aloges
MacBook / Parallels Desktop / Win Vista Question
Mon Sep 10, 2007 1:45 am
Hi all,
someone I know is getting a MacBook (the white one with 2.16 GHz) and I'm trying to be a bit helpful. She got a bundled deal for a Leopard upgrade and a substantial discount on Parallels Desktop, so for that reason she will install that VM. We are however not quite so sure which Windows version to run through PD. XP or Vista? As there will be a proper OS  Wink on the machine at all times anyway, we lean towards Vista. Is there any fundamental reason against it? The prices for OEM versions on both eBay and Amazon weren't that far apart, hence not an issue.
The other issue is 32-bit or 64-bit? I've done a bit of reading up on the issue and it appears that 64 is too much of a resource hog for a MacBook, even with Boot Camp as opposed to a VM. Compatibility seemed to be a problem as well. Any info on that?
Any help is much appreciated!
N231YE
RE: MacBook / Parallels Desktop / Win Vista Question
Mon Sep 10, 2007 2:46 am
From what I know, if it has the Intel Core Duo, it is the 32 bit version of XP or Vista.
If it has the Intel Core 2 Duo, then it is the 64 bit version.
My former college roommate had a white MacBook 17" (I think that was the size), and since it had just the Intel Core Duo, he had the 32 bit version of XP Pro installed, via Bootcamp.
Personally, I'd tell you to go with either XP or Vista Basic. Since I assume you will be running OSX for most of your needs, don't drop down the extra money of the added features of the premium versions of Vista.
Wait for Klaus to chime in for a better answer.
aloges
Mon Sep 10, 2007 3:08 am
Quoting N231YE (Reply 1):
 checkmark  That one. I read though that this wasn't a "proper" 64 bit CPU, but rather something along the lines of glueing 2 32 bit ones together...  confused
a white MacBook 17"
Wouldn't that have to be a MacBook Pro?
Thanks for mentioning that one, that "Aero Glass" GUI is said to be a resource hog so you'd probably be better off with Basic where it's disabled... in a VM environment, at that.
Ooooh, if only it were me...  cloudnine  But yes, the thing will run OS X mainly.
I excluded him from the thread starter with difficulty...  Wink  Silly But thank you!
Klaus
Mon Sep 10, 2007 3:28 am
64 bit per se is not a resource issue, other than providing the possibility to applications to use - for instance - more than 4GB memory space. On the Intel architecture 64 bit code can also run faster since it discards the limitations of the IA32 architecture (the PowerPC never had such limitations, so 64 bit code will usually not be faster).
MacOS x 10.5 Leopard is a complete 64 bit operating system when running on a G5 or Core 2 CPU, just fully backwards compatible with existing 32bit applications and drivers.
When running on an older 32 bit CPU (such as a G4 or Core 1 CPU) it automatically runs as a 32 bit OS without the user noticing much of a difference.
On the Mac side it is quite possible that Leopard will actually run faster in 64 bit than in 32 bit.
64 bit has only become somewhat of a scare issue through the separate and incompatible Windows versions between 32 and 64 bit. Since there are numerous incompatibilities as far as I'm aware, you will probably be better off using the 32 bit version in almost all cases. If you don't know of a really compelling reason to install the separate 64 bit version, just don't. Parallels Desktop will also not run Windows 64 at this time (although that may change down the road).
Choosing between XP and Vista is again a matter of requirements. Vista comes with a whole bunch of problems at this point without actually offering that much more than XP except the hope that future service packs may improve the situation. It depends on what your friend is going to use it for.
Klaus
Mon Sep 10, 2007 3:35 am
Quoting Aloges (Reply 2):
No, it's a true 64 bit CPU. Just running in 32 bit mode under the current MacOS X 10.4 Tiger most of the time (internally Tiger does already use some 64 bit code on the system level).
Indeed. No non-Pro MacBook at 17", I'm afraid.
Oh, you can disable that one in any VIsta version as far as I'm aware. It will even do that for you if it happens to fail its "Genuine Advantage" check because MS has screwed up its servers again...!  crazy
No need for special consultations before posting it!  silly
moo
Mon Sep 10, 2007 3:48 am
Quoting Klaus (Reply 3):
Huh? The 64bit extensions used in the Pentium 4, Core 2 Duo and the Xeon are all extensions on top of IA32, and thus have all the same legacy cruft - the extensions are based on an AMD design (yes, even the Intel implementation, called EM64T) called AMD64.
EM64T does remove several older technologies, but it is still an extension to the original x86 line, and thus retains the same legacy. The main reason why code runs faster in 64bit mode is because of the extra registers supplied in the package, but you can target many 32bit compilers to use these registers as well for 32bit code.
You may be thinking of IA64 which was implemented from scratch by Intel with no x86 legacy, and is implemented in the Itanium and Itanium 2 - both have nothing to do with the Mac range of computers.
aloges
Mon Sep 10, 2007 3:51 am
MS Office (for Mac), webmail and surfing until university starts and then whatever they require. She's getting PD through this, might be interesting for you as well: http://gravis.gravis.de/leopard/ I advised against waiting until October when Leopard will be released so she can get used to Mac OS X before things get serious at uni and so she can be sure to avoid supply shortages.
Quoting Klaus (Reply 4):
Ah, that makes more sense. Of the blunders Intel have made, I didn't expect the Core 2 Duo to be one.
...and even activate it in Home Basic.  Wink If that is actually true, it's just as fascinating as Microsoft's licensing scheme.
Oh dear... tell me about it. Or rather, please don't.  Wink
 biggrin
hawaiian717
Mon Sep 10, 2007 4:00 am
I recall some discussion about Microsoft waffling about whether they would allow the less expensive versions of Vista to run in a virtual machine. There likely aren't any technical restrictions, just verbiage in the license agreement.
Considering Vista's resource hogging and overall annoyance to use, I'd stick with XP.
Klaus
Mon Sep 10, 2007 4:22 am
Quoting Moo (Reply 5):
The crippled register set was the main problem of the IA32 architecture (next to the formerly used segmentation nightmare, of course); The 64 bit architecture introduced by AMD and thankfully adopted by Intel finally overcame that limitation. The opcode structure wasn't that much of a problem.
No, I'm always trying to forget about that piece of junk. The sooner it sinks back into oblivion the better!  yuck
Quoting Aloges (Reply 6):
Ah, neat! But since I already own Parallels Desktop it's not that much of a bargain for me.  Smile
swiftski
Mon Sep 10, 2007 8:21 am
Quoting Aloges (Thread starter):
Where? What were the terms of that?
MS Office (for Mac)
Get iWork '08. Far superior, and cheaper.
N231YE
Mon Sep 10, 2007 10:01 am
Quoting N231YE (Reply 1):a white MacBook 17"
Yeah, it might be a 15." I could call to find out, but I would think I am talking to a salesman telling all the pros of OSX and all the cons of Windows, and why I should invest in a Mac.
Ooooh, if only it were me...    But yes, the thing will run OS X mainly.
Well, maybe you might want to get Vista Ultimate, then through down some other dollars for other things, after all, Klaus would agree that Windows is far superior  wink   silly
aloges
Mon Sep 10, 2007 6:13 pm
Quoting Swiftski (Reply 9):
http://gravis.gravis.de/leopard/ €129,- for the Leopard upgrade, a €25,- discount on a min 500GB Iomega external HD and a €45,- discount on Parallels Desktop.
Another bundle, for students this time... and I might add, even better: €0,99 if purchased together with a mobile computer and you get a printer on top of it. All things combined, that was even cheaper than the substantial Apple on Campus discount I could get.
Users browsing this forum: aerlingus747, cf105arrow, johnboy, johns624, TWA772LR and 1 guest
