MaverickM11
My Ipod Won't Turn Off
Mon Jun 25, 2007 11:48 pm
My iPod won't turn off, any suggestions? It's a standard 30Gb iPod that you hold down the play button to turn off. Nothing works. For a while it took several tries to turn it off but now nothing. Joy.
E pur si muove -Galileo
gunsontheroof
RE: My Ipod Won't Turn Off
Mon Jun 25, 2007 11:51 pm
I'm not sure if the 30Gb model has changed since I got mine, but leaving it alone works just fine for me. Shuts off on its own every time.
Picked a hell of a week to quit sniffing glue.
deltagator
Mon Jun 25, 2007 11:55 pm
Check the Hold slide button on top of the iPod?  Wink
Hopefully so. Otherwise hold the middle button and play button down at the same time for a few seconds to restart the iPod. Then try holding the play button again to turn it off.
senorcarnival
Mine does the same thing. It used to be that it took a few tries or just letting it sit playing for a few seconds but now it's taking more and more tries. Mine's an 8GB nano though...Try the 5R's from Apple's website
http://www.apple.com/support/ipod/five_rs/
Oh no, she's getting impatient! Take a stab at it!
Klaus
Tue Jun 26, 2007 12:02 am
Suggestions:
- Check if the button has a contact problem (which can be just temporary). That might manifest by switching off on hold as desired, but then turning back on when you release the button. Pressing the button slightly differently might help in that case.
- As said above, it should go to sleep after a few minutes on its own.
- If nothing else helps, holding the menu and center buttons simultaneously for a few seconds resets the iPod. It might work after that.
dl021
Tue Jun 26, 2007 12:23 am
When mine did that it was because I left it running in the car still attached to the charger/rf connector. I let it drain and recharged it and it worked fine. It hasn't happened since.
I have the 30g version as well, and it's been terrific.
Is my Pan Am ticket to the moon still good?
YWG
Tue Jun 26, 2007 1:20 am
An Apple friend/fanatic of mine explained this problem to me after I complained to him about my ipod was doing the same.
-just reboot the ipod, and it should solve the problem.
-the reason it may not let you turn it off, is because the ipod wants to drain its battery in order to extend the life the battery. Apple has a ton of built in "smart" features like this, some make sense and some don't but in the long run it's for the best.
Contact Winnipeg center now on 134.4, good day.
Klaus
Tue Jun 26, 2007 1:22 am
Quoting YWG (Reply 6):
I'm not aware of such a feature. And refusing to turn off would be an extremely bad way to design it even if it existed.
Steve332
Tue Jun 26, 2007 1:29 am
Happened to me a couple of times, Just let the battery die and it'll be fine.
Btriple7
Tue Jun 26, 2007 2:31 am
Uh-huh...  Confused  eyebrow
I learn something new everyday.
I'd be interested to hear someone give a detailed explanation as to how this feature works, and also who came up with the idea. Seems like one of the more quirky features. I always have trouble turning off my iPod (2nd Gen. Nano) too. It's really annoying, and I don't see how draining the battery could extend battery life.
Btriple7  wave
Just...fly.
Klaus
Tue Jun 26, 2007 3:13 am
Quoting Btriple7 (Reply 9):
I am practically certain that such a "feature" does not exist and is exclusively a rumour.
It would make no sense whatsoever as a product feature.
It is not a bad idea to actually use the existing battery capacity, at least every once in a while, but a "forced discharging" feature is almost certainly not in existence.
It's simply a bug. In some cases the very small debounce delay in the iPod can be a (temporary) problem when releasing the button appears to switch the iPod back on after holding the button has put it to sleep, but pressing the button slightly differently takes care of that.
A reset (holding menu+center) should take care of any otherwise intractable problem that should still remain.
Jpax
Tue Jun 26, 2007 3:36 am
Smashing it with a large hammer and proceeding to douse and ignite it with gasoline will certainly turn it off.
Now, how 'bout that warranty?  Wink
pawsleykat
Tue Jun 26, 2007 5:03 am
I find that it happens with my 30Gb one.... it usually happens if I am in the song screen. What i do to resolve the problem is to come back into one of the menus and try again from there  Smile hope this helps
JG
WestJetYQQ
Tue Jun 26, 2007 8:39 am
Quoting MaverickM11 (Thread starter):
Consider Yourself Lucky. Mine won't turn on. It got bent in half.  Wink
Will You Try to Change Things? Use the Power that you have, the Power of a Million new Ideas.
ThePRGuy
Tue Jun 26, 2007 8:42 am
Ring Apple.
Alex
Heathrow has been described as the only building site to have its own airport.
Jamie757
Tue Jun 26, 2007 8:49 am
Generally speaking it's better to fully drain a battery before it's recharged. This prevents so called 'memory effects' and helps to maintain the specified capacity.
Rgds.
"I feel like a turkey who's just caught Bernard Matthews grinning at him!"
jamesjimlb
Tue Jun 26, 2007 9:16 am
play songs for hours and it will run out of batteries.
The sky is no longer the limit, but the mere minimum
lincoln
Tue Jun 26, 2007 9:32 am
Quoting Jamie757 (Reply 15):
I though that that was higly dependent on the battery technology/chemistry. For example, my understanding is that NiCad batteries are highly succeptable to develop 'memory' whereas Lithium Ion batteries are significantly less succeptable to memory and certain battery technologies (though I can't remember which off the top of my head) may actually be damaged by running the battery completely down.
Lincoln
Jamie757
Tue Jun 26, 2007 9:59 am
Quoting Lincoln (Reply 17):
I think you're correct there, that said, the mobile phone that I have now has a Li-Ion battery and the manual recommends that it's cycled fully.
I believe that Lead-Acid (car) batteries can be damaged if deeply discharged.
Rgds.
Klaus
Tue Jun 26, 2007 10:18 am
A deep discharge is bad for the life expectancy of any battery, Li-Ion or not.
WellHung
Tue Jun 26, 2007 10:32 am
Since you can't just pop the battery out, one would think such a revolutionary piece of technology would have one of those 'reset' hole dealies where you stick a pin or something and the device resets. These are standard on many other media players. Waiting hours for the battery to run out seems rather silly and unnecessary.
Klaus
Tue Jun 26, 2007 10:36 am
Quoting WellHung (Reply 20):
And it is.
As I explained above, resetting the iPod merely requires holding of the menu and center buttons simultaneously for a few seconds. That's it.
A330300
Tue Jun 26, 2007 12:19 pm
Cycle the hold switch at the top....
Then, press the menu (top of the ring) and center buttons simultaneously for about five seconds, this should reboot the iPod. If it happens frequently, I would suggest updating the iPod software.
Pohlcat
Wed Jun 27, 2007 11:45 am
I have the (expensive) 80Gb version I bought this spring. It holds all 9,200+ songs in my music library. I love it. But as magnificent as it is, I also had problems turning it off by holding down the pause button. The backlight would turn off, but the screen was still visible. Even when I wasn't playing music, it was still draining my battery.
The only way I was able to fix the problem was to restore (not reset) the iPod, which was a relief in some ways knowing it wasn't broken, but it took nearly three hours to complete the process since restoring an iPod erases everything with all that music I have. I don't know what caused the problem of suddenly it's not able to turn off the way it should. I payed good money for this thing and I don't want to have a shortened battery life because of a mysterious "iPod won't turn off" ordeal.
Pohlcat
LH423
Wed Jun 27, 2007 12:10 pm
Funny that this is mentioned. I had this happen to me last Friday. I believe I might have been going to quickly through songs I didn't want to listen to and it caused my iPod to freeze up. I tried the standard reboot button hold and every imaginable combination after and nothing seemed to get it to reboot. I had to let it die and recharge it to get it to work again. The timing really sucked too since I had a 25 minute subway ride and a 75 minute train ride and no music.
Quoting Klaus (Reply 19):
Normally I let my battery run to the red zone (not completely dead), is this wrong? Should I be charging it more frequently? I have for years heard conflicting information on whether to let batteries run dead or close to dead before recharging and other times being warned against letting them get too low. What do you recommend? How often should I recharge my iPod battery?
LH423
« On ne voit bien qu'avec le cœur. L'essentiel est invisible pour les yeux » Antoine de Saint-Exupéry
Klaus
Wed Jun 27, 2007 4:31 pm
Quoting LH423 (Reply 24):
The red zone is not actually deep discharge, it's just the "recharge now, please!" indication.
Deep discharge means the state of the battery actually being discharged completely which you normally can't do because the iPod would turn off automatically before that.
I'm using mine just the same way - I let it run down until it switches off on its own or at least into the red zone normally. The important thing is to no let it sit on a shelf for a long time when discharged that far, because it could then sink further down into a deep discharge where the chemicals in the battery can start to degrade.
When it's normally discharged I simply charge it up again to full capacity as soon as possible. Li-ion batteries are somewhat less susceptible to the dreaded "memory effect", but doing proper charge/discharge cycles seems to be a good idea nevertheless.
I've got a first generation iPod nano and it's still going strong with rather frequent use.
jamesbaldwyn
Wed Jun 27, 2007 6:36 pm
Look in the manual for exact action but I believe that u have to move the switch to the hold position and then hold the center and menu button down. This resets the ipod and you will be off Big grin
Klaus
Wed Jun 27, 2007 7:42 pm
Quoting Jamesbaldwyn (Reply 26):
No. If the reset didn' work the first time, cycle the lock switch (unlocked - locked - unlocked) and in the unlocked state hold the two buttons to reset.
LH423
Thu Jun 28, 2007 1:15 pm
Quoting Klaus (Reply 25):
Thanks. Then I'll just keep doing what I've been doing all along!
LH423
aaflt1871
Thu Jun 28, 2007 1:32 pm
Where did everybody go?
Users browsing this forum: Bing [Bot] and 1 guest
