UAL Bagsmasher
Zodiac Inflatable Boat Question
Sun May 30, 2010 12:05 am
I own a Zodiac PVC rollup inflatable fishing boat. I would like to protect the bottom of the tubes from abrasion when pulling the boat up onto a sandy beach. Does anyone know of any coatings I can apply to achieve some sort of abrasion resistance? I'm sure I can get creative with a few tubes of out of date PRC, but I'd rather do it the 'right way.'
MCOflyer
RE: Zodiac Inflatable Boat Question
Sun May 30, 2010 2:36 pm
I would go to a local marine store and ask them. Does your Zodiac have a fiberglass bottom or inflatable keel??
KH
MD11Engineer
Sun May 30, 2010 2:45 pm
I own an old Klepper Master folding dingy from the 1960s (frame made out of marine plywood with a rubberised canvas skin and two inflateble belts to aid in bouyancy and to give it rigidity). I used ruberised canvas strips, which I would glue over the sensitive spots with rubber cement.
http://www.faltbootbasteln.de/fbb-klepper-master.html
Jan
UAL Bagsmasher
Sun May 30, 2010 4:01 pm
It has an inflatable keel. The rubberized canvas sounds like a good idea.
PPVRA
Sun May 30, 2010 9:21 pm
Consider a light-weight launching dolly, or this interesting concept...
http://www.perneborn.se/products.html
If you're going to use it on the beach, make sure it has a nice big (off-road style) tire so that it doesn't sink into the sand.
"If goods do not cross borders, soldiers will" - Frederic Bastiat
UAL Bagsmasher
Sun May 30, 2010 11:34 pm
I like the last idea. I've actually seen a similar product for sale at a marine store. My only concern about using them is that you have to drill into the wooden transom below the water line. Will a good sealant be enough to prevent water ingress? It's hard to undrill a hole
PPVRA
Mon May 31, 2010 1:10 am
Talk to someone who does marine repairs, but I don't think it's going to be a major problem. Sealants work very well.
Also, consider if the transom can support the load of the boat. As long as it is in good condition it shouldn't be a problem.
Fly2HMO
Mon May 31, 2010 1:28 am
Well the really cheap solution we use for our 10Ft Avon Super Sportster is to just lay out a tarp in the launch area. Much more simple. Though it's not really necessary.
Dunno about Zodiacs but the material on Avons is so thick and tough that you could drag the damned thing for miles on asphalt or a rocky road and it would never puncture.
UAL Bagsmasher
Mon May 31, 2010 2:36 am
I already use the tarp method, but its dragging up to the tarp I want to avoid. Granted, the material is tough. But over time I can see it wearing down and getting thin.
MD-90
Mon May 31, 2010 5:33 pm
Quoting Fly2HMO (Reply 7):
I like simple solutions too. In order to pull my canoe out of the water (an Old Town Tripper) over the wooden dock I just lay down one of the boat cushions and slide it out of the water on that. It's easier to do that than to have two people try to hoist such a large canoe directly out of the water.
Fly2HMO
Mon May 31, 2010 5:57 pm
Quoting UAL Bagsmasher (Reply 8):
Nah, you'll be fine. We've had the Avon for 20+ years. Barely has any scratches. I will say however, it does seem Avon has much better material than almost all the Zodiacs I've seen.
UAL Bagsmasher
Sat Jun 05, 2010 1:01 am
Well, I went with the transom mounted wheels. I used the boat this week and what a difference! No leaks and launching is a breeze now. But, I have a new problem  How can you remove algae staining from the bottom of a PVC Zodiac? I've tried all the inflatable cleaners and no joy. I'm afraid of trying anything harsher (i.e. Jet-A) . I drove through an algae bloom and now my once gray boat is lime green below the waterline. Any ideas?
Users browsing this forum: salttee, seb146, tommy1808 and 12 guests
