Airstud
Can You Put Logs In A Gas Fireplace?
Thu Jul 29, 2010 5:10 am
There are so many gas fireplaces these days. When I lived in a place that had no fireplace, I was always jealous at the supermarket or corner store, watching people buy those Duraflame logs in the winter time.
Well hey...the Duraflame people have been in business for awhile, do they make a firelog I can burn in a gas fireplace - or is it safe to even burn their regular ones in there? When the Minneapolis winter sets in, I want a cozy, wintry, cackly, the-fireplace-is-cackling-and-not-just-because-of-natural-gassy feeling.
Pancakes are delicious.
Maverick623
RE: Can You Put Logs In A Gas Fireplace?
Thu Jul 29, 2010 6:13 am
It should be safe. A fire is a fire, although I think Natural Gas burns hotter. Also, there's the issue of embers and ash cleanup that you'd need to take care of if the fireplace is narrow.
"PHX is Phoenix, PDX is the other city" -777Way
UAL747
Thu Jul 29, 2010 6:15 am
I've always had and grown up with a gas fireplace, and we just threw regular wood into it. You don't need a starter log since you have the gas keeping the flame going.
What's the point of a fireplace if you don't get that nice and cozy fire smell?
Tugger
Thu Jul 29, 2010 6:25 am
Quoting Airstud (Thread starter):
Yes, a gas fireplace is perfectly safe to burn normal wood in. And you don't have to buy those Duraflame logs, just load in your wood and light the gas for five or so minutes and then turn it off and tend to your nice wood burning fireplace.
Of course the problem nowadays is that it is not a "sealed" or "efficient" fireplace like the ones that a designed for wood are nowadays. But then those fireplaces can't use a Duraflame log anyways....
But seriously, the gas fireplace is just fine to burn normal wood in, just remember you will have to periodically clean out all the ash from the burned logs (which is why gas fires are so nice) so don't have the fake ash and stuff in there and be a bit careful of the gas feed when cleaning.
Tugg
Fly2HMO
Thu Jul 29, 2010 6:55 am
Quoting Maverick623 (Reply 1):
It should be safe.
Quoting UAL747 (Reply 2):
Quoting Tugger (Reply 3):
HOLD YOUR FREAKING HORSES!!!!
This may be stating the obvious but there are MANY types of fireplaces and the majority of gas ones I've used are NOT meant for wood.
Have you guys ever read a gas fireplace manual? Most of the ones I've read clearly state to NOT use wood. EVER. For a variety of reasons.
Many gas fireplaces do not vent to the outside. So next thing you know is you have a bunch of smoke clouding up inside your house. This is obviously not in your best interests. Also, many are not meant to handle ashes or any debris of any type inside. You could ruin the gas manifold by clogging it up or warping it due to the weight of the log burning over time.
Generally, if you have to tear apart the fireplace (remove latches, metal grills, glass pane, etc) to put in some wood then they are definitely NOT meant for wood. However, if they're of the type built like a traditional fireplace (not one of those commercial plug-in-the-wall types) that are otherwise a normal fireplace with a gas burner, then yes, you can use wood too.
When in doubt, READ THE MANUAL
[Edited 2010-07-28 23:55:51]
Tugger
Thu Jul 29, 2010 7:13 am
Quoting Fly2HMO (Reply 4):
Ahh, I understand. For me, when I think of a gas fireplace I think only of mine which is the only kind I have seen for a gas fireplace. And my gas fireplace is very much a standard built-into-the-house brick fireplace with a normal chimney and damper, etc. I have not seen or used other types and I must admit, if it did not look like the type of fireplace I am familiar with I would not build a wood fire in it.
So point taken. My comments only relate to what is otherwise a completely standard fireplace but with a gas line and tube installed just under the firewood rack.
Tugg
TSS
Thu Jul 29, 2010 7:31 am
Good points all, to which I will only add
Technically those are unvented gas heaters (albeit with a fireplace-like appearance), and they're not a good idea in general, mainly because of the odorless, colorless, and highly poisonous carbon monoxide they can put out.
Quoting Tugger (Reply 5):
I'm guessing by your location that the fireplace in question is one designed to burn wood and not coal? Coal-burning fireplaces tend to be much narrower and shallower than ones designed to burn wood, so they can usually only safely handle one DuraFlame-sized log at a time.
Airstud
Thu Jul 29, 2010 8:11 am
I'm talking about the kind of gas fireplace one might find in the Louisiana Oaks apartments in St. Louis Park, Minnesota (juuuuuust west of Minneapolisness).
iairallie
Thu Jul 29, 2010 9:22 am
My mother burned them all the time in her gas fireplace with no harmful effects.
Enough about flying lets talk about me!
JAGflyer
Thu Jul 29, 2010 12:37 pm
Quoting Airstud (Reply 7):
Look for a model/made somewhere at the bottom of the fireplace (where you adjust the gas). Google it and find a manual so you can get an educated answer from the manufacturer.
Support the beer and soda can industry, your recycle old airplanes!
NoWorries
Thu Jul 29, 2010 2:55 pm
Another safety consideration is creosote buildup in the chimney. Depending on the type of wood and temperature of combustion, you can get creosote buildup in the chimney -- potentially very flammable. Gas burners don't have this problem so the chimney normally requires no cleaning -- but regular wood-burning also implies regular cleaning (depending on just how much and type of wood is burned).
falstaff
Thu Jul 29, 2010 3:05 pm
My parents had a regular fireplace that they converted to a gas fireplace back in the 1990s. It was a regular fireplace with a gas line run to it. It had fake logs and embers and a plastic know attached to a regulator to vary the flame. You could have easily turned it back into a regular fire place because the chimney was never modified, but you would have had to remove fake logs and embers. I would also imagine that he plastic knob and gas regulator would be damaged by the heat of a traditional fire.
The other type of gas fireplace I have seen are the type with a gas lighter that runs underneath the grate and has a keyed valve off to the side. Once the fire is burning you shut of the gas. That type uses regular logs. A buddy of mine had that kind and he would have to clean out the gas jets every now and then because they would clog up with ash and soot.
I couldn't agree more. You don't want to be that guy that burns down your apartment building and has all the neighbors ready to kill you while you are all standing outside watching your building go up in flames.
My mug slaketh over on Falstaff N503
Users browsing this forum: coolian2, Georgetown, LJ, pvjin, salttee and 2 guests
