ManuCH
Crew
Pee In The Shower To Save The Rain Forests
Mon Aug 24, 2009 8:41 am
A funny campaign by a Brazilian environmental group:
The group believes that by adding a yellow stream to the morning's shower, one toilet flush can be prevented. If one flush is avoided each day in a single household, 4,380 liters (1,157 gallons) of water is saved per year.
http://www.mnn.com/the-home/househol...ucts/blogs/the-girl-from-impeenema
What do you think? In my opinion, while funny, this is yet another useless campaign made by people who believe too much in statistics... what happens if people take this too literally? Maybe those who usually don't shower daily (not everyone does) will start doing so, only to be able to follow the campaign's recommendations. And there goes the water saving...  Silly
Never trust a statistic you didn't fake yourself
Type-Rated
RE: Pee In The Shower To Save The Rain Forests
Mon Aug 24, 2009 9:05 am
Yuck. And what about the people who don't scub the floor of their tub or shower on a regular basis. Does your shower begin to smell like urine? Who wants urine around their feet?
Fly North Central Airlines..The route of the Northliners!
Aeri28
Mon Aug 24, 2009 9:24 am
every man pees in the shower,or at least has done so. Not every man will admit to it as I'm sure the ensuing posts will prove. If you say you don't or have not, you are lying.  Big grin  Big grin It's akin to not admitting you never have or never have had a finger up your nose in the privacy of youself.
Superfly
Mon Aug 24, 2009 9:26 am
Quoting ManuCH (Thread starter):
What do you think?
I'd have to have a Golden Shower with the girl from Ipanema before I make up my mind.  Smile
Seriously, these environmentalist are insane!
So in other words, urinate where you bathe yourself all in an effort to save the environment.
Poor hygiene is a sign of mental illness, but hey it's all about the environment.  Yeah sure
Bring back the Concorde
MD11Engineer
Mon Aug 24, 2009 9:36 am
The problem is that water is unevenly distributed on our planet. E.g. North-Western Europe gets more than it´s share of rain and water is normally not a problem (the water shortages in the UK a few years ago were not caused by the lack of rain, but by the lack of investment into maintenance and upkeep of the distribution systems by the water companies after privatisation).
Other places have a lack of water, e.g. the Sahel zone.
But saving a toilet flush e.g. in rainy Ireland won´t help a farmer in Burkina Faso.
It reminds me of the stories we had to listen to as children about emptying oiur dinner plates and not to throw away any food "because in Africa children are starving". Me finishing an overfull plate (filled by the grandma) would not have saved a child over there. I already noticed the lack of logic when I was five years old.
Jan
Mon Aug 24, 2009 9:57 am
Gross... But I guess it happens in hotels and airport lounge showers etc... But Id rather not think about it .
Quoting MD11Engineer (Reply 4):
Rainy Ireland ? Its been flooding it down and yesterday it was like monsoon !! I was thinking if only I could send it over to Athens to put out the fires.
MD11Engineer
Mon Aug 24, 2009 10:31 am
Another point is that the existing water and sewage systems require a minimum flow rate. If this is not reached the drinking water will not flow fast enough through the pipes and the water works can´t guarantee the sterility of the drinking water. Also the faeces will get stuck and dry up in the sewage pipes insted of being transported to the sewage treatment plant.
Since massive water saving started years ago (mainly due to people taking short showers imnstead of full baths or using toilet flush boxes with a low quantity button for No.1), both the water works and the sewage works have to flush their pipes regularly. This is wasting water.
Jan
jush
Mon Aug 24, 2009 10:40 am
Quoting MD11Engineer (Reply 6):
While your post is correct the last statement is not. They have to clean their pipes but they'll do it with cleaning machines that use the flowing water around them. Normally there is no need to waste fresh, clean water in that process.
Still saving water is not always the best option for the system.
I have another thing to think about. If your shower lasts longer because you are doing Nr. 1
in it you use considerably more water than if you just have a short shower and a little flush with the toilet.
Regds
jush
There is one problem with airbus. Though their products are engineering marvels they lack passion, completely.
MD11Engineer
Mon Aug 24, 2009 10:54 am
Quoting Jush (Reply 7):
Regds
jush
Not correct. Flushing the drinking water system is usually done by hookuing up a fire hose to a fire hydrant (which are connected to the drinking water system) and running the water into a street gulley or manhole (which at the same time flushes the sewage system).
What you mean is the cleaning done to remove caked dirt and obstructions from the sewage pipes. This is done using a high pressure washer with a special head ("Pipe rocket") at the end of a long hose. Again, this machine (mounted on a truck) uses drinking water.
For regular flushing the fire hydrant / fire hose method is being used.
Jan
DocLightning
Mon Aug 24, 2009 3:48 pm
Quoting Type-Rated (Reply 1):
Um. It's urine, which is an aqueous solution. Thus, if you pee in a working shower, the urine is dispersed in the water and disappears completely down the drain.
-Doc Lightning-
-Carl Sagan
baroque
Mon Aug 24, 2009 3:58 pm
Quoting DocLightning (Reply 9):
You like me are a bit puzzled at these dry showers apparently being taken in some parts of the world.  Confused
Indeed, Jan, water saving has been a problem with blocking in our sewers too.
 splat
dxing
Mon Aug 24, 2009 5:18 pm
Not to mention if you are in the shower, aren't you supposed to be using some sort of soap? If you are using a public facility, like at a camp ground, and not using some sort of footwear, what are you thinking?
Heck, there are people that tube a couple of nearby Texas rivers that will drink a six pack or more of beer during an afternoon and not get out of the river once to hit the head. I envy their bladders!
Warm winds blowing, heating blue skies, a road that goes forever, I'm going to Texas!
Revelation
Mon Aug 24, 2009 5:59 pm
It'd save lots of water to have the return of the privvy, complete with stacks of junk mail to wipe your bum. Kills two birds with one stone!
Inspiration, move me brightly! Light the song with sense and color.
Hold away despair, more than this I will not ask.
Faced with mysteries dark and vast, statements just seem vain at last.
Some rise, some fall, some climb, to get to Terrapin!
Rara
Mon Aug 24, 2009 7:51 pm
I have to deal with stuff like that on a regular basis... my company works with several environmental campaigns. Some are quite good, others are mindnumbingly stupid.
The other day, somebody came up with the slogan "wouldn't it be great if everyone used electricity from renewable sources?" No shit, Einstein. Because that's totally possible in the year 2009.
It's on the campaign website now.  banghead
Samson was a biblical tough guy, but his dad Samsonite was even more of a hard case.
FlyDeltaJets87
Mon Aug 24, 2009 8:28 pm
Quoting DXing (Reply 11):
Classic Ron White routine!  biggrin
Quoting Aeri28 (Reply 2):
Just like masturbating. 80% of men admit to masturbation. The other 20% are liars.  wink
"Let's Roll"- Todd Beamer, United Airlines Flight 93, Sept. 11, 2001
canoecarrier
Mon Aug 24, 2009 8:52 pm
I've never seen this as a problem operationally though. Every treatment plant I've ever worked on is well over the minimum amount to run. I could see this being more of an issue on a smaller scale plant that services 100 units or so.
Ah, the dilution is the solution to pollution argument  Smile
Really, why not just build a better plant that includes secondary treatment with filtration and a higher level disinfection (like a UV-light disinfection) and use it to flush the toilets? You'd be surprised the things you can use reclaimed water for without having to pee in the shower. I'll still wear sandals though when I use a campground shower. People pee in those all the time.
The beatings will continue until morale improves
fruitbat
Mon Aug 24, 2009 9:06 pm
This may be of interest....
http://www.guardian.co.uk/lifeandsty...2009/aug/06/peeing-in-shower-rules
Love the idea of having etiquette rules for such a topic Big grin
Weaseling out of things is important to learn. It's what separates us from the animals ... except the weasel.
YVRLTN
Mon Aug 24, 2009 9:26 pm
I guess if you dont wipe your ass, you save paper and the rain forests..... oh wait, then you waste more water cleaning your undies...
Follow me on twitter for YVR movements @vernonYVR
A332
Tue Aug 25, 2009 3:44 pm
Everyone is peeing in the shower already anyway, just no one is willing to admit it. We really won't be saving any significant amount of water when the few 'hold-outs' actually catch on to the idea... it's a moot point.
Peeing in the shower... peeing in the pool/hot tub/lake/river... it's already happening.  Wink
Bad spellers of the world... UNTIE!
DocLightning
Tue Aug 25, 2009 8:05 pm
Quoting FlyDeltaJets87 (Reply 14):
There is the 0.03% who have no hands...  Wink
-Doc Lightning-
-Carl Sagan
dragon-wings
Tue Aug 25, 2009 8:38 pm
The second I saw this thread I thought of the Seinfeld episode where George peed in the shower and yells It's all pipes!!  laughing
Don't give up don't ever give up - Jim Valvano
falstaff
Tue Aug 25, 2009 8:40 pm
I have done it many times. Too many to count really...
 checkmark   checkmark   checkmark
There are those that do it and those that lie about it.
Quoting DocLightning (Reply 19):
I am sure they figured out a way to do it!
My mug slaketh over on Falstaff N503
globeex
Tue Aug 25, 2009 8:54 pm
Well done Einstein!!!...... I was four!  Big grin Naa, but you are right. =)
Well, you could apply the sampoo while doing No.1. So maybe (as everyone is doing it already) their slogan should be "ALREADY APPLY THE SHAMPOO WHILE PEEING IN THE SHOWER, IT WILL SAVE MORE THAN 4000L PER YEAR!"
Who said I'm a liar!  Wink
Quoting YVRLTN (Reply 17):
Unfortunately most of the people who don't speak German won't understand what he is talking about.
http://www.youtube.com/watch?v=s1pO3...aynext=1&playnext_from=PL&index=20
for those how don't speak German, I will translate: He first asks her how much toilette paper she needs for a No. 2. Than she shows him the amount, and then he explains her how to do it with one sheet. haha
GlobeEx
As you may presently yourself be fully made aware of, my grammar sucks.
kalakaua
Tue Aug 25, 2009 8:55 pm
I pee a lot everyday, because I drinks lots and lots of water. I only flush when my pee is yellow.
Gravity explains the motions of the planets, but it cannot explain who set the planets in motion.
fruitbat
Tue Aug 25, 2009 9:12 pm
Quoting Kalakaua (Reply 23):
Reminds me of the water saving advice:
"If it's yellow, let it mellow; if it's brown, flush it down"
I'll get my coat.........
 embarrassed
AmricanShamrok
Tue Aug 25, 2009 10:09 pm
Quoting OA260 (Reply 5):
Hear hear Big grin don't talk to us Irish about saving water!
mham001
Wed Aug 26, 2009 1:40 am
A good majority of the women I've showered with do it with no shame. I don't see the problem, urine from a healthy person is sterile.
afterburner
Wed Aug 26, 2009 5:12 am
Well, he's a doctor and doctors know about hygiene more than most people. Whenever I need to pee while I'm showering, I just pee.  Smile
LTU932
Wed Aug 26, 2009 5:20 am
Quoting GlobeEx (Reply 22):
That just reminded me of a bad blonde joke: Why is a blone woman walking around in the shower all the time? Because the shampoo bottle says "Wash n Go". (German original version: Warum läuft eine Blondine in der Dusche hin und her? Weil auf der Shampooflasche "Wash n Go" steht).
[Edited 2009-08-25 22:38:14]
TUNisia
Wed Aug 26, 2009 5:28 am
When we recently renovated our new home we installed a waterless (no-flush) urinal in the guest bathroom downstairs.
http://www.us.kohler.com/onlinecatalog/waterlessurinal.jsp
Users browsing this forum: E2, StlHsvSfoSan and 4 guests
