Queso
My Shower Head Sounds Like A JT8D!
Mon Dec 03, 2007 1:44 pm
I thought about posting this when I started the water flowing for my shower at 4:50am this morning. The shower head makes it sound just like a JT8D! And since I live out in the sticks and have water from a well, the pressure slowly fluctuates as the pump cycles on and off so it gradually sounds as though it powers back to cruise and descent as the pressure tank empties, then rapidly spools up to takeoff thrust then the pump cycles on again!
I used to have a massaging shower head and it sounded like a Chinook or a V-22 Osprey.
ANCFlyer
RE: My Shower Head Sounds Like A JT8D!
Mon Dec 03, 2007 1:56 pm
You need to get out more . . . .  laughing
On the upside, at least you're taking a shower . . .  wink
bhmbaglock
Mon Dec 03, 2007 2:00 pm
Quoting Queso (Thread starter):
Try some Lime-out. On the shower head, not the JT8D.
You need to get a bigger tank or adjust the pressure at which the pump cuts on. This really shouldn't be noticeable. The other possibility is that the pump is on its last legs. I had the same symptoms once and that's what it was. Unfortunately, the casing was corroded and we weren't able to get the pump out and ended up having to drill a new well. $$$
Funny, they sound quite a bit different to me.
Where are all of my respected members going?
Queso
Mon Dec 03, 2007 2:14 pm
Quoting BHMBAGLOCK (Reply 2):
Naw, everything is in good working order. I have the cut-in and cut-off ranges set very wide on purpose. It cuts in at about 30 and cuts off at abour 65. The tank and pump are fine, it takes the pump (Grundfos 1HP) about one minute (with no outflow) to fill the tank from 30 to 65 PSI and it takes the shower about 4 or 5 minutes to draw it back down to 30. It has always run like that. Most people wouldn't notice it but I am really nerdy that way.  Wink
Like a Hughes 500 maybe?
falstaff
Mon Dec 03, 2007 2:18 pm
I used to live in a really crummy apartment where the shower sounded like a engine about to throw a rod. When the pipes would start to bang you knew to stand out of the way because either the water was going to get very hot or very cold. After a while I knew how much the temperature was going to change by the pitch of the sound.
My mug slaketh over on Falstaff N503
bhmbaglock
Mon Dec 03, 2007 2:25 pm
Quoting Queso (Reply 3):
V-22 is similar but with some extra harmonics from the second rotor disc(and slightly different orientation at times)  Smile
I kept mine much closer, ~ 15 psi IIRC. You really couldn't tell it wasn't city water other than it tasted much better.
GQfluffy
Mon Dec 03, 2007 3:16 pm
Hmmm...I'm not conscious at 0450, much less to recognize engine types....
Caffiene, I love you...
This isn't where I parked my car...
Nuori5084
Mon Dec 03, 2007 11:58 pm
Don't stop taking showers. Use your head and replace the shower head.
Failure to plan on your part does not constitute an emergency on my part.
FlagshipAZ
Tue Dec 04, 2007 1:24 am
Anyone here know where I can find a shower head like sounds like a CF6, or a CFM56 on a rainy day?
"Beer is living proof that God loves us and wants us to be happy." --Ben Franklin
tz757300
Tue Dec 04, 2007 1:33 am
Quoting FlagshipAZ (Reply 8):
Or what about a VC-10 on takeoff?
LETS GO MOUNTAINEERS!
goboeing
Tue Dec 04, 2007 1:39 am
Can you take a video of this and put it on youtube for us or something?
FlyDeltaJets87
Tue Dec 04, 2007 1:59 am
The scanner in the computer lab at our detachment sounds a lot like the flap system on a 757.
You should install a parachute reverser on the thing then, since that's the coolest part of the JT8D engine.  wink   silly
"Let's Roll"- Todd Beamer, United Airlines Flight 93, Sept. 11, 2001
MCOflyer
Tue Dec 04, 2007 2:04 am
We need a video of it running compared to a JT8D. Anyways that is funny.
Hunter
NWADC9
Tue Dec 04, 2007 3:53 am
At least it isn't running like a JT3D  Wink
I get paid to convert dead dino juice into noise.
sovietjet
Tue Dec 04, 2007 5:38 am
Or a JT3C lol ....................................
Queso
Tue Dec 04, 2007 12:55 pm
Quoting GoBoeing (Reply 10):
Strangely enough, I thought about doing that. I'll see what I can do. You'll have to ignore the singing in the background though.  Wink
Aaron747
Tue Dec 04, 2007 2:19 pm
Not to be crass or childish but have any of ya'll experimented with the various sounds you can get from putting hands over your ears while the shower spray hits the back of your head? I've been able to get it at just the right spot where it sounds like that awesome bass-filled crackle and pop from the SRBs in a space shuttle launch  Smile
airfoilsguy
Tue Dec 04, 2007 2:24 pm
Stick a hush kit on it. I am sure you can find one on Ebay if you look hard enough.
It's not a near miss it's a near hit!!
Molykote
Tue Dec 04, 2007 2:32 pm
I want your showerhead!
Why would anyone want to get rid of that sound  cloudnine
Speedtape - The aspirin of aviation!
Siren
Tue Dec 04, 2007 9:03 pm
It brings new meaning to the term 'wet thrust'.
Siren: 32 year old single white female based @ KLAX. Aviation nerd, political wonk, disability rights activist, German car enthusiast, Californian Independence leader & evangelist
Users browsing this forum: ACDC8, aerlingus747, BawliBooch, Bengan, Francoflier and 1 guest
