mham001
Scientists Predicting Another Ice Age
Sun Feb 10, 2008 1:42 am
Global Cooling comes back in a big way
Dr. Kenneth Tapping is worried about the sun. Solar activity comes in regular cycles, but the latest one is refusing to start. Sunspots have all but vanished, and activity is suspiciously quiet. The last time this happened was 400 years ago -- and it signaled a solar event known as a "Maunder Minimum," along with the start of what we now call the "Little Ice Age."
Tapping, a solar researcher and project director for Canada's National Research Council, says it may be happening again.
.......Observational data seems to support the claims -- or doesn't contradict it, at least. According to data from Britain's Met Office, the earth has cooled very slightly since 1998. The Met Office says global warming "will pick up again shortly." Others aren't so sure.
http://www.dailytech.com/Solar+Activ...t+Another+Ice+Age/article10630.htm
RJdxer
RE: Scientists Predicting Another Ice Age
Sun Feb 10, 2008 2:27 am
Better put on your abestos suit, the globe around your computer is about to warm considerably.  flamed
Warm winds blowing, heating blue skies, and a road that goes forever. I'm going to Texas!
nighthawk
Sun Feb 10, 2008 3:13 am
so..............? what happened to global warming then?
Does this therefore prove that climate change is a result of sun cycles and not greenhouse gasses as previously thought? or is it time to fly more in order to stop the ice age?
AirTranTUS
Sun Feb 10, 2008 8:05 am
Damn. Is science proving theories wrong again? Better change the science to make it fit.
I love ASO!
Sun Feb 10, 2008 11:04 am
Out here in Mumbai its the coolest in 47 years.Quite weird around this time though to have such low temperatures.
regds
MEL
trekster
Sun Feb 10, 2008 11:20 am
This time last year half the uk was covered in snow. Past 2 days here in London we have had warmish weather, very strange.
Where does the time go???
Klaus
Sun Feb 10, 2008 11:24 am
By all means - stick to handpicked data points and totally avoid the conclusions scientists are drawing! Voluntary confusion is much move convenient for justifying complacency than actual analysis!  crazy
LH526
Crew
Sun Feb 10, 2008 12:07 pm
Hot .... Ice .... Hot .... Ice .... Hot .... Ice .... Hot .... Ice .... Hot .... Ice .... Hot .... Ice .... Hot .... Ice .... Hot .... Ice .... Hot .... Ice .... Hot .... Ice .... Hot .... Ice .... Hot .... Ice .... Hot .... Ice .... Hot .... Ice .... Hot .... Ice .... Hot .... Ice .... Hot .... Ice .... Hot .... Ice .... Hot .... Ice .... Hot .... Ice .... Hot .... Ice .... Hot .... Ice .... Hot .... Ice .... Hot .... Ice .... Hot .... Ice ....
C'mon Guys!!!!!
Trittst im Morgenrot daher, seh ich dich im Strahlenmeer ...
Sun Feb 10, 2008 12:12 pm
Quoting Trekster (Reply 5):
Agree, same here in Sweden.
baroque
Sun Feb 10, 2008 12:39 pm
Quoting B747forever (Reply 8):
I think that the guy who designs the weather has decided to use early 2008 to demonstrate the difference between weather and climate. Good luck to him/her. Others have failed.
David L
Sun Feb 10, 2008 1:35 pm
Quoting Baroque (Reply 9):
Is this weather or climate...
Quoting Mham001 (Thread starter):
kc135topboom
Sun Feb 10, 2008 1:45 pm
Hmmm, I need to go to Wal-Mart to buy new clothes. So does anyone know if it is getting hot before it gets cold? Or will it get cold before it gets hot?
I just want to know what to buy?
Quoting LH526 (Reply 7):
C'mon Guys!!!!!
 rotfl   rotfl   rotfl   rotfl   rotfl
nighthawk
Sun Feb 10, 2008 1:51 pm
Quoting Klaus (Reply 6):
instead shall we look at one report which says greenhouse gases are increasing, another which says global temperatures are increasing - then draw conclusions that the two must be linked?
Klaus
Sun Feb 10, 2008 2:11 pm
Quoting Nighthawk (Reply 12):
No. By themselves, two pieces of research are not enough to draw wide-ranging conclusions.
However when thousands of research results point consistently into the same direction with none or very few dissenting, that is an entirely different matter. And that is why the global community has decided to draw the consequences.
RobertNL070
Sun Feb 10, 2008 2:16 pm
Quoting Klaus (Reply 13):
 confused  Your otherwise excellent English has deserted you here.
Youth is a gift of nature. Age is a work of art.
Klaus
Sun Feb 10, 2008 2:31 pm
Quoting RobertNL070 (Reply 14):
Thank you... but where is the problem?
To clarify: The global community has decided to draw the necessary consequences from the current state of research.
David L
Sun Feb 10, 2008 3:39 pm
Quoting Klaus (Reply 15):
I suspect you mean "conclusions", not "consequences". To me, "drawing the consequences" implies getting what you deserve. Yes, it's nit-picking - we know what you meant.  Smile
Rara
Sun Feb 10, 2008 3:46 pm
Appearantly, the German "Konsequenzen ziehen", meaning "to act accordingly", can't be translated word by word into "to draw consequences". The latter seems to translate more to "Konsequenzen auf sich ziehen".
Interesting, I wouldn't have noticed it otherwise.
Samson was a biblical tough guy, but his dad Samsonite was even more of a hard case.
baroque
Sun Feb 10, 2008 3:50 pm
Quoting David L (Reply 16):
Interestingly while it is indeed a nit pick and your explanation David is 100% correct, there is another nit pick in the opposite sense. If GW is indeed being affected by [CO2], if we do not attempt to reduce the increase in [CO2] then we will suffer consequences rather than conclusions.  Big grin
nighthawk
Sun Feb 10, 2008 3:53 pm
theres no denying that global temperatures are increasing - theres no denying that greenhouse gasses are increasing. There is plenty of research to back this up. However there is NO proof that the two are linked. Its mearly speculation
Also bear in mind that the media likes to jump on "newsworthy" results - thousands of research papers could be written showing there will be no major changes in climate, and one single paper showing a drastic swing in global temperatures. Guess which one gets published and grabs everyones attention?
AverageUser
Sun Feb 10, 2008 4:09 pm
I naturally searched what Dr. Kenneth Tapping might have said, where and in which context. Someone asked him directly, and it appears another someone has put words into his mouth:
The stuff on the web came from a casual chat with someone who managed to misunderstand what I said and then put the result on the web, which is probably a big caution for me regarding the future.
It is true that the beginning of the next solar cycle is late, but not so late that we are getting worried, merely curious.
It is the opinion of scientists, including me, that global warming is a major issue, and that it might be too late to do anything about it already. If there is a cooling due to the solar activity cycle laying off for a bit, then the a period of solar cooling could be a much-needed respite giving us more time to attack the problem of greenhouse gases, with the caveat that if we do not, things will be far worse when things turn on again after a few decades. However, once again it is early days and we cannot at the moment conclude there is another minimum started.
Please feel free to quote what I said. I think it is a real shame that we sometimes see the downside of the freedom of the web, and that an investment journal would quote reports like that without going to their source.
http://scienceblogs.com/deltoid/2008...dont_trust_anything_you_read_i.php
We have the first solar cycle 24 sunspot spotted in Dec 2007, so everyone can now relax and take it easy.
http://sidc.oma.be/news/101/welcome.html
The prediction for the coming years:
Dec. 21, 2006: Evidence is mounting: the next solar cycle is going to be a big one.
Solar cycle 24, due to peak in 2010 or 2011 "looks like its going to be one of the most intense cycles since record-keeping began almost 400 years ago," says solar physicist David Hathaway of the Marshall Space Flight Center. He and colleague Robert Wilson presented this conclusion last week at the American Geophysical Union meeting in San Francisco.
http://science.nasa.gov/headlines/y2006/21dec_cycle24.htm
[Edited 2008-02-10 08:36:31]
PlymSpotter
Sun Feb 10, 2008 4:41 pm
If there was to be a complete lack of sunspots for many years then it is likely that the global temperatures would slip by a few degrees on average. This has happened before during an event called the 'Maunder Minimum' when only a handful of spots were recorded for decades. Normally though they operate on an 11 year cycle, so around about now we will be experiencing the minimum period so in five or six we should be back to the maximum again.
AverageUser
Sun Feb 10, 2008 5:17 pm
Quoting PlymSpotter (Reply 21):
Your scale is set badly wrong. "A change of a few degrees on average" is just a sort of disaster a fully-developed global warming would result in. There has been a minimum in the early 1800s that lasted for decades and did not result in such a dip.
Solar output during the Maunder Minimum was reduced approximately 0.25%, which is equivalent to a global temperature reduction of about ½°C; however, the actual temperature decline during the Little Ice Age was ½ to 1½°C (Nesje and Dahl 2000). This suggests that other factors, namely volcanism, were also at work to create cooler climatic conditions.
http://academic.emporia.edu/aberjame/ice/lec20/lec20.htm
AA777
Sun Feb 10, 2008 5:23 pm
Well if this is true, maybe our emission of greenhouse gasses and heating of the atmosphere will be counteracted by less solar activity.... lol.
-AA777
AverageUser
Sun Feb 10, 2008 5:33 pm
Quoting AA777 (Reply 23):
Or amplified by more, which can't be excluded.
PlymSpotter
Sun Feb 10, 2008 6:27 pm
Quoting AverageUser (Reply 22):
Not so much my scale as my wording - by that I mean one to two degrees, I should have phrased it better.
The Maunder Minimum to which I was referring took place from the mid 1600s to early 1700s, this was more severe and lasted much longer than the Dalton Minimum of the early 1800s to which you are referring there. I'm afraid I don't recall which journal I read this in, it was during some side research for a design project last Autumn, but it roughly mirrored your temperature decrease figures for the period in Europe, but suggested that changes to the North Atlantic Oscillation and Arctic Oscillation were more likely to have had a potential affect on the greater regional cooling at the time in some parts of the continent.
The exact relationship between a lack of sunspot activity, volcanic activity and, the little ice age is very much open to debate though. Yes you have several significant volcanic eruptions before this period of cooling and during it, but my uncertainties about the link are perhaps best documented by an eruption as it came to an 'end' (I say 'end' because the cool period has many different definitions as to it's duration) when Krakatua blew itself to bits in 1883. This eruption lowered the average global temperature by around 1 degree as a result of particles released into the atmosphere, but within five years they had returned to normal - so on that evidence how can volcanic activity can be attributed to any more than short 'pockets' of cooling around the major eruptions?
Dan
[Edited 2008-02-10 11:02:56]
Klaus
Sun Feb 10, 2008 6:58 pm
No offense taken... I've read the phrase so frequently over the years - with never a correction in sight - that I've never questioned it. That's definitely the value of corrections - exterminating mistakes before they start breeding...
In german there is a clear distinction between drawing conclusions and (in german) drawing consequences - the former is merely the intellectual acknowledgment, the latter includes taking action as a result of those conclusions. How would you express that same conceptual difference?
AverageUser
Sun Feb 10, 2008 7:03 pm
Quoting PlymSpotter (Reply 25):
No, it was your scale that was/is wrong not your wording. There's just no way our worldwide temperature can go up or down worth whole degrees in a matter of a few (sunspotless) years.
Krakatua blew itself to bits in 1883. This eruption lowered the average global temperature by around 1 degree as a result of particles into the atmosphere
The source I found says:
..Eruption large enough to produce wide-spread ash may be large enough to have climatic effects for 2 - 3 yrs
Examples:
Krakatau 1883, 0.5oC cooling
Few eruptions in 1930-40's or 1950-60's warm periods
El Chichon (1982, 7x104 m tons H2SO4) no cooling, coincided with El Niño
(Mass and Portman, 1989, Science 245:127)
Mt. Pinatubo (1991-92) 3 x 1011 g SO2 0.5 oC cooling
http://www.geo.arizona.edu/palynology/geos462/23climaros.html
PlymSpotter
Sun Feb 10, 2008 7:32 pm
Quoting AverageUser (Reply 27):
Sorry to be pedantic here, but in my original sentence I said 'many' not 'few' and, it was in reference to another long term event occurring like the Maunder Minimum, during which a lack of sunspots have been cited (depending on which sources you believe) as a reason why global temperatures fell. I am not trying to suggest that within the 11 year minimum/maximum cycle temperatures can drastically change by several degrees.
Examples:
Different sources give different figures - they vary greatly, some even suggesting that a decrease of 2 degrees or more was experienced after said eruption, which in my view is incorrect. Still though, your source states that the climatic affects of Krakatua were only felt for 2-3 years after the event, so that bears even less weight on your suggestion that volcanic eruptions can be the most significant cause of the little ice age - if I'm remembering correctly there were no more than ten major eruptions during the entire questionable period, most smaller than the aforementioned.
Dan Smile
AverageUser
Sun Feb 10, 2008 7:41 pm
Quoting Klaus (Reply 26):
I've read the phrase so frequently over the years .. that I've never questioned it.
That's the very reason why such phrases are called "false friends", you tend to use them without noticing. Every learner will fall for them some time.
bagpiper
Sun Feb 10, 2008 7:55 pm
So um... could you show where those *thousands* of research points for global warming are?
Klaus
Sun Feb 10, 2008 8:00 pm
Quoting AverageUser (Reply 29):
Indeed... and it's why corrections generally do more good than harm.
Expressions which are almost the same in different languages are the most dangerous ones. And apparently I just missed one of those.  cool
Klaus
Sun Feb 10, 2008 8:29 pm
Quoting Bagpiper (Reply 30):
Simply check the climatology research of the past decades. There are numerous peer-reviewed publications dedicated to the field.
AverageUser
Sun Feb 10, 2008 9:21 pm
Quoting PlymSpotter (Reply 28):
I'm sorry but you've just met your match in pedantry: your exact words were, to quote you from your post:
"If there was to be a complete lack of sunspots for many years then it is likely that the global temperatures would slip by a few degrees on average"
The problem with your sentence is the imprecision. "A few" in English is at least two degrees which is way too much given the historical evidence on sunspots we have. We can talk about a decade error.
Krakatua
It's traditionally written "Krakatau".
mham001
Sun Feb 10, 2008 9:29 pm
Quoting AverageUser (Reply 33):
Speaking of pedantic, a few refers to 3 or more. 2 is often called a couple. Also, he does not say if he is referring to Celsius or Fahrenheit which might produce a couple if not a few different interpretations.
PlymSpotter
Sun Feb 10, 2008 9:46 pm
I no longer seem to understand what you are getting at?
I already explained to you what I meant by the first comment you highlighted and, that I should have phrased it differently to represent what I actually meant:
Then you say that I have suggested temperatures will change 'in a matter of a few sunbspotless years':
I know that as well as you do I am sure, because I didn't say that they could go up or down in a 'few sunspotless years':
Note it says many and in the context of my argument I was relating it to a similar event to the Maunder Minimum, not few and, I even clarified it here:
So, before you continue to berate me for my 'imprecision', please took at the context and read what I have (already) written first?
Dan Smile
PlymSpotter
Sun Feb 10, 2008 9:51 pm
Quoting Mham001 (Reply 34):
Sorry, it is Celsius, I should have added that - in the UK just saying the temperature is 'xyz' degrees is associated with your meaning degrees Celsius, as that is the main scale used for measuring temperature and the one we see on our weather forecasts etc... so it is used the most.
Dan  Smile
foppishbum
Sun Feb 10, 2008 10:00 pm
Sounds like The Day After Tomorrow  Yeah sure
Taiwanese-American :D
Banco
Sun Feb 10, 2008 10:10 pm
If you are going to be pedantic, then in English it's traditionally written "Krakatoa" actually.  Wink
She's as nervous as a very small nun at a penguin shoot.
PlymSpotter
Sun Feb 10, 2008 10:39 pm
Quoting Banco (Reply 38):
I'm not going to say a thing - I was wrong on both accounts - but I freely admit that my spelling is poor  silly
dc9northwest
Sun Feb 10, 2008 11:44 pm
Yes. In Bahasa, it is Krakatau though  Wink
Banco
Sun Feb 10, 2008 11:58 pm
Quoting Dc9northwest (Reply 40):
And if that was the language he was writing in on here....  Wink
baroque
Mon Feb 11, 2008 2:59 am
Well IF we are going to get really picky, in Bahasa Inggris, it is written Krakatoa and pronounced "owe ah"
However in Bahasa Indonesia, it is Krakatau, and pronounced "ow" as in "ow that hurts".
So while the nits are being picked, Bahasa means language, not Indonesian. And if Krakatau were to explode again, it would be Anak Krakatau, the child of Krakatoa that blows up.
AverageUser
Mon Feb 11, 2008 2:28 pm
Not everyone agrees here, even on this relatively simple issue. I did not catch the specific "3" mentioned in any of my printed disctionaries.
a few(a): more than one but indefinitely small in number; "a few roses"; "a couple of roses" wordnet.princeton.edu/perl/webwn
Quoting PlymSpotter (Reply 35):
Yes, but even during in your specified context of the Maunder minimum we did not reach a one degree deviation.
RJdxer
Mon Feb 11, 2008 2:46 pm
Quoting Baroque (Reply 42):
 rotfl   rotfl   rotfl  Would that be "son" of Krakatoa?
Quoting AverageUser (Reply 43):
Then perhaps you should check in one of your printed "dictionaries"
one-being a single unit or thing
couple-an indefinite small number
few-not many persons or things
source:
http://www.merriam-webster.com/dictionary.htm
Not much snow in Finland? Come on over to the midwest. Several areas are about to set all time records for snowfall this winter season. International Falls is somewhere around 10-20 below zero F this morning.
wingnut767
Mon Feb 11, 2008 3:33 pm
Quoting RJdxer (Reply 44):
Come on AverageUser, There are plenty of Scandanavians in the upper Midwest. You will feel right at home on the lakes up there.  Wink
Yakum purkan min shmaya
agill
Mon Feb 11, 2008 3:35 pm
All this pedantic stuff, is it to prove that you all are annoying people or what is the point?  duck
AverageUser
Mon Feb 11, 2008 3:59 pm
ok, thank you: here's from it:
"few", adjective, sense 2: at least some but indeterminately small in number —used with a
again, turning to "some" from the same source we have:
adjective, sense 2a being one, a part, or an unspecified number of something (as a class or group) named or implied b: being of an unspecified amount or number
sense 4. being at least one —used to indicate that a logical proposition is asserted only of a subclass or certain members of the class denoted by the term which it modifies
In all, we see "a few" is a vague small (whole) number, not a definite "3 or more" as some say.
Online dictionaries say "anak" is "a child" as suggested above. Moreover, we know from Wikipedia: "A majority of Indonesian words that refer to people generally have a form that does not distinguish between the sexes. "
However, certain English and international naming conventions may have become established, even if they are not correct in the strict sense.
Unfortunately not, we had some snowfall last week, in fact a small blizzard. Its melting away though, it's 3.6 degrees C (above freezing) and I can see several patches of ground in our back yard.
No doubt fuelled by all that "unseasonally warm and humid" air that pushed its way northwards by the recent huge weather system. I think there was a thread alive just recently on this ... with some disturbing graphics on the recent sea ice development in and around the Arctic as well.
[Edited 2008-02-11 08:11:40]
baroque
Mon Feb 11, 2008 4:44 pm
Quoting AverageUser (Reply 47):
Correct AverageUser, anak is child and non specific for gender. Laki laki is a boy, and perempuan a girl. I am not sure about Finnish but I think you too do not have as many gender specific terms as English. In Indonesian toes are "foot fingers", I know that holds in Hungarian too, how about Finnish?
Moving from language to the Gunung Api (fire mountain) itself, it appears that while the effect of the dust lasted only a couple of years, the effect on the ocean may have lasted rather longer.
http://www.nature.com/nature/journal/v439/n7077/full/439675a.html
"Volcanoes and climate: Krakatoa's signature persists in the ocean
P. J. Gleckler1, T. M. L. Wigley2, B. D. Santer1, J. M. Gregory3,4, K. AchutaRao1 & K. E. Taylor1
Top of page
Abstract
This huge eruption slowed sea-level rise and ocean warming well into the following century.
Top of page
Abstract
We have analysed a suite of 12 state-of-the-art climate models and show that ocean warming and sea-level rise in the twentieth century were substantially reduced by the colossal eruption in 1883 of the volcano Krakatoa in the Sunda strait, Indonesia. Volcanically induced cooling of the ocean surface penetrated into deeper layers, where it persisted for decades after the event. This remarkable effect on oceanic thermal structure is longer lasting than has previously been suspected1 and is sufficient to offset a large fraction of ocean warming and sea-level rise caused by anthropogenic influences."
See also
http://www.nature.com/nature/journal/v438/n7064/abs/nature04237.html
For more you have to pay!!
RJdxer
Mon Feb 11, 2008 6:26 pm
Quoting Baroque (Reply 48):
 scratchchin  Some people have no sense of humor. As in Son of Kong, or Son of Frankenstien......
I see you left one and couple out of the mix. I don't know how it is in England or Australia, but here, if you say a "couple" you mean two. If you say "a few" the perception will be that there was more than one or two. If you say "many", the perception will be that there were more than a few, and a lot more than one or two.
Users browsing this forum: Baidu [Spider], Dt91c, OMP777X, PanHAM, salttee and 2 guests
