United Airline
How Do Stabilizers On Ships Work?
Sun Oct 26, 2008 3:39 pm
How do stabilizers on ships work? Do they help a lot at rough seas?
Dreadnought
RE: How Do Stabilizers On Ships Work?
Sun Oct 26, 2008 3:56 pm
Quoting United Airline (Thread starter):
They are gyroscopically operated, and help mostly with roll caused by medium sized seas. Really rough seas will definately overwhelm their capabilities.
You have enemies? Good. That means you've stood up for something, sometime in your life. - W. Churchill
bristolflyer
Sun Oct 26, 2008 4:17 pm
I know of 2 different types of stabilizers. Firstly, fins that stick out from the sides of the hull (underneath the waterline). They slow the boat rolling by making it harder for the hull to move through the water.
The second one was very simple, but simple os good. I saw it on a large (about 80') motor yacht. It was a 1-ton weight on a rail inside the engine bay, the rail was mounted across the boat. I believe hat other than being able to lock the weight in position, it wasn't powered - it only ever rolled 'downhill'. So the boat would roll to port, the weight would roll that way and counteract the boat rolling back to starboard so quickly.
After writing this I did a wki search for you:
http://en.wikipedia.org/wiki/Ship_stabilizer
Fortune favours the brave
astuteman
Sun Oct 26, 2008 4:24 pm
Quoting BristolFlyer (Reply 2):
This is done with tanks of water on some bigger vessels, which are "tuned" to the natural frequency of the ship's motion......
Simple, and elegant..  Smile
United Airline
Sun Oct 26, 2008 6:28 pm
Any pictures of it?
I was on Oceania Insignia around Cape Horn and it was very rough.
If I was on Grand Princess, Freedom of the seas or bigger ships will it be more stable?
EMBQA
Sun Oct 26, 2008 6:56 pm
Quoting United Airline (Reply 4):
Any pictures of it?
There are several different designs. Most common look like stabilizers on a plane. They stick out of the hull and adjust to reduce the roll...
DocLightning
Sun Oct 26, 2008 7:04 pm
There are two basic kinds, as has been said here.
The first are a set of fins that stick out of the side of the hull. They simply change their angle of attack just like a plane's stabilizer to counter the roll. They can reduce the ship's roll to essentially nothing.
The second type is a pair of tanks of water with a high-speed pump that pumps water between them to balance the ship against rolling. I've been on this sort of ship, too, and they roll more, but it still takes the bite out of the roll. We were also doing the Drake Passage...
-Doc Lightning-
-Carl Sagan
PPVRA
Sun Oct 26, 2008 7:06 pm
Bigger will always help. Bigger + stabilizers even better.
"If goods do not cross borders, soldiers will" - Frederic Bastiat
Klaus
Sun Oct 26, 2008 7:16 pm
An image search has turned up these:
Extended:
Retracted:
skidmarks
Sun Oct 26, 2008 7:56 pm
Whatever they do I recommend a trip on the Ben my Cree from Heysham to Douglas in the Isle of Man in a force 8 gale. There you will feel exactly what stabilisers are incapable of!!! Big grin
And be very sick into the bargain!  vomit
Andy  old
Growing old is compulsory, growing up is optional
DocLightning
Sun Oct 26, 2008 8:07 pm
Quoting Skidmarks (Reply 9):
I made the Drake Passage without getting sick. Second day of the voyage I felt a bit "off" but I was faring a lot better than many of the Russian crew, who were walking into walls (admittedly at times the walls seemed more horizontal than the floors) and looking a bit green. Meanwhile, I just seem to be immune to motion sickness.
-Doc Lightning-
-Carl Sagan
MCOflyer
Sun Oct 26, 2008 8:28 pm
You can have whats called Paravane roll Stabilizers. Heres a photo of one:
http://www.tsb.gc.ca/en/reports/marine/1998/m98n0064/photo_1.jpg
Note the outriggers on the side of the boat. When one side goes down or up the other helps keep the boat level. Another form of stabilization is the sea gyro used for boats from 5-50meters. Heres more information:
http://www.abc.net.au/tv/newinventors/txt/s1415189.htm
Hope this helps,
Hunter
comorin
Sun Oct 26, 2008 9:37 pm
Even the biggest ships ( I was on the Monarch of The Seas), you can feel really tiny in a Hurricane! The force with which the ship smashes down on the waves, the groan of the steel beams, and the unsteady floors can be a truly terrifying experience even for hardened seamen. You keep waiting for the next wave, the bow of the ship rises, the rivets creak, and Bam!, the bow smashes into the trough, flooding the decks...it goes on interminably.
Stabilizers are great for damping rolling motion over normal range but are limited in their use in extreme pitching conditions.
DocLightning
Sun Oct 26, 2008 9:48 pm
Quoting Comorin (Reply 12):
And you sit there wondering if you're going to capsize or break in two.
-Doc Lightning-
-Carl Sagan
bristolflyer
Sun Oct 26, 2008 11:15 pm
Quoting MCOflyer (Reply 11):
Huh, I thought those were for spreading fishing nets wide. I did a search and they have fin-like devices that cut throught the water beneath them.
MCOflyer
Sun Oct 26, 2008 11:25 pm
Quoting BristolFlyer (Reply 14):
http://www.kastenmarine.com/roll_attenuation.htm
Scroll down about halfway and you'll see the word "paravanes."
Hunter
United Airline
Mon Oct 27, 2008 2:20 am
Quoting PPVRA (Reply 7):
How much of a difference between Grand Princess and Oceania Insignia at Cape Horn? It was really rough that time
PPVRA
Mon Oct 27, 2008 2:38 am
Quoting United Airline (Reply 16):
Grand Princess
Seems not very easy to find data on MS Insignia, though from pictures, Grand Princess is MUCH larger.
comorin
Mon Oct 27, 2008 2:43 am
Quoting DocLightning (Reply 13):
 yes
United Airline
Tue Oct 28, 2008 2:50 pm
Do stabilizers help a lot even in very rough conditions?
DocLightning
Tue Oct 28, 2008 6:02 pm
Quoting United Airline (Reply 19):
They decrease roll, which is the most uncomfortable motion just because of its frequency and magnitude. And they help a LOT. They do not, however, eliminate all sense of motion and they do nothing to decrease pitch.
But if a ship wants to pitch, let it pitch its heart content. It's roll that bugs me.
-Doc Lightning-
-Carl Sagan
United Airline
Wed Oct 29, 2008 2:20 am
Roll means left and right movements right?
sasd209
Wed Oct 29, 2008 6:26 am
Quoting United Airline (Reply 21):
Port and starboard, but yes. Through the longitudinal axis of the ship  Wink
Pitch is the fore and aft "up and down" motion of the vessel, usually as it encounters swells.
SASD209
vikkyvik
Wed Oct 29, 2008 6:38 am
Quoting Astuteman (Reply 3):
Believe many skyscrapers have similar water tanks or other weights on their roofs, that also dampen the natural swaying of the building.
That's what she said  duck
United Airline
Wed Oct 29, 2008 6:51 am
Up and down is ok. But left and right bothers me
astuteman
Wed Oct 29, 2008 7:10 am
Although size isn't everything....  Smile
Most modern cruise liners are inherently disadvantaged by having a large metacentric height as a result of the draught being limited (for access to shallower harbours), and the beam being greater (metacentric height is a function of, amongst other things, beam/draught.
A large metacentric height increases the righting moment exerted on the ship when it rolls from side-to-side, making the rolling "stiff" and uncomfortable.
That's one reason for the "popularity" of stabilisers, these days..  Smile
The older liners were much better in this respect.
Ironic, I suppose, that this very "stiffness" is actually a sign of inherent stability - the less stable, the easier the motion..  Smile
the rivets creak
Rivets?
In this day and age?
 faint   Smile
skidmarks
Wed Oct 29, 2008 7:26 am
Quoting Astuteman (Reply 25):
the rivets creak
Rivets?
Obviously he doesnt travel on the "right" sort of ship!! Big grin
Andy  old
DocLightning
Wed Oct 29, 2008 8:26 am
Quoting Vikkyvik (Reply 23):
Works a bit differently. Those weights are basically dampers that increase the mass of the building and this 1) lower its intrinsic frequency and 2) make it so that the wind has to push harder to move the building.
-Doc Lightning-
-Carl Sagan
Zkpilot
Wed Oct 29, 2008 12:53 pm
Try going on a Navy Frigate in the Southern Ocean at speed through 100ft ocean swells... the ship goes through the wave and is almost completely submerged before coming out the other side... My dad has done this many times and I've seen photos taken from a helicopter above of this.
No stabilisers however.
[Edited 2008-10-29 05:54:03]
57 types. 38 countries. 24 airlines.
sprout5199
Wed Oct 29, 2008 7:54 pm
Quoting DocLightning (Reply 20):
I would have to disagree. The ship I was(FFG), rolled quite a bit, but didn't get too many people sick, but when we pitched a lot most of the crew was green. We did have fin stabs, but they were broke most of the time.
Dan in Jupiter
MCOflyer
Thu Oct 30, 2008 1:05 am
Quoting Zkpilot (Reply 28):
I would like to pics of this.
Also, I know a couple who have a Sea Gyro on their vessel and love it.
http://www.seagyro.com/
Hunter
Zkpilot
Thu Oct 30, 2008 7:10 am
Quoting MCOflyer (Reply 30):
Its been a while since I've seen those pics... just tried to find them but no luck...
here are some other ones I have found online tho..
These waves are all much smaller than the example I was talking about earlier... but they are still good shots!  Smile
HMNZS Te Kaha (Frigate)
HMNZS Canterbury (Frigate retired)
HMNZS Waikato (Frigate retired)
HMNZS Te Kaha
Not sure... possibly HMS Jupiter or another RN frigate that may have been sold to RNZN
MarSciGuy
Thu Oct 30, 2008 10:19 pm
Any pictures of it?
As other posters have said, yes bigger does help to some extent, but being you have to take into account where you are in relation to the vessels CG as well...if your moment arm is increased enough on a large vessel you'll certainly feel it!.
I am a hydrographic surveyor and by definition (and contractual data quality obligation) we cannot survey in rough seas - (air under the xducer causing blowouts in the data meaning we are going ot have to re-do the survey lines anyhow) and I can tell you, especially from my last months' experience off of Delaware, that roll is predictable and can therefore be compensated for to some extent but unless you keep your body tensed up continually to compensate for the slamming sensation as the hull crashes into the next wave/swell, pitch can really suck! Though, on the flip side of the coin, roll empties shelves of supplies, even moderately weather-proofed shelves, all over the decks much quicker.
Quoting United Airline (Reply 24):
The last leg I was out (basically 4 of the last 5 weeks) I woke up several times from a dead sleep bracing myself and thinking rapidly about how I'd get out of the pitch black cabin I was in quickly and out onto deck if the roll I had woken up to continued what felt like only a few more degrees...though in reality it wasn't quite that bad, being in the trough of 8-10 ft swell on a 100' LOA mudboat makes you wonder every so often  Wink
"There weren't a ton of gnats there where a ton of gnats and their families as well!"
c172akula
Fri Oct 31, 2008 9:08 pm
Quoting DocLightning (Reply 10):
Another survivor of the 'Drake Shake', I did it in February of this year on the way down to Antarctica. Let that ship pitch all it wants, but the roll definitely had me feeling queasy, no problems when I could see outside though. The problem was in the halls and other areas you couldn't establish a point of reference.
On the way we hit a maximum roll on our trip of 60 degrees! Booya!
MarSciGuy
Fri Oct 31, 2008 11:01 pm
Quoting C172Akula (Reply 33):
WOW!!!!!!!!!!!!!!!! 60 degrees! Why were you heading for Antarctica?
MCOflyer
Sat Nov 01, 2008 12:59 am
Quoting Zkpilot (Reply 31):
The bottom photo looks like 30ft swells. Nice photos.
If I ever own a a trawler, a Sea Gyro is going to be on order for stability. This is the stabilizer is for small craft unlike big ships we have shown. However, stabilizers don't jack for for big waves like 40ft-60ft.
Hunter
Users browsing this forum: anshabhi, salttee and 1 guest
