jamesbuk
Computer Freezing Issue.
Wed Aug 20, 2008 8:52 pm
Hey guys and girls,
Got a problem with my computer. Basically every so often something on the computer will freeze, could be anything and its totally random.. sometimes its explore.exe, firefox etc etc.. so I do the normal control alt delete and click end task and go through the normal method there and nothing happens - the programme wont close. So I click processes and try to terminate it that way and again nothing will happen.
Ive had this problem since last night, I've tried a system restore and the problem has come back. Any ideas?
Regards, James
You cant have your cake and eat it... What the hells the point in having it then!!!
Dougloid
RE: Computer Freezing Issue.
Wed Aug 20, 2008 9:00 pm
If you're running Windows, I'd guess that ultimately the easiest way to clear this is to do an operating system reinstall. Rather than struggling with trying to troubleshoot an obscure problem, this may save you some time. Load your important files onto some CDs and off you go.
On the other hand, one thing about Windows is that if you, James, are having a particular problem, a bajillion other people have had that one too and are talking about it in newsgroups and chatboards. It makes troubleshooting a lot easier. Google your way home, what?
AverageUser
Thu Aug 21, 2008 3:36 am
So you have a one particular programme each time that will not close and the others will? You could have a malware infection, especially if that programme is a browser. I'd start by downloading Spybot and Ad-aware Free (remember to update the definitions after installation) and see how far the get and with what results.
bhmbaglock
Thu Aug 21, 2008 12:27 pm
Given the random nature of the problems you are having, the best bet is that you have defective or sub-standard memory in the machine. If you have more than one DIMM, remove all but one, run for a day or two, change DIMMs, etc. to see if you can isolate the problem. You can also find a memory tester program, that you can boot the computer to and it will check all of the memory at one time.
This could be a Windows installation problem, bad processor, or any of several other things as well but it really screams memory problem.
Before you do anything, check to make sure all of your firmware is up to date, that's another possibility.
Where are all of my respected members going?
jamesbuk
Thu Aug 21, 2008 12:42 pm
Dougloid - I tried searching google for a good hour and didnt get any similar results. Thanks anyway.
Quoting AverageUser (Reply 2):
Its not just a browser that freezes, like I said it could be any programme at any time.. its completely random.
Quoting BHMBAGLOCK (Reply 3):
Ok cool Ill try that, I did buy a new 1 gig stick about 5 weeks ago.. both have been running fine the whole time, they are the same mhz and memory size and I think same manufacturer.
Regards, James
Dougloid
Thu Aug 21, 2008 3:05 pm
Forgot about that. Good idea to get yourself a baseline. Microsoft has a nifty memory checking utility. There's a link here.
http://oca.microsoft.com/en/windiag.asp
Let us know how you make out with this turkey.
AverageUser
Thu Aug 21, 2008 5:42 pm
Quoting Jamesbuk (Reply 4):
Then it'll be your video card or subsystem, I'd say 80% of the time. The rest will be mainboard issues, bad memory is a very unlikely (but not quite impossible) since you do not receive any "segment fault" type of errors ever. Having said that, the best memory testing software I know with the least footprint is http://www.memtest86.com/ . You need to boot from a device, which you choose by downloading a particular version of the software, but then you'll have practically no interference from your OS.
Thu Aug 21, 2008 6:10 pm
If its XP......Use the System Restore.
Clean your Temp folders.
Carry out an Antivirus check.
regds
MEL
MYT332
Thu Aug 21, 2008 6:22 pm
Quoting Jamesbuk (Thread starter):
Hey guys and girls,
I think the problem here is that your computer is getting below zero degrees Celsius.
Try putting the computer in a room with a heater and see how it goes.
Regards.
One Life, Live it.
Dougloid
Thu Aug 21, 2008 8:48 pm
Quoting Myt332 (Reply 8):
Regards.
Another frackin' comedian....I love it.
 laughing   laughing
Users browsing this forum: BobPatterson, kitplane01, mad99, socalgeo and 1 guest
