Braybuddy
Belgian Travel Advice
Tue Jul 21, 2009 7:50 pm
I believe the bus shuttle service from Brussels South/Charleroi to Lille and Bruges/Brugge has been discontinued since April. What ways would you recommend travelling to the former and from the latter? Or would it be better to do it the other way round?
Any help here would be appreciated.
Scorpio
RE: Belgian Travel Advice
Tue Jul 21, 2009 8:15 pm
You can take the train. There's a bus that runs between the airport and the railway station. From Charleroi-Sud railway station there's a direct train to Lille every hour. To / from Bruges you have to change trains once (in Brussels South railway station), and there's a connection every half hour. If I'm not mistaken (it's been a while since I took a plane at Charleroi) you can buy a ticket that counts for both the bus and the train service.
You can look at the schedules of trains here: http://www.b-rail.be/main/E/index.php
Braybuddy
Tue Jul 21, 2009 9:59 pm
Great stuff, and thanks for your help Scorpio. One more question, seeing that I'm familiar with the Ryanair bus service from the rue de France, do you think it would be better taking that to the airport rather than the train, given that you have to get a bus at Charelroi station to the airport?
Scorpio
Tue Jul 21, 2009 10:53 pm
I'm not familiar with the Ryanair bus service quite honestly, so can't help you there. Though the bus from Charleroi station to the airport is easy to find and clearly marked, and I believe it's timed to connect nicely to the train coming from Brussels.
Braybuddy
Wed Jul 22, 2009 2:36 pm
Quoting Scorpio (Reply 3):
Great! Thank you. Probably a better option given that the shuttle bus doesn't operate to a precise timetable.
BrusselsSouth
Wed Jul 22, 2009 7:38 pm
Hi,
Quoting Braybuddy (Reply 4):
Never used the shuttle, but Charleroi Airport website seems to publish a timetable :
http://www.charleroi-airport.com/doc.php?nd=1101&tid=101&site=1&lg=2
Might be a fast option during July/August when the traffic around Brussels is weak.
If you want to travel by train, you'll find all the timetables on the site linked by Scorpio :
It's indeed easy and relatively cheap to go from Charleroi-Sud train station to the airport and vice-versa (bus "A" with a plane symbol and "Aéroport" direction sign).
Let me know if you need some specific info, as a "local", I'd be glad to help.
BrusselsSouth
Braybuddy
Wed Jul 22, 2009 8:37 pm
Quoting BrusselsSouth (Reply 5):
Looking at Google Maps, I see there are a few stations in Charleroi, with lines radiating in different directions. Which station(s) do I need for mainline services to Lille or Bruges?
Taking-in the two cities starting from CRL, what way (and order) would you suggest, or does it make little or no difference?
BrusselsSouth
Thu Jul 23, 2009 5:13 am
Quoting Braybuddy (Reply 6):
You should use Charleroi-Sud station (Sud means South), which is the main station in Charleroi, and the only one where every passenger train stops. It is also the starting point of the 'A' bus line, connecting the station with the airport.
I've just had a look a the 'A' bus timetable :
Airport to Station :
Monday to Friday : 2 bus per hour  Smile20 and :50)
Weekends and official holidays : 1 per hour  Smile40)
Station to Airport :
Monday to Friday : 2 bus per hour  Smile15 and :45)
Weekends and official holidays : 1 per hour  Smile05)
The journey between the airport and station (and vice-versa) lasts approximately 20 minutes.
It's just a matter of personal preference, really. Just keep in mind that there are no direct trains between Bruges and Charleroi (connection at Brussels), while there are direct trains between Lille and Bruges and between Charleroi and Lille.
You'll find PDF timetables here :
http://hari.b-holding.be/Hafas/folders/20081214/G/Lst.htm
Click on the 'F' (French) or 'N' (Dutch) icon next to a line to get the PDF :
- Charleroi - Lille : Line 78
- Lille - Bruges : Line 75
- Charleroi - Brussels : Line 124
By the way, be careful : timetables with a grey 'A' watermark are for Monday to Friday, while those with a 'C' watermark are for weekends and holidays.
Hope this helps. Again, feel free to ask any question you might have.
BrusselsSouth
teahan
Thu Jul 23, 2009 7:31 am
I think it's much easier to just use the Belgian railways English language journey planner:
Goodbye SR-LX MD-11 / 6th of March 1991 to the 31st of October 2004
Braybuddy
Thu Jul 23, 2009 2:17 pm
Quoting BrusselsSouth (Reply 7):
Looks like I have all the information I need now, thanks to all who posted. Who needs the Lonely Planet when you have all the local info just a keystroke away on here?
Merci!
