jamesbaldwyn
Removed Cmos Battery - Now PC Acting Strangly
Sun Jan 20, 2008 10:44 pm
Hey
I've been faced with the classic 'BOOT DISC FAILURE..' etc crap and I thought taking the CMOS Battery out for a hour might help. (Desperate Stage Big grin ) And somehow, it worked. However, I'm having loads of strange problems. Such as MSN Complaining about my clock, windows updates not working etc. I've set the clock correctly and when I tell it to connect with the online server to update it comes back with an error.
Any ideas? I'm running Vista..
Thanks In Advance.
Go3Team
RE: Removed Cmos Battery - Now PC Acting Strangly
Mon Jan 21, 2008 1:37 am
You probably lost some settings in the BIOS. You'd probably have to go thru it and check the settings.
Yay Pudding!
Klaus
Mon Jan 21, 2008 1:39 am
Try rebooting. Just setting the clock graphically might not be enough - some internal services might still run on the "old" (nonsensical) time, so rebooting might re-synchronize them.
jamesbaldwyn
Mon Jan 21, 2008 7:25 am
Quoting Go3Team (Reply 1):
That sounds like that might do the trick; I'll try that later.
Cheers.
Quoting Klaus (Reply 2):
Computer has been rebooted and shut down for a long period of time.
AverageUser
Mon Jan 21, 2008 12:28 pm
Quoting Jamesbaldwyn (Thread starter):
The procedure then is to run the Setup manually (press DEL or F2, typically) at startup and go to "auto detect hard disk" or select "auto detection". No valid information there --> check cables and that drive makes some noise, if cables ok -> visit a facility that offers hard drives for sale.
jamesbaldwyn
Mon Jan 21, 2008 3:51 pm
Quoting AverageUser (Reply 4):
All 3 of my hard drives were identified in the BIOS. That being 2 Sata & 1 IDE. Somehow its all working, I think it may be my PSU so I'm replacing that.
I realised why I was having this problem with the clock.. I'm living in the past Big grin I set 2007 not 2008
Thanks everyone for your help.
AverageUser
Mon Jan 21, 2008 7:26 pm
Quoting Jamesbaldwyn (Reply 5):
I hope so too, having said that, I've seen quite a number of sporadic HD quirks that have fast developed into real HD failures so I suggest you make point of preparing a copy of anything you need to keep.
jamesbaldwyn
Mon Jan 21, 2008 8:22 pm
Quoting AverageUser (Reply 6):
I have 3 in my pc like I said earlier :
1 IDE = XP
Sata 1 = Vista
Sata 2 = Flight Sim & Backup
At the time, I was mixing and matching with no luck. So I don't think its the hardy drives.
AverageUser
Mon Jan 21, 2008 8:37 pm
Quoting Jamesbaldwyn (Reply 7):
If you have a major fault in the primary HD, the alternative boot device will be used, as defined in BIOS setup boot order. If you do not have a proper boot sector on the alternative HD, a fault in the primary HD will land you in a error message as you saw. A HD controller error is a possibility which I seldom see however.
flipdewaf
Tue Jan 22, 2008 9:24 am
Same thing happens if you remover the CMOS from my motherboard, There are a set of jumpers (not sure you call them that) that mean you can reset the BIOS to the default where it sets everything up automatically. On mine its a little plastic sleeve you remove from connecting two pins and then connect another 2pins to reset, then move back again.
Fred
ffis34
Tue Jan 22, 2008 3:46 pm
When you take that battery out the computers clock resets, and so programs wont run if the date of the computer is say 1989 and the program was made in 2000, If you sync your clock you will be good to go, you also might have to re activate windows again and do the updates. Maybe try running your Windows disk in repair mode that should help out a lot if their are some corrupt files and should help you against the disk failure screen again. It has happened to me. Just re sync the clock
Brad
hope this helps
AverageUser
Tue Jan 22, 2008 5:36 pm
Quoting Ffis34 (Reply 10):
Nothing personal, but everyone likes doing unnecessary things a lot when their HDs begin acting up. Sometimes the situation seems to improve (data gets rewritten, perhaps on a different physical sector on the HD, the drive may hide the actual operation, transparently), but in the end of the day a failing hard drive will be a failed hard drive.
ffis34
Tue Jan 22, 2008 11:22 pm
Quoting AverageUser (Reply 11):
I understand, but the "boot disk failure" could range from a corrupt file to what you said a future hard drive failure. But as I have just recently in the past 2 years ventured into computer repair, and I am always up for learning new stuff. But Having the same problem about 6 months back I did exactly as I described above and the problem was resolved, and after troublshooting the problem with my uncle it turned out to be a .sys file, So we ran the xp disc in xp repair mode probelm solved. But at the same time you could be very right about signs of a hard drive failure.
AverageUser
Wed Jan 23, 2008 1:47 am
Quoting Ffis34 (Reply 12):
Yes, I could be. The HD has it's build-in on-line self-diagnostics: S.M.A.R.T., the possible notifications of which you can enable at bootup from BIOS setup. I've saved many client's data by that "early warning system", when they've phoned me about a S.M.A.R.T. message they've got. The diagnostics message is enabled by default mostly on laptops only, I've noticed.
The smartmontools utility pack is available free at http://sourceforge.net/project/downl...ls-5.37-1.win32-setup.exe&83983089
The very pack is very informative about the hidden life of your hard drive, and very educational as well.
Happy computing  Smile
Users browsing this forum: aviationaware, L410Turbolet, scbriml and 2 guests
