mt99
Car Scheduled "Maintenance"
Wed Sep 16, 2009 2:01 pm
So I take my 2007 Jetta to the dealer because one of the tail lights is burnt. I know oil change is coming up and the scheduled 20K Miles service is coming in about 1,500miles - so i inform the gentleman to go ahead and perform these services.
So i drop it off this morning. Turns out that the 20k mile mark is the "intermediate service" which cost about $500.
One part of the engineer in me thinks that all the fluid “flushes” and "checks" they do are useless – but the other engineering part of me understands that things do break down, and things need to be maintained properly.
Luckily its not breaking the bank - but i was still quite shocked.
I think you have to do it anyways to keep the warranty alive – at least that’s what I am trying to comfort myself.
On the good side - they will replace the light bulb for free.
Do you guys follow maintenance by the book?
Step into my office, baby
ShyFlyer
RE: Car Scheduled "Maintenance"
Wed Sep 16, 2009 2:10 pm
Quoting Mt99 (Thread starter):
About the only item I looked up in the owner's manual on my vehicle is the oil change interval, which is 5000 miles in my case. Everything else I inspect, change, replace based on my own observations.
sv7887
Wed Sep 16, 2009 2:14 pm
It's mostly a racket. They overprice the hell out of basic services, and I've seen VW and other carmarker's actual cost vs price list so I can tell you that for sure. Even Toyota has started the same deal, I remember them charging $80 for a basic oil change. They just packaged it as a "service." For a Lexus it was well over $100 a few years ago.
At 20K miles you really shouldn't need much. Maybe coolant flush? Most cars these days have "Long Life" fluids, so you shouldn't have to change them so early. (The flip side is that the automaker pitches them as "Lifetime" fluids, and then the customer wonders why they suffer severe mechanical breakdowns at 100K miles)
You should have seen my face when they told me a basic oil change on my Mercedes is $300. The sad thing is that this car has 6,000 miles on it and apparently needs "inspections." The key is to find a trusted mechanic that will do the work for you. I got my oil change done for $120 at a well known independent mechanic for a full synthetic oil change.
Flighty
Wed Sep 16, 2009 2:17 pm
Maintaining a new car is generally cheap. A Jetta needs oil changes and maybe a spark plug change at some point. Inspections and so-on should be based on your level of concern. To me it is not worth some $500 to get inspections for items I could do myself, or am not worried about. Alternatively, since it is under warranty you could simply ask them to check your items of concern for no cost, since that is their obligation under the terms of warranty. Checking brake fluid levels, etc is generally a joke, in temrs of easy / not necessary with a new car.
Most of the time, these "maintenance programs" are inflated in cost by about 300% so dealers can make several thousand dollars per car without actually repairing anything except perhaps an air filter every 40,000 miles and some spark plugs every 60,000, which total about twenty minutes of work. If you are actually interested in maintenance, the factory program may neglect certain areas such as transmission fluid. Overall I would relax and change the fluids, the spark plugs and not worry about the rest. Save your money for later on, when things break and the warranty does not help you.
ANITIX87
Wed Sep 16, 2009 3:02 pm
Quoting Sv7887 (Reply 2):
Wow! My oil changes (with full synthetic) cost me $34.27 here in New York. Regardless of the car! Even what you paid seems bonkers to me...
As for servicing, my dad and I tend to take care of our cars like they are little babies. We may not drive them like they are, but when it comes to knowing when something is wrong, we're like hawks. We have a 1992 Mazda MPV van with 180,000 miles on it that runs like the day we bought it (has had new belts and stuff installed, but nothing major at all), and a 1999 Honda Accord V6 with 165,000 miles on it that just recently got new shocks and struts installed, and that was the most expensive repair it has had done to it ($400 dollars). My car is a 2000 Ford Focus ZX3 with 56,000 miles on it, and this is the car that has had the "most" problems (most being a relative term in my family's case) mainly because it is an American car. I have had to replace brakes and tires, obviously, the front shocks, springs, and struts ($580), the timing belt ($300), the starter switch ($110), the windshield/body join panel ($75, to avoid leaks into the passenger compartment during rain), and that's IT. All the electronics work just fine, and I've never had to replace a bulb or anything. Recently it has started making a burning smell when I come off the highway or drive really hard, so I need to get that looked at...
Basically, if you know what you are doing even a little bit and take care of your car, and know a good mechanic for when things DO go wrong, there's no reason to pay for all those service fees. My dad did the first scheduled service on the Honda and decided it wasn't worth it. Hasn't done one since. Just treat your car as if it's a complex machine (which it IS) and read up a bit on how to recognize problems before they become major and there's no reason to spend thousands of dollars over your car's lifetime.
Sorry for the long post. Just my two cents (maybe more after inflation since it took me so long to write...)
TIS
sv7887
Wed Sep 16, 2009 3:08 pm
Quoting ANITIX87 (Reply 4):
Wow that is cheap!!!! Even a Mobil 1 Oil Change at the local gas station is nearly $60. The sad thing is that people who take their cars to the Benz dealer pay $300 as if it is the most normal thing in the world. All for a glorified oil change.
Before I turned in my last E class it needed a "C" Service, meaning it was close to 20K miles. they wanted $650 to change the brake fluid, oil, and perhaps the air filter. And it isn't limited to the German cars, as my Lexus was horrendous. I never left the dealer with a bill less than a few hundred dollars. Towards the end when it got to around 100K miles, I was seeing $700+ bills every six months.
I am glad I found a good independent mechanic for my current car because this was starting to get insane. That said, I admit these luxury cars are probably the worst financial investment you can ever make.
AM744
Wed Sep 16, 2009 3:21 pm
I do and so far it's worked. But I share your feelings, specially now that my car is a 2004 make and some issues not covered (and certainly not detected) by the maintenance program, like a dead battery, 'position' sensor and other electric parts have arisen in the last couple of months. I'm expecting the clutch and dampers to be dead in the short to medium term and those guys in the dealership know nothing about prevention, so I'm considering taking the car with an independent mechanic from now on. Problem will be finding a trustworthy one.
BTW. Is there a way to know if a clutch (manual shift) is past it's lifetime without serious disassembling?
ManuCH
Head Moderator
Wed Sep 16, 2009 3:31 pm
Yes, always. If you don't, the resale value goes down. It's the first time they check when buying a used car.
Never trust a statistic you didn't fake yourself
ANITIX87
Wed Sep 16, 2009 5:06 pm
Quoting Sv7887 (Reply 5):
Wow, I didn't know Mobile was that much! Where I go, you pay the 35 dollars I quoted above, and you even get a free car wash! They do it in about 12 minutes while you wait. Very nice.
Quoting AM744 (Reply 6):
It depends. If you're talking about the clutch, try starting from a stop in the highest gear. If it moves without stalling, the clutch is slipping and needs replacement. This is, of course, if the clutch is in horrible, horrible shape. As for whether gears or synchros are in need of repair, you could try floating gears. If it doesn't work like it should, it could be a bad sign in regards to the synchros, or gear meshing. But don't quote me on any of that. If you really think there is a problem, take the car to a mechanic you trust.
TIS
Sabena332
Wed Sep 16, 2009 5:13 pm
Yes, always! And of course must the maintenance be done at an Audi dealer (in my case) and not at some backyard garage.
Quoting ManuCH (Reply 7):
Exactly!
Patrick
mt99
Wed Sep 16, 2009 5:24 pm
Quoting Sabena332 (Reply 9):
But this is what makes me doubt. I just got a call from the dealer..
" the guys found some sporadic misfiring in the cylinders - not enough to light up the check engine light. We recommend the "fuel service" (for $200) This should had been done at 15k miles but we missed it"
Note that i saw an advertisement on the wall this morning about this "fuel service" and explaining why you should get it. So i don't think its really required - if it was it wouldn't had been "missed" at 15k.
So i told him that he should go "service" himself.
PS. The other tail light bulb as about to blow to. So they will kindly replace it - for $3
Cadet57
Wed Sep 16, 2009 5:26 pm
Isnt the first 36k miles free service wise? Last I checked it was.
Nope. Not with a new, or in my case, pre owned VW. You can do the service yourself. They dont care, atleast my dealer diddnt.
Yes, partly because my father taught me just about everything he knows about cars, and two, my car is a finicky german wench when she is not working properly
That all being said, once my car was out of warranty, I stopped taking it to the dealer. Overpriced and crappy service. The sales manager steered me towards an independent guy about two blocks from the dealer, he is half of what the dealer charges for labor and he uses all VW parts. The guy has been in business since the 70's and all he services is VW and Audi, the guy is awesome. I recommend you do the same and find a good local mechanic who knows VW. You do NOT have to go to the dealer to keep your warranty. The only time you need to take it there is for warranty work, but for basic stuff, save alot of money and find a local shop.
VW G-12 coolant, last time I looked was rated to atleast 100k before it needed changing.
JBirdAV8r
Wed Sep 16, 2009 6:35 pm
Mt99,
Wow! I'm glad I didn't buy a Volkswagen. I've taken my Acura to the dealer for every service, and I've never paid more than $70 for an oil change--and that includes tire rotation/balance, a "courtesy inspection" and a car wash.
Quoting Mt99 (Reply 10):
Wonder how you "find" sporadic misfiring unless you're chugging and lurching down the highway, lol. A $3 bottle of fuel injector cleaner ought to do you nicely.
 checkmark  Good move.
I just had my fluids changed (again at the Acura dealer) and it cost me $275--plus they gave me a loaner car for the day. Wow. And yeah, the engineer in me would agree with you that it's probably not all that necessary, but in most circumstances can't hurt. Except I wouldn't have just anyone change especially my transmission fluid--I have that changed rarely because it can be a Bad Thing if someone doesn't know what they're doing.
Cadet57
Wed Sep 16, 2009 6:38 pm
Quoting JBirdAV8r (Reply 12):
Thats an ignorant comment.
Id have told him where to stick that "fuel service" as well. Again, VW service is a absolute rip off, see my advice in reply 11.
JBirdAV8r
Wed Sep 16, 2009 6:43 pm
Quoting Cadet57 (Reply 13):
No, it's actually well-researched. I am glad I didn't buy a VW...for more reasons than just the OP's problems. I know your feelings on VW...it wasn't a personal attack, honest  Wink
All the Puebla-built cars I've seen have been absolute junk in terms of reliability. Sure, my Acura may be a soulless Japanese boat, but at least I'm not worried about it falling apart doing 70 down the highway...
andz
Wed Sep 16, 2009 6:54 pm
Absolutely. My BMW has 100,000km maintenance included so if I miss one it's invalid.
HAJFlyer
Wed Sep 16, 2009 6:59 pm
In Switzerland most premium and semi-premium brands (e.g. BMW, Audi, Mercedes, Volvo, Saab, ....) offer free scheduled maintenance for up to 100'000 km or 10 years (whatever comes first); during the first three years the parts are included as well. Even the first 6 wheel changes (switch from summer to winter wheels and back) are free.
It is a great loyalty tool that has you coming back to the dealer. One additional benefit for the importer is that is curbs parallel imports as only cars distributed through the official dealer network enjoy these privileges.
So, yes my 09 BMW 318i will be serviced for the dealer - with who I am very satisfied - for quite some time to come.
mt99
Wed Sep 16, 2009 7:10 pm
Quoting JBirdAV8r (Reply 14):
Mines the best 2000 tons of steel that Puebla ever produced  Smile
Not a single problem - except for the tail light bulb in question - and the overpriced 20k service.. but that's hardly the cars fault... I guess that's the price you pay in taking it to the dealer right smack in the middle of Chicago's Gold Coast.
I hadn't either. And that's what i was expecting this AM - Not $500  Sad
I really don't need a car for the day.. they did drive me to work in a very very nice Audi SUV
fr8mech
Wed Sep 16, 2009 8:09 pm
The only thing I do is oil changes at the specified interval. Everything else is on-condition. It served me pretty well with the passed 3 new cars I've had. It will serve me well for this new (2009 Flex) car, though the 7500 mile oil change interval concerns me a little.
1988 Cherokee - 10 years and ~160,000 miles. My brother-in-law drove it for another 50,000 or so until the body rusted out.
1997 Explorer - 12 years and ~145,000 miles. Still being driven by one of my wfe's cousins.
2003 Sebring - still own and at about 75,000 miles. Hasn't missed a tick (knocking on wood like head)
I replace the coolant when the hydrometer indicates I need to. Transmission fluid when the color is 'off'. I know...color is not a good indicator, but, there you have it. Never did the transaxles or differentials on the 4x4's. Batteries when they show even the slightest indication of becoming an issue. Air filters at 10,000 miles.
And no, unless your bill of sale or warranty specifically says it is void unless you have service perforned at the dealer, then you should be good to go. Be prepared to show some records if you make a warranty claim.
By the way...why go to the dealer for a bulb?
Cadet57
Wed Sep 16, 2009 8:13 pm
Quoting Fr8Mech (Reply 18):
Go to autozone, spend $2 on one and they'll even put it in for you.
mt99
Wed Sep 16, 2009 8:15 pm
Because i needed an oil change anyways... and i knew that stuff had to be looked at for the 20k miles
I was expecting $150 or so
L410Turbolet
Wed Sep 16, 2009 8:16 pm
Why?
fr8mech
Wed Sep 16, 2009 8:36 pm
I don't know. I understand full synthetics can easily go this distance, but it just seems a long time. I'll get used to it.
Springbok747
Wed Sep 16, 2009 8:42 pm
I always maintain my car by the book.
I'm surprised premium cars like BMWs and Mercedes don't have scheduled maintenance built into the car. I remember several years ago when we were in South Africa, the cost of a new Mercedes included the maintenance. They have just introduced a similar thing here in Oz for the new E-class. The buyer pays an extra $500 or something when they buy the car and that takes care of all the normal maintenance for 5 years or 100,000 kms. Its an awesome deal which means for a normal service (where nothing major needs replacement) you don't pay anything.
Quoting Flighty (Reply 3):
It is a racket. When I took my Wrangler for its 50,000 km service a couple of months ago..I was shocked to find out the things the dealer had included in the 'service'...there were some weird hidden costs, like $24 for a 'computer reset' and $12.50 for 'data recovery'..wtf? Cheap idiots trying to make money wherever possible.
אני תומך בישראל
L410Turbolet
Wed Sep 16, 2009 9:03 pm
Quoting Fr8Mech (Reply 22):
The exchange intervals in the US are for some reason extremely low (at least compared to what manufacturers prescribe in Europe).
My 2001 HDI engine has a 20,000 km (12,500 miles), 30,000 km has become the norm for the cars manufactured nowadays (some go as far as 50,000 km although I would not leave there that long).
DocLightning
Wed Sep 16, 2009 10:30 pm
I bought it pre-done on the Prius because it was pretty cheap (like $2000) and covers 100,000 miles or 10 years, whicever comes first.
During that time, I can have regular maintenance and I don't have to worry about paying a dime for it if my finances are tight. It also keeps the car's value up and makes me worry less about a random problem popping up one morning on my way to work, nails in tires aside.
BTW, my car detects nails in tires. Gives me a pressure warning. That's so cool! I've never had a car that can do that before.
-Doc Lightning-
-Carl Sagan
Flighty
Wed Sep 16, 2009 10:38 pm
True, but on the other hand, most factory / dealer "maintenance plans" totally neglect the ATF. Cars with 100,000 miles and their original ATF adhere to their factory plan. But they are cooked, their transmissions are pretty much toast. The mx plans are profit centers for dealers, period.
 thumbsup
Cars are designed to last. There is no maintenance needed until after 50,000, generally. The idea of inspecting a 20,000 mile car -- basically a brand-new car -- is just laughable to some of us. Oh yeah, let's check the coolant on that brand-new car. Whatever. Sometimes, the "plan" isn't even written in the factory owner's manual -- it is an outcome of the dealer's own creativity to make himself some money.
Quoting myself... what I mean was, properly maintaining a new car IS POSSIBLE to do very cheaply. Just change the oil and trust that the rest is good for at least 60,000 unless you damaged something. If you read the fine print it's usually a bunch of nothing. Meanwhile when the real repairs come along, you already spent your money.
WildcatYXU
Thu Sep 17, 2009 12:23 am
Quoting L410Turbolet (Reply 24):
Not only in the US, in Canada too. The most likely reason is that the only condition to keep your warranty is oil change (at least here). No warranty inspections as it's a habit in successor countries of former Czechoslovakia.
So the car dealers try to make at least some money this way. It's annoying, but still cheaper than over there. (16000 Kc for the company Astra's last warranty inspection - ouch...)
310, 319, 320, 321, 333, 343, 345, 346, 732, 735, 73G, 738, 744, 752, 762, 763, 77L, 77W, 788, AT4, AT7, BEH, CR2, CRA, CR9, DH1, DH3, DH4, E45, E75, E90, E95, F28, F50, F100, MD82, Saab 340, YAK40
PPVRA
Thu Sep 17, 2009 12:51 am
I have a Jetta and change my own oil. I use Mobil, which costs about $20 for one change iirc. My car is out of warranty though.
The oil drain (don't know if there's a technical name for it) is so easily accessible I don't even lift my car off the ground to change the oil. I have to squeeze a bit, but I fit in there (or my head and one arm does, anyway), which is nice since I hate getting under a ton of metal no matter what those stands are rated for.
"If goods do not cross borders, soldiers will" - Frederic Bastiat
vikkyvik
Thu Sep 17, 2009 1:48 am
Absolutely.
$120
$60
Unbelievable. I don't think I've ever had an oil change cost me more than $30-40.
The mechanic I use now charges somewhere around $20. Hell, last time I took my car there was for a muffler replacement; he did an oil change as well, and the whole thing cost me $150.
Quoting Mt99 (Reply 20):
Get the stuff looked at somewhere else. It'll be a hell of a lot cheaper than the dealer.
Cadet57
Thu Sep 17, 2009 2:02 am
Quoting Vikkyvik (Reply 29):
I do my own oil changes and it costs me $35. 5qt jug of Mobil1 full synthetic and a Bosch OEM oil filter. 20 mins later, and I saved $45 dollars. The stealership charges $79.99 for an oil change...
tommy767
Thu Sep 17, 2009 2:18 am
2004 chevy malibu LT V6 106,500...will bring it in soon for new belts and hoses. Otherwise solid right now but here are some past problems:
2008: Had to get new brake calibers and pads replaced on front along with new struts. a very expensive repair...
2007: new exuast system system because the previous one rusted out from being parked outside to much in New Jersey...
2007: CD player malfunction...got a new one in 2008 after market (much better one)
American cars aren't bad, but just need more care than say a Toyota.
"KEEP CLIMBING" -- DELTA
mirrodie
Thu Sep 17, 2009 2:25 am
Trust your instincts unless your warranty becomes invalid otherwise.
Whoa....how can you tell if a bulb "is going" to blow? An incandescent bulb?
Anyway, as I am on the market for a new car, its threads like these that enforce my opinion that I would ever buy German... Used to be that German engineering was once prided upon and the cars would last forever with simple maintenance. Nowadays they are over-engineered with too many potential problems and ridiculous maintenance schedules and fees. (I feel that way about many makes, but use German just as an example.)
Just give me 4 wheels and reliability without hassle and I'm a happy guy. I'll get the oil changes with my mechanic.
Forum moderator 2001-2010; He's a pedantic, pontificating, pretentious bastard, a belligerent old fart, a worthless st
sccutler
Thu Sep 17, 2009 2:49 am
My wife's Jetta (2003, Puebla-built) is tight as a drum, fast and solid, at 61,000 miles. Fine car.
The OP was being ripped-off, but it was not by VW of America; it is a dealer shakedown.
Just say "No."
...three miles from BRONS, clear for the ILS one five approach...
andz
Thu Sep 17, 2009 6:05 am
Quoting Springbok747 (Reply 23):
I don't pay for anything, irrespective of the type of service or what needs to be replaced.. Nothing at all. The only thing excluded from the maintenance plan is tyres and top up oil.
T prop
Thu Sep 17, 2009 6:52 am
Quoting Mt99 (Reply 17):
You must crush people in the wake of your 4 million pound vehicle.  silly
HAJFlyer
Thu Sep 17, 2009 6:53 am
Quoting Andz (Reply 34):
Same here, and never had any serious issue with my current or past two 3 series BMWs.
Quoting Mirrodie (Reply 32):
That depends very much on the equipment level. I would be most worried about the long term reliability of fancy "driver assistant systems" such lane departure warning, radar cruise control, etc. On most german cars except for the top versions like the s-class, A8 or 7-series these are optional anyhow.
Carlisle
Thu Sep 17, 2009 12:09 pm
Yes, although I must admit I am dreading to see what it's going to cost me for my 15,000 mile maintenance check which is now due. My 10,000 was around 350USD and goes up each time I take it in. I am guestimating that its going to cost me 500USD this time.
Thanks for posting this as it is to remind me to take it in.
Jeremy
Proud Toyota 2009 Camry owner
"CLEAN PLANES AND DIRTY MARTINIS" (Delta)
sccutler
Thu Sep 17, 2009 1:09 pm
Quoting Carlisle (Reply 37):
You should not have to dread most routine maintenance on a car like yours; before you agree to pay for some fluffed-up and costly set of "recommended maintenance," be sure you read the MANUFACTURER'S required MX, not that official-looking sheet the dealer hands you.
Most cars require, essentially, oil changes, inspections (as in, look at it with the hood up, not disassemble it to inspect), and (perhaps) tire rotations. No "engine flush" or "injector service" or "tune up" (what the hell is THAT any more?) any more.
Replace timing belt at recommended interval, to avoid needless heartache, keep clean oil in the car, and drive it. Your Camry should be good for 100k+ miles with nothing but oil changes and (perhaps) a timing belt.
Don't feed unscrupulous dealers.
fr8mech
Thu Sep 17, 2009 1:18 pm
I'm interested: exactly what did you get for your $350? What do you expect to get for your $500?
The engines in new cars should be able to go 100,000 miles without any real work required. Oil change, filters (air & oil) and that should do it. Any coolant that has broken down in the first 30,000 miles or so, was a bad mix or low quality.
mt99
Thu Sep 17, 2009 1:31 pm
Thats a lot for 10k!
True this was $500 - but before that i had maybe spent $200 total on 3 or 4 oil changes and the required 5K, 10K and 15K maintenance. So total for 20K miles and 2.5 years has been about $700.
Nothing else should be required until the next 10k miles. Which should take me more than a year. So only oil changes for me until then  Smile
Quoting T prop (Reply 35):
Opps.. 2000 lbs !
CanadianNorth
Thu Sep 17, 2009 7:12 pm
Was it really a basic oil change? If so I woulda walked out right there. Anyone can do a basic oil change in their driveway by themselves, with a very small selection of basic tools and about 20 minutes of their time. All you'll need really is a jug of oil and a new filter, with generally can be had at pretty much any form of automotive type store for about ~$30.
CanadianNorth
HS-748, just like a 747 but better!
Cadet57
Thu Sep 17, 2009 8:21 pm
Quoting SCCutler (Reply 33):
If its a VW dealer they are told what to charge. Which is another example of why I will do all my maintenance myself, or if its a larger job, the independent VW shop I found.
Im sorry to hear that  Wink
I thought Toyotas never need anything? the Most I ever paid for a service was $525 which was my 80k service. Timing belt, water pump, tire rotation, oil change, fluid check, sunroof check, tire balance, spark plugs and a ton more that I really dont feel like typing: For you 1999-2005.5 VW owners, this is the service's you should be doing at your respective mileage:
http://www.bentleypublishers.com/ima...h/vw/vw.2003.maintenance.sched.pdf
RobertNL070
Thu Sep 17, 2009 9:26 pm
Daylight robbery!
Proud [ ... ] owner
 crazy
Youth is a gift of nature. Age is a work of art.
Cadet57
Thu Sep 17, 2009 9:27 pm
Quoting RobertNL070 (Reply 43):
Funny. I thought the same thing.
[Edited 2009-09-17 14:28:22]
tommy767
Thu Sep 17, 2009 10:44 pm
One thing I will add about the 2004 malibu is the gas mileage is incredible for a V6: 23 city 30 highway...so it keeps the costs down a bit while driving in LA...
sccutler
Fri Sep 18, 2009 4:41 am
Quoting Cadet57 (Reply 42):
Read your warranty book (came with the car), see what the manufacturer *requires*; if the dealer insists on doing more, and suggests that the warranty will be in ANY way affected if you don't, run, don't walk, to the Attorney General's office for your state, and ask that the dealer be investigated.
Then call VW of America, tell them about it.
What you describe is just plain wrong.
My VW dealer does only what I ask of them.
sv7887
Fri Sep 18, 2009 2:03 pm
Quoting DocLightning (Reply 25):
That sounds pretty expensive. Does this cover brakes and things like that? Given it's a hybrid I'm curious whether it needs less maintenance because the engine runs less. Toyota cars typically require "major" services at 30K intervals with less expensive services every 15K.
TPS is becoming pretty common on cars. There are two types, one that measures the actual pressure (Lexus has this on some of their models) and a more passive system that measures the revolutions of the tires to notice any difference. Still it's a very good feature to have, especially on hybrid where MPG is the primary reason.
They are still built sturdy, but as you say crammed with pointless complexity. My dad's S Class has had $10,000 in warranty work. The sad thing is that this car is 3 yrs old and has 15,000 miles on it.
My E Class has been relatively trouble free. I did avoid the air suspension and all the electric junk that comes on the higher end models. The assembly quality is better than anything I've driven. Only the 1992 Lexus LS400 I had came close.
Quoting CanadianNorth (Reply 41):
Sadly it was. The problem with Benz is that you need to suction the oil from the dipstick. And the jerks require their proprietary computer (It's basically a Thinkpad loaded with their diagnostic software) be hooked up to the car, so the "car can tell you what it needs." Also you can't reset the service light without this dumb computer, so if you do your own oil changes, the car will keep bitching at you that you're overdue for maintenance.
Insane I know. Lexus used to be cheaper too, but by the time my dad traded in his LS430 they were starting to adopt the same inane service antics that the Germans are known for.
Cadet57
Quoting SCCutler (Reply 46):
The list I provided in post 42 is what HAS to be done at each service interval for my car.( http://www.bentleypublishers.com/ima...h/vw/vw.2003.maintenance.sched.pdf )
Not only are their rates exorbitant for simple services ($79.99 for an oil change, $15 for a tail light bulb, their hourly rate for my car is $95/hr) their service dept sucks. I've had my car smoked in, 70 miles put on my car once after an air pump change, my seat left in that oh so comfortable "gangster" style, the local rap station left on in my car with the volume at a window shaking level, being called a liar by the (now former) service manager. Just to name a few. There is only one person there I like and its the woman who answers the phones and even she admits the service is bad. On that note, the person who suggested I go to this independent shop? The dealerships sales manager. That says something right there.
Users browsing this forum: bagoldex, jubguy3 and 13 guests
