LHStarAlliance
Really Need Help! My Laptop Is Going Crazy!
Sun May 20, 2007 6:15 am
Hi guys ,
It seems that I got a Trojan over MSN Messenger .
When I try to run Antivir it crashes I also tried to go to the taskmanager then it says , the administrator enabled the Taskmanager , I´ve tried to download Windows defender it also crashes ...
I don´t know what else I could do ...
I´m getting crazy !
Please help !
Konstantin
PD : All 2 min while I´m posting this message writes alone :
Hola
espero q te gusten las fotos ;
me las hice ayer y
Boycott The Olympic Games In Beijing !
TupolevTu154
RE: Really Need Help! My Laptop Is Going Crazy!
Sun May 20, 2007 6:19 am
Que Klaus and his "Should have got a Mac" speeches  Wink
But seriously, I can't be of any help to you!
Tom Big grin
aloges
Sun May 20, 2007 6:21 am
Try the safe mode ("abgesicherter Modus") and then install and run whatever you've downloaded to clean up your system. And stop opening the *OMG SOOOO FUNNY!!!!!!!* files you receive via that messenger.
Alternatively, ask Ché if he can fix it.
me =  tired   grumpy  and a damn good reason for it
LHStarAlliance
Sun May 20, 2007 6:24 am
Quoting Aloges (Reply 2):
how can I get there ?
aloges
Sun May 20, 2007 6:28 am
Quoting LHStarAlliance (Reply 3):
Hit F8 like a crazy madman during boot, and I mean right from the start. You'll get to a menu that lets you choose that safe mode; unless my memory is playing tricks on me, that is. But make sure you have the software you'll need on your HDD as the safe mode loads only very basic drivers, i.e. probably not for a USB stick you might want to use. Prepare to re-arrange your desktop icons as well after you re-boot into standard mode.
ANCFlyer
Sun May 20, 2007 6:30 am
Quoting LHStarAlliance (Thread starter):
Does this mean you WON'T be posting as much for a while?  wink  laughing
LHStarAlliance
Sun May 20, 2007 7:14 am
Quoting Aloges (Reply 4):
I´ve done that over MSCONFIG and runned my anitvir and it didn´t found any vir , but I´ve still the same problem ...
 banghead   banghead
Quoting ANCFlyer (Reply 5):
Yea , Till I haven´t solved this problem this will be my only thread ...
But I´ll be back soon
 bigthumbsup
Konstantin
aloges
Sun May 20, 2007 7:19 am
Quoting LHStarAlliance (Reply 6):
You've done what in MSCONFIG? You can screw up your system quite seriously with that, better be careful!
Have you tried Spybot and Ad-Aware? Maybe you needn't use safe mode for those, depending on what the malware - not virus - lets you do.
LHStarAlliance
Sun May 20, 2007 7:24 am
Quoting Aloges (Reply 7):
Ad-Aware
Running Ad-Aware now without safemode
BTW : thanx for taking your time to help me  Wink
aloges
Sun May 20, 2007 7:31 am
Quoting LHStarAlliance (Reply 8):
no prob
Give Spybot a try as well, but make sure to figure out how you can deactivate that "TeaTimer.exe" in case you don't want it active. It's in the "expert mode" options of Spybot that you specifically have to activate after the install. But you should probably use it as it serves to help prevent just the problem you've run into: malicious changes to your operating system.
LHStarAlliance
Sun May 20, 2007 6:49 pm
Quoting Aloges (Reply 9):
I runned spybot in safemodus and for 2 min it seems all is OK I can enter to the Taskmanager but suddenly it´s back the message :
Hola
me las hice ayer y
and I can´t enter to the Taskmanager .
 Sad  Sad  Sad
LHStarAlliance
Sun May 20, 2007 7:02 pm
When I downloaded that file It said something about olympus , I don´t know what this could mean but over the Taskmanager of spybot there was a process called olympus ...
There must be a connection ...
Konstantin
aloges
Sun May 20, 2007 7:44 pm
Quoting LHStarAlliance (Reply 10):
Did you scan the hard drive with Spybot? It may be a dumb question, but going by the info in your post you didn't. Olympus is a maker of digital cameras. Do you have the exact name of the running process in question? Google may get you to some more info, but you need the exact name of the .exe file. If you have a firewall, block that process from accessing the internet/the network you use to connect to the WWW and see in anything changes.
LHStarAlliance
Sun May 20, 2007 7:58 pm
Quoting Aloges (Reply 12):
I runned HiJack this and it seems OK now ...
Thanx
Konstantin
aloges
Sun May 20, 2007 8:10 pm
Quoting LHStarAlliance (Reply 13):
Good choice, and good luck with the computer - just remember to be more careful in the future!
LHStarAlliance
Sun May 20, 2007 8:16 pm
Quoting Aloges (Reply 14):
Yea thanx Aloges ! Really good your help !
Konstantin
LHStarAlliance
Sun May 20, 2007 8:28 pm
Bad Luck , just restarted and all same as before :
I checked the process it´s : SP2.exe in windows - system32
Konstantin
aloges
Sun May 20, 2007 8:42 pm
LHStarAlliance
Sun May 20, 2007 9:03 pm
Quoting Aloges (Reply 17):
oh yea restarted now and all seems OK now ... I had to delete the File in System32
well as said Many thanks!
Konstantin
Klaus
Sun May 20, 2007 9:04 pm
Quoting TupolevTu154 (Reply 1):
Give it a rest.
I don't kick people when they're already in trouble.
LHStarAlliance
Sun May 20, 2007 9:06 pm
He was killed by some ass***** in Bolivia some years ago ...
strasserb
Sun May 20, 2007 9:09 pm
Quoting LHStarAlliance (Reply 16):
Please check this link as well:
http://www.virus-buster.com/en/virus...N=aa76c5b7d679e7a1eb5abe8b697fb08e
Still, even in the most arid desert is an airport somewhere ...
LHStarAlliance
Sun May 20, 2007 9:42 pm
Quoting StrasserB (Reply 21):
It´s OK now thanx
Users browsing this forum: LittleFokker, petertenthije and 3 guests
