Fly2HMO
Question For The MS Excel Gurus: Formula Help?
Thu Feb 18, 2010 10:41 pm
So I'm building a spreadsheet where I need to calculate the operating cost per hour per route for a plane.
So in simple terms the formula would be column A (duration of flight) times column B (cost to operate aircraft per hour) = cost for flying the route
The problem is that I can't figure out for the life of me (short of converting hours to decimal format) how to make excel multiply the time in regular time format correctly to get the correct results.
A sample formula that I'm trying to do:
1:30hrs x $850= $38 (according to excel, WTF?!?)
The A column is selected to be in time format.
If i change the hours to normal general decimal format then excel gives me the right answer:
1.5hrs x $850 = $1275
I've searched like crazy on the help system and on google and cant find an answer.
I need to use non decimal format times for a presentation. Any ideas?
Using office 2007 by the way
[Edited 2010-02-18 14:42:49]
Phoenix9
RE: Question For The MS Excel Gurus: Formula Help?
Thu Feb 18, 2010 10:53 pm
Quoting FLY2HMO (Thread starter):
Enter the time in minutes instead of hours, you won't need to enter decimals
This is an indirect method: create another column with time in decimals and use that in your formula. When doing the presentation, just shrink the column to hide it or use 'white' as the text colour
Sorry couldn't help more.
Life only makes sense when you look at it backwards.
2H4
Thu Feb 18, 2010 10:57 pm
Quoting Phoenix9 (Reply 1):
You can also highlight the columns you'd like to hide, right click up on the letter of the column, and select 'hide'.
Intentionally Left Blank
Phoenix9
Thu Feb 18, 2010 11:02 pm
Quoting 2H4 (Reply 2):
Oh yes. D'oh! Forgot that excel has that option.
casinterest
Thu Feb 18, 2010 11:13 pm
You forget that you are using two different units values to multiply into $/hour. if you truly want $ per hour as your multiplier you need too have the time entered as hours. Think of this as a modulus operation on the true number.
Hours of the timestamp+Minutes of the Timestamp converted to hours by dividing by 60
I ran a sample listed below.
I offer up the following: Where A is your Time format in X:X and B is your Cash
=(HOUR($A1)+(MINUTE($A1)/60))*$B1
1:30 $850.00 $1,275.00
4:30 $850.00 $3,825.00
2:30 $850.00 $2,125.00
3:15 $850.00 $2,762.50
7:30 $850.00 $6,375.00
Older than I just was ,and younger than I will soo be.
Dreadnought
Thu Feb 18, 2010 11:15 pm
Excel uses a time system based on day units, where 1 day =1, 1 hour = 0.041666667, 1 minute = 0.000694444 etc.
If you type in a cell a time in a recognizable format, like 1:30, excel automatically converts it to it's own system, which would be 0.0625.
The way to get around that is not to use such formats, and put in simply the units you want, like hours. 1.5 instead of 1:30.
You can do dozens of other things as well if you want to experiment with text parsers etc.
Democrats haven't been this angry since we took away their slaves.
petertenthije
Thu Feb 18, 2010 11:17 pm
I use the Dutch version, so the exact term might be slight different.
Say you got your begin time in cell A1, end time in B1 and the total time in C1 (=B1-A1).
You have two options, one simple one a bit longer:
A1 = 10:00
B1 = 12:30
C1 = 2:30
D1, add funtion "=HOUR(C1)", result will be "2", multiply this by the price per hour so you get "=HOUR(C1)*850". You'll get 2*850 = 1700.
E1, add funtion "=MINUTE(C1)", result will be "30", divide this by 60 (minutes) and multiply by the price per hour so you get "=(HOUR(C1)/60)*850". You'll get 0,5*850 = 425.
F1, add function =D1+F1". You'll get 1700 + 425 = 2125.
Or you can combine the function in cell D1 and E1 into one big function: "=(HOUR(C1)+(MINUTE(C1)/60))*850". If you really want to make your sheet future proof you might want to consider putting the price per hour in another cell and letting the formula refer to that cell. If the price per hour changes, you only need to change the input cell and not all functions.
[Edited 2010-02-18 15:19:00]
Attamottamotta!
Fly2HMO
Fri Feb 19, 2010 12:56 am
Oh man I'm drinking out of a firehose
(I just realized the implications of that, therefore...) *that's what she said*
But I'll experiment with the suggestions.
LOL sure smarty pants then I have to use operating cost per minute in the rest of the cells.
Quoting Dreadnought (Reply 5):
I'll do that for now just to get some useful numbers
Quoting casInterest (Reply 4):
Quoting Petertenthije (Reply 6):
That's probably what I'll end up using for the presentation.
Thanks ya'll!
Phoenix9
Fri Feb 19, 2010 1:01 am
Quoting FLY2HMO (Reply 7):
of course. then you just make another hidden cell that has the operating cost/minute and use it in your calculations
Users browsing this forum: Francoflier, Kindredmsg, salttee, vc10 and 3 guests
