money to buy any.
Have one at home sitting on the workbench in the garage.
PlymSpotter
Sat May 12, 2007 2:13 am
About three meters. Out of my room across the hall, and straight on my right as I enter the kitchen opposite.
Dan Smile
bagpiper
Sat May 12, 2007 2:17 am
the garden hose is about 20 feet from me. 25 second running time if I forget to open the door... if I do open the door, its about 5 seconds. (Don't have to pick myself back up, etc).
Oh, we're talking about fire extinguishers, as in the little red bottles, not a stream of water? About 200 feet, next door.
airfoilsguy
Sat May 12, 2007 3:44 am
At work about 5 feet. We have at least one fire a week around here so it is best to know where they are hanging.
It's not a near miss it's a near hit!!
adopim88
Sat May 12, 2007 3:47 am
Well at home I don't have one at all. However, at work we have them all over the place. There are 3 rows of presses in my area with 16 presses in each row. A fire extinguisher is placed at the end of every other press. There's about 3-4 feet in between each press. Since I started there almost 2 years ago no one has ever had to use one (if we have a fire we dump it on the floor and stomp it out)
Early bird gets the worm, but the second mouse gets the cheese.
AllegiantAir
Sat May 12, 2007 6:27 am
Mine is at the other side of the hallway, roughly 29 feet away.
Live to Fly.
Queso
Sat May 12, 2007 9:34 am
No more than 10 feet. I do all of my ammunition reloading in this room and all of my amateur radio gear is in the room too, therefore it is imperitave to have a good extinguisher handy just in case something were to go wrong.
MDorBust
Sat May 12, 2007 9:41 am
About three feet away, bolted to the wall at behind my desk.
At home I have one bolted to my reloading bench.
"I KICKED BURNING TERRORIST SO HARD IN BALLS THAT I TORE A TENDON" - Alex McIlveen
YYZflyer
Sat May 12, 2007 10:31 am
I just measured the distance to mine too. Big grin The distance from my current location to the extenguisher is 58 feet. I'm upstairs and it is half way into my basement...  scared  And as I was measuring the distance my dad said we should get a new one. We've had it for 8 years now and it's covered in dust.
Avoid hangovers, stay drunk.
RichPhitzwell
Sat May 12, 2007 10:37 am
At work we have an active fire suppression system. It uses sensors and emits a gas if any significant heat is present. On top of that there are fire sprinklers.
Otherwise I think there is one in every hall, so about 100' from me at any time.
At home, about 25' in a closet.
Nonav.com kinda like Whiners except the lights are on and the pimps been paid
allstarflyer
Sat May 12, 2007 12:24 pm
Quoting Cabso1 (Reply 2):
Yeah, I could use an extra one here myself.
-R
Living the American Dream
CaptainJon
Sat May 12, 2007 1:31 pm
At work, right next to me desk, by the server room/closet. So less than 5 metres. As for one in my home, I really have no idea where it is come to think of it.
[Edited 2007-05-12 06:32:08]
AirTranTUS
Sat May 12, 2007 3:49 pm
In the dorm the nearest was 10 paces away, so 8 meters or so. Here at home, the nearest one is in the garage, and my room is the furthest from there. I would estimate distance to be 25 paces, maybe 20 meters.
I love ASO!
Users browsing this forum: Ken777 and 52 guests
