rootsair
Two Men Die Like Lobsters
Wed Mar 03, 2010 7:38 am
Last february, two men in Russia died after coming out of the sauna. They had the intention of refreshing themselves by jumping on a pool of cold water. However the water in the pool had been boiled by error.
A third man that was present tried in vain to save them but nothing could be done !
TWO Russian men died in a sauna after jumping into a plunge pool that had accidentally been heated to boiling point, investigators and media said.
http://www.heraldsun.com.au/lifestyl...ishap/story-e6frfhk6-1225836428560
A man without the knowledge of his past history,culture and origins is like a tree without roots
aircatalonia
RE: Two Men Die Like Lobsters
Wed Mar 03, 2010 8:06 am
That's a hell of a heating system, that can heat an entire pool to 100C.
Kiwirob
Wed Mar 03, 2010 11:18 am
Boiled people wouldn't be as tasty as boiled lobster, but seriously what a horrible way to go, I hope it was quick.
Bongodog1964
Wed Mar 03, 2010 12:00 pm
Bizarre, and to be honest seemingly very unlikely to happen as reported.
Why would a plunge pool have the facility to have its water heated at all, even less likely to boiling point. Hot water systems normally only go to a maximum of about 80c at the boiler, they are not designed to boil, as boiling water in the pipes makes a hell of a racket to strat with.
And then it takes a lot of effort to fill a pool big enough for two people.
MD11Engineer
Wed Mar 03, 2010 12:09 pm
Actually many hot water systems are limited to 60 centigrades, because, if the water is hard, limescale will start to fall out and to clog up the pipes above this temperature.
Jan
bohica
Wed Mar 03, 2010 4:30 pm
I call BS on this one.    First you would need one hell of a system to heat an entire pool to boiling. Second, we all know what boiling water looks like in a pot on the stove. The pool would look the same way. Also there would be lots of steam coming out of the water. Anyone with any common sense would know better than to jump into boiling water.
oly720man
Wed Mar 03, 2010 4:36 pm
A different take on the story here which seems to be a more reasonable explaination for why the water was hot, at least...
http://www.austriantimes.at/news/Aro...03-03/21247/Sauna_man_boiled_alive
The two teachers thought they'd filled the plunge pool with cold water but had turned on the hot tap instead sending gallons of boiling water into the tank, say police in Kirowie, Russia.
GQfluffy
Wed Mar 03, 2010 4:52 pm
Boiling water out of a tap?
This isn't where I parked my car...
LTU932
Wed Mar 03, 2010 5:18 pm
Are they eligible for the Darwin Awards?
EZYAirbus
Wed Mar 03, 2010 7:19 pm
I was expecting it to say they were hand picked from a large tank in a restaurant and served up as a main course!
http://www.glenneldridgeaviation.com
mwhcvt
Thu Mar 04, 2010 4:35 pm
I don't think that we are actually talking about boiling water in reality, I sounds as thought the error was to fill the plunge pool only from the Hot tap, this would result in some very hot water, no boiling but certainly hot enough to scold, burn the body at a cellular level, lets not forget you do not have to exceed the normal body temp by much to cause irepubal damage.
Must think up a new one soon, slow moving brain trying to get into gear ;)
sudden
Thu Mar 04, 2010 4:51 pm
Quoting GQfluffy (Reply 7):
Well, I live in Holland, and here the hot water from the tap is really hot . The reason for this system is to kill any bacterias. Sweden doesn't use this system as there they have filters to sort that out. So the hot water never gets close to the boiling point. But here in Holland the hot water is no joke as it's close to the boiling point. And I can well imagine that if you jump in a tank with water as hot as we have it here, your gone. Maybe they use the same system in Russia.
Aim for the sky!
Sudden
When in doubt, flat out!
AirPacific747
Thu Mar 04, 2010 5:19 pm
I agree with some of the other posters.
I don't believe that really happened. It is pretty obvious when water is boiling due to a lot of steam and bubbles. Also the heating system is not geared to heating a whole pool and that to 100c degrees. Doesn't make sense.
slimshady
Fri Mar 05, 2010 6:56 pm
I belive it.
I was in Mexico on vacation with the wife a few years ago, and our villa had a private heated plunge pool. We asked the front desk to heat up the plunge pool and they left the heater on waaaaay to long. Seriously, I stepped my foot into it and it was really really hot!!! It burned like crap, and that after just being in the water for just a second. Imagine if I had jumped in, instead of walking down the steps, I may have suffered the same fate as those poor guys.
Users browsing this forum: 1337Delta764, WildcatYXU and 2 guests
