bristolflyer
BMW 5 Series Ceramic Heaters
Fri Feb 29, 2008 12:32 am
A few years ago I remember a big deal being made about BMW's new heater system that retains heat for a number of hrs for quicker cabin warm-up in cold climes. IIRC it had some sort of ceramic insulation material that was ultra effective at holding the heat for a long time.
Does anybody have any experience with this? Is it any good? Has it been used on other vehicles?
Just curious.
Fortune favours the brave
flight152
RE: BMW 5 Series Ceramic Heaters
Fri Feb 29, 2008 12:59 am
The system uses residual heat from the engine compartment, and blows it into the cabin compartment.
LOT767-300ER
Fri Feb 29, 2008 1:20 am
Quoting Flight152 (Reply 1):
Is the BMW system as stupid as the VW one? Where you have a water pump that heats the heater core for a period of I want to say 30-60 minutes after car has been turned off?
Just get a remote start and be over with it.
flight152
Fri Feb 29, 2008 1:31 am
Not really sure how well it works to be honest. My parents have it on their 530xi, but I don't think it has ever been used.
N1120A
Fri Feb 29, 2008 9:41 pm
I think most car heaters do that, don't they?
MCOflyer
Sat Mar 01, 2008 12:35 am
Quoting LOT767-300ER (Reply 2):
I could not agree more. It also warms up the engine and you loose the risk of your car stalling.
Hunter
bill142
Sat Mar 01, 2008 1:28 am
Quoting MCOflyer (Reply 5):
 redflag
I don't know about really cold climates, but in most conditions the whole letting the car warm up thing is BS.
avt007
Sat Mar 01, 2008 1:36 am
I like cars, and technology, but sometimes it gets out of hand. Just use a plain old heater core, so it doesn't cost $2,000 for a replacement. Gimmicks like that strike me as a fine idea until it fails, and now you've got an expensive, complex system to repair instead of a plain one.
LOT767-300ER
Sat Mar 01, 2008 1:38 am
Quoting Bill142 (Reply 6):
My friend the point is to heat the inside of the car up before going to work or school when the temperature is -20C so you dont freeze your ass off.
N1120A
Sat Mar 01, 2008 2:06 am
In modern cars, you are correct. In older cars, not so much. The issue, however, is that people need their cars to be warm before driving in really cold weather.
Quoting Avt007 (Reply 7):
I have never seen a BMW with a major HVAC problem.
planewasted
Sat Mar 01, 2008 2:44 am
I use anti-ecodriving when starting the car cold. That means, I use the first and second gear all the time until the car is warm and nice. To low gear = lots of friction heat into the engine cooling water. Takes maximum 2 minutes until I have lots of nice heat from my 65 hp engine.  Smile
scrubbsywg
Sat Mar 01, 2008 3:41 am
about 'not letting cars warm up', well, that is fine and dandy when it is warm but when you start the car and the temp gauge says -32C when you get in in the morning, i think its best to let it run for a few minutes.
BR715-A1-30
Sat Mar 01, 2008 5:08 am
Quoting PlaneWasted (Reply 10):
I could SMOKE you on the drag strip.. LOL  Silly I only got 130hp too...
Puhdiddle
LOT767-300ER
Sat Mar 01, 2008 5:12 am
Quoting BR715-A1-30 (Reply 12):
I could SMOKE you on the drag strip.. LOL I only got 130hp too...
Let the Go-Kart wars commence.
luv2cattlecall
Sat Mar 01, 2008 9:19 am
For quite some time, BMWs have had a "REST" button = residual heat, where it just blows air over the heater core dumping...residual heat...into your car. It may seem like a gimmick feature, but if you're just running into the mall for an hour or something, it's great. Keep in mind that most BMWs have a gigantic battery (in the trunk, opposite side of the driver, to counteract his/her weight since most of the time, it's only the driver in a car), so draining it isn't really an issue.
The newer ones have a "normal" heater core style heater, but some (mine is an '07 7 series, not sure about the rest) have a regular electric heater as well. Since the 7 has a V8 engine, it takes some time to warm up, so it's great having hot air right away. I think most portable heaters may be referred to as "ceramic heaters..." not sure on that though, but seeing as how the system is basically a portable heater stuffed into your HVAC system, that'd be what you're talking about.
TheSonntag
Sat Mar 01, 2008 11:48 am
Is this a special feature for colder regions? I do not think I have seen such a system in Germany for BMWs. The BMW of my parents has heated seats, thoug, thats cool as well...
Users browsing this forum: ChrisKen, Dutchy, L410Turbolet, ROSWELL41 and 2 guests
