rootsair
Travelling With 2 Passports
Sat Dec 29, 2007 6:58 pm
Hi folks
I am sure more than one person here travels with two passports. This is my case. I have both Costa Rican and Swiss nationality. When travelling GVA-CDG-ATL-SJO I used my Swiss passport all the way except when I entered Costa Rica, which I did with the Costa Rican passport. This is the first time I trevelled to the US using both passports.
I entered Costa Rica with the CR passport and so I will exit with the CR passport because my Swiss passport has no entry visa stamp in the passport.
However in ATL I will show my Swiss passport since I don't need a visa for the US with it. Is there any risk that US authorities ask for the Costa Rican exit stamp and thus find out I am travelling also with Costa Rican passport and require a Visa?
Would you recommend me to exit with the Swiss passport even if it has no entry stamp inside it?
If you have a nationality that doesn't requie visa like the Swiss, can they still ask you a Visa because you have a nationaliy that requires Visa?
that would be nice if you could answer me those doubts
 airplane   wave
A man without the knowledge of his past history,culture and origins is like a tree without roots
LAXintl
RE: Travelling With 2 Passports
Sat Dec 29, 2007 7:04 pm
I'd enter the US with whatever passport is used when checking in at SJO.
Airlines now scan, or input your details for transmittal to US authorities before the plane ever arrives in the US. Having info transmitted about you with one passport, and arriving with another could be the cause some issues.
AirNZ
You shouldn't have any problems at all as entering as a Swiss citizen does not require a pre-approved visa (it will be provided on entry into the US)
I certainly wouldn't exit Costa Rica using your Swiss passport as that could flag up all sorts of unnecessary difficulties.
Flown:F27/TU134/Viscount/Trident/BAC111/727/737/747/757/767/777/300/310/320/321/330/340/DC9/DC10/Dash8/Shorts330/BAe146
slz396
Sat Dec 29, 2007 7:25 pm
Quoting RootsAir (Thread starter):
In short, NO.
You are a full Swiss national and as such you benefit from all 'advantages' of having this nationality, including falling under the Visa waiver program of the USA when going there.
Quoting LAXintl (Reply 1):
Correct, but that's the problem of the immigration services. Besides, the info contained on both passports should be the same, so they can still do their check up, based on info of the exit passport they've received from the airline and it should match the info they should have found if they would have had your entry passport data.
It really is up to the US immigration service to connect the dots here, because as a holder of 2 passports you are not doing anything illegal when using your passport to exit your own country, and enter the US with the other because it gives you more privileges: they are both valid and real.
Besides, I am sure you know this, but when you hold 2 passports and you want to enter/leave a country you hold the passport of as well, you are required to present THAT passport. In this case RootsAir would be in breach of the rules on nationality if he'd pretend to be Swiss when entering or leaving CR when also holding a passport of CR!
Same in Switzerland: they see him as a FULL and ONLY as a Swiss national, and won't recognize him as a foreigner should he want to.
To all other countries, the choice is up to him and yes, he may even change during the flight.
rootsair
Sat Dec 29, 2007 7:36 pm
Quoting Slz396 (Reply 3):
This is true! Had not thought about that but I had heard one time that if you have CR nationality your are obliged to enter with CR passport if ever you posess a valid one!
kiwiandrew
Sat Dec 29, 2007 7:37 pm
That applies for a lot of countries , certainly the US and Australia amongst them , but not necessarily all countries , a dual NZ / UK passport holder is entitled to enter NZ on their UK passport provided it has a permanent residency stamp ( my sister does it all the time ) , however the authorities do prefer that you enter NZ on the NZ one , and they do like you to enter and leave on the same passport though for convenience sake I often enter on the NZ one and exit on the British one ( since I live in Belgium the airlines always want the British one rather than the NZ one so they can be sure that they wont be fined for carrying someone on the wrong documentation and the NZ one does not give me the right to live here ) for which I regularly get 'told off' but usually when I explain the reason they just shrug and say "you are not really supposed to do that "
[Edited 2007-12-29 11:40:47]
slz396
Sat Dec 29, 2007 7:42 pm
Well, dual passport holders from UK and any other British Commonwealth nation are not really good examples, neither are persons who hold 2 EU passports as these countries do grant far greater immigration privileges to each others citizens anyway.
A CR and Swiss passport however are 'likely' a good set of passports to demonstrate the general principle.
mham001
Sat Dec 29, 2007 7:45 pm
Just because it's "their" problem does not necessarily mean it will not become Roots problem.
LAXintl
Sat Dec 29, 2007 7:50 pm
And I guarantee you they will.
If the presented passport is different passport then was scanned in CR, they will definately notice it as his details will not match the pre manifest when his passport is rescanned in customs in ATL.
At the end of the day, its really no big deal, yes he'll be let in off course, but likely be subject to a few more questions if not sent off to secondary inspection.
I know of two people that similar things have occurred to. One with dual citizenship where the airlines transmitted passport details did not match the passport used for US entry, while another one a US green card resident happens to have a letter in his foreign name that is non existent in English. Upon arrival it was noted his passport did not match his green card 100%. To solve this he either had to change his name(that one character) in his passport to match his green card, or change the green card to match his passport. Apparently there is a universally recognized method for displaying that one character being a double A "aa". At the end of the day being a long time US resident it was easier for him to change his foreign passport then all of his entire US documentation to match that "aa" spelling.
Bottom line is, now with electronic data transfers its much harder to shuffle various documents, or passport around as one travels the globe.
slz396
Sat Dec 29, 2007 7:57 pm
Quoting Mham001 (Reply 7):
The only problem that may arise is some US immigration officer being not familiar with the situation, but that would surprise me, since it happens all of the time really. Many people hold 2 passports and make use of the best one depending to the country they visit as Kiwiandrew just showed us.
kiwiandrew
Sat Dec 29, 2007 8:02 pm
I would actually recommend that you double check with the authorities of all three countries concerned , as a former travel agent I know too well the problems caused by accepting advice from well meaning people based on their experiences which may be quite different to your own - there were a large number of cases where I had customers tell me "My friend said that you are talking rubbish and you dont need a visa/six months validity/ etc , they did it three years ago and had no problems "
rules and restrictions change all the time and no offence to anyone on this forum as I dont believe anyone would intentionally misinform you but this is not the place to get that sort of information .
assuming that you are connecting right through on your way home ( you didn't actually specify ) then the airline carrying you out of SJO will probably want to see some proof that you are entitled to enter Switzerland without an onward ticket - if your CR passport does not have any entries indicating that you have permanent residence in Switzerland then it is likely you will need to present your Swiss passport just to be accepted for checkin .... but , as I said earlier , please dont take my word for it - check with either the authorities concerned or a reputable consular advice service ( which will not be free ) there is one in New Zealand called Travcour which guarantees the accuracy of their advice , I assume similar agencies will exist in other countries
carmenlu15
Sat Dec 29, 2007 8:09 pm
Quoting Kiwiandrew (Reply 10):
 checkmark
There's another thing... airport agents in Costa Rica will check if you have all the necessary documentation to travel to your final destination, and will not board you if you don't fulfill all the requirements. You will have to show proof that you are allowed to enter the U.S., which in this case would be your Swiss passport (I am assuming you don't have a visa stamped on your Costa Rican passport). You should better check first...
Don't expect to see me around that much (if at all) -- the contact link should still work, though.
mariner
Sat Dec 29, 2007 8:13 pm
Quoting Kiwiandrew (Reply 5):
And NZ may yet make is mandatory to use the national passport, as the US and Australia have done.
I have two passports, Australian and UK, and my Australian passport gives me all rights of residency in NZ - I don't need any sort of residency stamp in that passport, but my residency is recorded in the Immigration computers.
If I go to Australia, I enter and leave on my Australian passport. Doing anything else would create considerable hassles.
As for entering NZ on one passport and leaving on another, you may not had had a problem so far, but I think you're still rolling the dice.
Why play games with immigration?
mariner
aeternum nauta
slz396
Sat Dec 29, 2007 8:14 pm
Quoting LAXintl (Reply 8):
You make it sound as if it would be something suspicious even clandestine to do?
As pointed out, it is perfectly legal to 'change nationality' during the trip and in some cases one is even obliged to do it: What with US citizens who have a dual citizenship and travel to the country of which they also hold the nationality of?
Upon them leaving that country back to the US, they are normally required to present that country's passport, but I can hardly imagine they will stand in line upon arrival in the US to have their foreign passport stamped off? They just go the way all US citizens go (it is even obliged as US national) and the imigration officer may wait forever for that Mr. Joe Average from the Republic of X to show up at his desk...
In short: the international laws fully allow for it so the US immigration rules should fully cater for it and in a customer friendly, efficient and polite way.
[Edited 2007-12-29 12:17:15]
rootsair
Sat Dec 29, 2007 8:17 pm
Quoting Carmenlu15 (Reply 11):
good point ! iThus for checkinh in I will have to show my Swiss passport! I guess this is the last time I will travel with both passports to prevent all the hassle and stick to my Swiss one!
 airplane   wave
slz396
Sat Dec 29, 2007 8:21 pm
Always a MUST!
Assuming that you are connecting right through on your way home ( you didn't actually specify ) then the airline carrying you out of SJO will probably want to see some proof that you are entitled to enter Switzerland without an onward ticket - if your CR passport does not have any entries indicating that you have permanent residence in Switzerland then it is likely you will need to present your Swiss passport just to be accepted for checkin ....
Which is the best thing to do really;
Check-in: use your Swiss passport, as this is the data transferred to the US immigration office.
Boarder control in CR: use your passport of CR as obliged.
Boarder control in the US: use your Swiss passport as it will give you entry without a visa and match the data from the airline, it keeps the US immigration office ignorant, but happy  Wink
Boarder control in ZRH: use your Swiss passport as obliged.
Easy and fun to do.... Big grin
LAXintl
Sat Dec 29, 2007 8:39 pm
Quoting Slz396 (Reply 13):
One of the benefits of electronic data transfer and the new US lead global digital passport format requirements is that it certainly does helps reduce clandestine activity -- wether terrorism, smuggling, forged documents, or people swapping documents amongst each other. Additionally, with data transfer authorities can now build a travel history on individuals which can have its own uses.
Swapping documents back and forth on a journey simply can be cause of a red flag.
Yes it is. However if you plan on entering the US, strongly suggest your checked in passport matches the one you present to immigration authorities otherwise you'll have a few more questions to answer.
A US citizen is required to always travel under his/her US passport when entering or exiting the US. Same goes with Green Card holders whom must present their Green Cards regardless if they have the ability to enter the US under other immigration provisions such as the Visa-Waiver.
Dont think the US cares less if 90 other countries happen to want to do something and it does not. At the end of the day it will do what it things is best for it.
rootsair
Sat Dec 29, 2007 8:40 pm
Quoting Slz396 (Reply 15):
thanks, I'll follow your advice
I'll fly into GVA  Wink but thanks still
mham001
Sat Dec 29, 2007 8:47 pm
Dual citizenship is generally not legal in the US. I know it isn't uncommon, but legally you can lose your US citizenship if you have pledged allegiance to another country. Holding two passports is not something a US citizen really wants to talk about with the authorities.
rootsair
Sat Dec 29, 2007 9:11 pm
Quoting Mham001 (Reply 18):
I heard many people who have lived away from the US for many years (eg a guy from the US living in Switzerland) gets Swiss nationality in order to lose the US one as not to have to pay taxes to the USA anymore
 airplane   wave
slz396
Sat Dec 29, 2007 9:17 pm
Quoting LAXintl (Reply 16):
Problem is, if you hold a passport of another country, you often have to enter that country under its passport too according to the rules... Now what? You show the passport of that country at ITS immigration services and the other one at the immigration services of the other, everywhere else you just choose.
Some people are born with 2 nationalities and do not choose for it, so there isn't any naturalisation taking place.
Everybody born in the UK is automatically also a UK citizen. even if he or she is the child from 2 foreigners. My grandma is British and Belgian through this way, despite it not being allowed to be naturalized AND keep your Belgian nationality under our law. Same for every US citizen born in the UK: he or she is always a legal Brit, even if he/she doesn't apply for the passport and what's more, he/she can't even renounce on it! Wonder how many millions of US citizens are at risk of loosing their citizenship?  Smile
Don't talk about it, pretend it doesn't exist. But it does and by the millions.
I regularly get 'told off' but usually when I explain the reason they just shrug and say "you are not really supposed to do that".
ROTLF.
That's what you get if you absolutely want to make everybody fit into well-defined boxes all the time; whenever some of them happen to fit into 2 boxes at the same time our systems can't handle it, so better to ignore it then.
mariner
Sat Dec 29, 2007 9:28 pm
Quoting Slz396 (Reply 20):
Within my experience, they handle it fine. I make no secret of the fact that I have two passports and it isn't a problem. As long as I have the correct paperwork for the country I am trying to enter, they shrug.
But - if you try to play games, Immigration can lose any sense of humor.
Entering on one passport and leaving on another is, of course, possible, people do it all the time. But it is also possible - and likely - for Immigration to get bloody-minded about it, depending on your attitude.
They can question you about your paperwork and take a remarkably long time doing it. You miss your flight out? Not their problem, they're not going anywhere.
They can call in Customs or Security to check your luggage and take a remarkably long time doing it. You miss your flight out? Not their problem, they're not going anywhere.
Missing your flight out is not the worst thing in the world, but it can be (a) inconvenient and (b) expensive. Neither of those are Immigration's problem.
mariner
aeternum nauta
LAXintl
Sat Dec 29, 2007 9:40 pm
Which is allowed. Summary of the US law;
The U.S. Government recognizes that dual nationality exists but does not encourage it as a matter of policy. Persons may have dual nationality by automatic operation of different laws rather than by choice. A U.S. citizen may acquire foreign citizenship by marriage, or a person naturalized as a U.S. citizen may maintain the citizenship of the country of birth, but required to owe allegiance to the United States (Upon taking the oath of citizenship, one renounces any allegiance or fidelity to any foreign state.)
Its not allowed however for a US citizen to go out and seek additional citizenship without risking their US citizenship;
Person who acquires a foreign citizenship by applying for it may lose U.S. citizenship. In order to lose U.S. citizenship, the law requires that the person must apply for the foreign citizenship voluntarily, by free choice. Intent can be shown by the person's statements or conduct.
Quoting RootsAir (Reply 19):
Yes suppose some do, as a US citizen one is subject to taxation on global income, however with most countries having dual-taxation treaties I'm not sure how much of a problem this really is especially since US tax rates are some of the lowest in the industrial world.
Also if they ever re-emigrate back to the US they potentially face a whole host of new problems in the future.
Sat Dec 29, 2007 10:47 pm
I have many passports  Smile. This has never been a problem. During check-in at CCS, I usually give the passport I am entering U.S. with ... then at immigration, give them my VZ passport. In the U.S., I give them my Liechtenstein and/or other VW country passport. Never had any issue. Of course, as some have mentioned, do verify.
rootsair
Sat Dec 29, 2007 11:13 pm
Quoting Abrelosojos (Reply 23):
wow did you ever live in FL or is one of your parents from there ????
LH423
Mon Dec 31, 2007 2:25 pm
The APIS data is sent but not used for comparative purposes. Basically, they look for potential arrivals that they wish to flag for additional screening but data is not necessarily compared against the person standing in front of the officer. However, if RootsAir is worried, as Slz396 said, check in at SJO with your Swiss passport but go to emigration with your CR passport. That way, the data sent to the US will show your Swiss passport info but the CR authorities will see your local passport.
LH423
« On ne voit bien qu'avec le cœur. L'essentiel est invisible pour les yeux » Antoine de Saint-Exupéry
TransIsland
Mon Dec 31, 2007 3:56 pm
I do this all the time... all you need to do is show the airline at check-in your Swiss passport (for they are the ones forwarding the info to the US authorities), but when leaving Costa Rica, you show the Costa Rican authorities your Costa Rican passport at the passport check.
I'm an aviation expert. I have Sky Juice for breakfast.
N1120A
Mon Dec 31, 2007 8:35 pm
No, because they would then be in violation of the treaties regarding immigration and visas with Switzerland.
It wont become a problem
Yes, it is generally very legal. The US Supreme Court has already weighed in on this issue.
Only sort of. You have to actively renounce your citizenship to a US consular official, or you don't renounce it.
It really doesn't matter. There are countless dual, even tri-nationals in the US who travel all the time using multiple passports. If you don't think the US government knows they have two passports, you are dreaming.
Quoting LAXintl (Reply 22):
Such intent to renounce US citizenship can essentially only be proven by the active renunciation of citizenship in front of a US consular official. Merely applying for another citizenship has no real bearing on things.
foppishbum
Tue Jan 01, 2008 3:52 am
Side notes: I will hold both Taiwanese passport and also US passport soon (when they finally set an interview date for me! ARGH!). The rule says if you're born another country's citizen then move to US, you have the right to hold both. However, if you're born an American citizen and you apply for other citizenship, you'll have to be prepared to give up US nationality (or something along the line). There was another thread that talked about this in non av...topic is something about US immigration rules.
My family just use US passport now since one can stay in Taiwan visa-less for 30 days with US passport and we most likely don't stay in Taiwan for over 30 days.
Cheers;
foppish bum
Taiwanese-American :D
rfields5421
Tue Jan 01, 2008 4:31 am
There is a rather long thread on this about two pages down on the Civil Aviation forum - but basically the dual-national arrived at the airport with a valid passport for his non-US nation and an expired US passport.
When he responded to the question about right to enter the US, he said he was a US citizen, but the airline refused to board him because the passport was expired.
They would not allow him to travel on is valid Norwegian passport - requiring he visit the US Embassy and have his US passport renewed.
The policies are hard to find, but very clear - US citizens/nationals must have/ present a valid US passport.
Being a dual national means you have to deal with twice as much official BS and paperwork, and be prepared for multiple delays when things don't match-up.
It doesn't mean you have more freedom and fewer hassles - but the opposite.
netdhaka
Tue Jan 01, 2008 5:15 am
If you show your CR passport to the immigration officer in CR, they might want to see if you have the right to return to Switzerland and passthrough US on your way. In that case you will have to show them your Swiss pass. Showing the ticket agent one passport and the immigration officer another might not work. I know that it doesn't work in many (or some) countries.
andz
Tue Jan 01, 2008 11:03 am
I have South African and British passports and every time I check in internationally for a country that requires a visa for South Africans they ask to see my British passport too. If I was going to the USA would they only send the British information or both? By law I have to use my SA passport to leave and enter South Africa, only the airline asks for both.
AA7295
Tue Jan 01, 2008 1:11 pm
Australians are not required to enter or leave Australia using an Australian passport. They can use any passport as long as they can prove they are an Australian citizen, which may obviously be a difficult task.
(http://www.comlaw.gov.au/ComLaw/Legislation/ActCompilation1.nsf/framelodgmentattachments/F4CA038FAB9CE77BCA2573010017AF8F)
kiwiandrew
Tue Jan 01, 2008 5:26 pm
Quoting AA7295 (Reply 32):
interesting because I can recall when I was working in the travel industry in New Zealand an Australian in NZ on an NZ passport whose Aussie one had expired being denied boarding at AKL for a flight to Aussie because he tried to travel on his NZ passport rather than his Aussie one , from what I recall he had any number of Australian documents , ( drivers licence etc ) except his Aussie passport which had expired and was in the process of being renewed when a family emergency came up and he had to go home ( or at least tried to go home ) He was told quite emphatically at the time that if he is Australian he cannot enter Australia on any other document than an Australian passport - could you be a little more specific where exactly in the link you have provided the relevant info is - I did a quick scan of the 50-odd paragraphs and couldnt find it and I would be really interested to read it ( although it is several years to late to help the poor sod who was trying to make it back home in an emergency )
edited to add: sorry , re-reading my post I probably should have phrased that better - I want to make it perfectly clear that I am not doubting what you said in your post , I would just like a little friendly push in the right direction to the relevant section  Smile
[Edited 2008-01-01 09:30:30]
ALexeu
Tue Jan 01, 2008 7:15 pm
How many passports are we legaly allowed to have? I travel with 2 passports.
TusAadvantage
Tue Jan 01, 2008 7:29 pm
I travel with three passports (American, British, Australian) and I use which ever one allows me to stand in the shortest line. I've never had a problem, but I've always wondered if having triple citizenship is really legit in the eyes of the U.S. gov.
Tue Jan 01, 2008 9:26 pm
Quoting RootsAir (Reply 24):
= I was born to a Spanish-Venezuelan dad and British-Canadian mom in FL ...  Smile ... spent a lot of my formative years there.
Quoting AlexEU (Reply 34):
= Depends entirely on the country no?
N1120A
Thu Jan 03, 2008 12:18 am
As an American, as many as you get without renouncing your citizenship
Quoting TUSaadvantage (Reply 35):
It is.
MD11Engineer
Thu Jan 03, 2008 3:09 pm
Quoting N1120A (Reply 27):
Some countries would, if a person (especially a woman) would marry one of this countries citizens, automatically give the foreign spouse their citizenship.
Jan
ME AVN FAN
Thu Jan 03, 2008 5:53 pm
A) they are NOT interested in Costa Rican exit stamps
B) they have to accept your Swiss passport with all its rights
THIS however is an error. He can become Swiss nationality but will NOT lose his US nationality. And while tax-evasion is just an "offence" in Switzerland and is therefore usually NOT prosecuted police-wise, it is a crime in the USA, and whenever he travels into the USA he may very well be caught
ALexeu
Thu Jan 03, 2008 6:29 pm
You have to pay taxes in the country you live in, no matter how many citizenships you have. If you are registered in Geneva, you have to pay Swiss taxes not US.
MD11Engineer
Thu Jan 03, 2008 6:49 pm
Quoting AlexEU (Reply 40):
Only if there exists a double tax agreement. Some countries require you to pay tax, no matter where you live, so you can end up paying tax twice (the Philippines used to be like this).
Jan
ME AVN FAN
Fri Jan 04, 2008 7:37 am
THIS exactly is the position of Switzerland. US authorities however stay to the position that business conducted in the USA by a US-citizen is subject to US taxation, regardless of domicile and additional nationalities.
N1120A
Fri Jan 04, 2008 9:09 am
Quoting MD11Engineer (Reply 38):
Most countries, with the US being a notable exception, have this rule for men or women.
That is how it works pretty much everywhere except the US.
