B737200
Maths Problem
Tue Jan 19, 2010 12:38 pm
Hi,
I have a maths problem and since I've seen people asking all sorts of questions over here I thought "why not?"
So I need to solve this equation: 2.64 = (a) + ln(a)
where a is the variable i'm looking for and ln is the function ln [log_e].
The only thing I could come up with is to insert values of a and repeat the process correcting a as I go.
Anything better than iteration?
Thanks.
Lady Guinness is ready to fly...
oly720man
RE: Maths Problem
Tue Jan 19, 2010 1:01 pm
Is this in any particular bit of maths?
One solution would be to use a series solution for ln(a) which would give a quadratic/cubic you could solve.
http://en.wikipedia.org/wiki/Natural...arithm#Derivative.2C_Taylor_series
B737200
RE: Maths Problem
Tue Jan 19, 2010 2:13 pm
Its actually a fluids problem but I got stuck on the mathematical part.
The problem has water flowing out of a tank through an orifice whilst water is also flowing into the tank.
I ended up with an integral which I solved using a given result and I ended up with the above equation. It should be correct since my calculator worked it out and the answer matched but our lecturer is a bit fussy so I'm not sure if he'd except that in an exam.
I'll take a look at the link you sent, it seems somewhat familiar, maybe we did it last year in our maths unit. Hopefully something like that would be in the equation sheet we get, good luck trying to remember all the funny mathematical solutions to stuff that MIGHT come out. I get the feeling he is going to test us on mathematics as much us he is going to test us on our fluid's knowledge.
What nudged me towards the iteration method was the fact that the question states the we are to give an approximate answer; of course using a series solution would also yield and approximate value so maybe this is it.
Thanks, series totally slipped my mind, maybe its because I can't stand them  Big grin
BMI727
RE: Maths Problem
Tue Jan 19, 2010 5:04 pm
Quoting B737200 (Reply 2):
Perhaps looking at the differential equations for a mixing problem would be of help.
Yellowstone
RE: Maths Problem
Tue Jan 19, 2010 10:31 pm
What you want to use here is something called Newton's method.
http://en.wikipedia.org/wiki/Newton%27s_method
First, rewrite your equation so that it's equal to zero. f(a) = a + ln(a) - 2.64 = 0
Next, you pick some value of a, call it a_0, that is decently close to the right answer. Then, calculate the following, where f ' (a_0) is the derivative of the function f evaluated at a_0.
a_1 = a_0 - ( f(a_0) / f ' (a_0) )
Calculate a_2 in the same fashion, replacing a_0 with a_1. Repeat until a_n converges.
Hydrogen is an odorless, colorless gas which, given enough time, turns into people.
Fabo
RE: Maths Problem
Wed Jan 20, 2010 12:42 am
Why repeat? If I understood right, you can use limit. You should get to about 1.96467 if I am not mistaken.
I will try figuring out how to isolate a, but do not expect much from me right now...
The light at the end of tunnel turn out to be a lighted sing saying NO EXIT
B737200
RE: Maths Problem
Wed Jan 20, 2010 7:53 am
Firstly thanks for all the input, I wasn't expected this much help for my little mathematical conundrum.
Quoting Yellowstone (Reply 4):
I was actually studying it this week, when I was trying the fluids problem I hadn't really gone over my maths note yet. Seems to bring a bit of order to my "lets just throw in some values" method.
Quoting Fabo (Reply 5):
By using a limit you mean with Newton's method? The version we learned didn't use that, I'll look around but if I misunderstood you I'll be on a wild goose chase for nothing.
Don't worry if you're busy, I understand and thanks for your input.
Quoting BMI727 (Reply 3):
I derived a differential equation. The one I derived was:
Q_out - Q_in = A_tank * (dh/dt) where Qs are volume flow rates, A is area and h is the height of water level in the tank.
On working it out using a given result printed under the question itself I ended up with the 2.64 = lna +a.
Not sure if you are referring to the same thing.
Once again thanks a million, very helpful.
ag92
RE: Maths Problem
Wed Jan 20, 2010 11:50 am
I don't know if I will be of any help, but I would just graph it, and calculate the value through a graph
Flighty
RE: Maths Problem
Wed Jan 20, 2010 12:59 pm
Use my very most favoritest website ever:
http://www.wolframalpha.com/input/?i=2.64%3D+a+%2B+ln%28a%29
You're welcome.
Fabo
RE: Maths Problem
Wed Jan 20, 2010 2:20 pm
Flighty: That is what I used to come to 1.96467 I mentioned  Smile Nice web, for sure.
waterpolodan
RE: Maths Problem
Wed Jan 20, 2010 4:16 pm
Having Maths trouble? Might I suggest this video as a useful tool-
http://www.youtube.com/watch?v=Pj2NOTanzWI
B737200
RE: Maths Problem
Wed Jan 20, 2010 4:54 pm
Thanks for the website, its now in my favorites.
Users browsing this forum: bhill, bombayduck, Kiwirob, salttee and 3 guests
