desertjets
Coffee For One
Mon Aug 02, 2010 3:32 pm
I've been craving/favoring coffee over the usual cup of tea for my morning caffeine fix. Problem is that swinging by the drive-thru to get a cup of coffee plus whatever breakfast is getting expensive. So I want to get a coffee maker again, but it really needs to be of the small/single serving variety.
My budget max is going to be about $50.
In terms of features it should have:
Programmable timer so I can set it up the night before and have hot coffee ready to grab when I head out the door.
Something that dispensed into a travel mug would be great.
Things I am not so sure about:
Systems that use coffee pods vs. bulk loaded coffee into a paper or wire mesh filter.
For reference I previously had a 4 cup with an automatic timer Mr. Coffee that I got for $20 from Target.
NoUFO
RE: Coffee For One
Mon Aug 02, 2010 3:41 pm
Can you program your stove? Then this:
If not, get one of those:
after all it takes only two minutes to bring water to the boil.
I support the right to arm bears
ALTF4
RE: Coffee For One
Mon Aug 02, 2010 3:46 pm
Is there a kind that adds loads of cream and sugar, too?
Just wondering...
The above post is my opinion. Don't like it? Don't read it.
JAGflyer
RE: Coffee For One
Mon Aug 02, 2010 3:52 pm
For a single serving of coffee I would suggest a french press pot like in the 2nd pic above. Just make sure the water you use is not quite boiling but still very hot and the coffee is coarse ground. You will find a bit of sludge in the bottom of the cup from the finer particles that get through the mesh screen but that shouldn't be a big issue.
If you flew today, thank a Flight Dispatcher!
baroque
RE: Coffee For One
Mon Aug 02, 2010 4:22 pm
Quoting DesertJets (Thread starter):
Take up drinking Kopi Jawa - Javanese coffee. Aka Kopi Tubruk or Collison coffee.
http://www.indonesialogue.com/destin...i-tubruk-%E2%80%93-mud-coffee.html
Kopi tubruk literally means “collision coffee”. The concoction can be found in many parts of Indonesia, particularly in Java and Bali. Sources say kopi tubruk stems from a similar recipe brought over by traders from the Middle East, where it is known as “mud coffee.” Kopi tubruk is the simplest recipe for preparing coffee. To make a cup, one needs to add two teaspoons of ground coffee and sugar according to one’s taste.
Next, pour in boiling water, and let it “cook” the coffee for a while until most of the grounds have settled to the bottom according to Evi Mariani.
Some say kopi tubruk needs finely ground coffee, while others prefer coarsely ground. Most Indonesians, however, buy the common coffee brands from any given warung (locale store).
Devotees say the key to proper kopi tubruk is in the water. Hot water from water dispensers is often not hot enough to cook the coffee grounds. Uncooked grounds will remain floating on the surface.
My local caffeine addict is now trying to limit herself to about 3 to 4 cups a day. A German acquaintance who is hooked on strong coffee positively salivates at the thought of a Kopi Tubruk in spite of his having given us an expensive coffee making machine.
So one bottle of freshly ground coffee, a clean water supply and a kettle will set you up for your next hit.
I presume this is what the guys who invented the Java computer language were drinking. Must be good.
NoUFO
RE: Coffee For One
Mon Aug 02, 2010 4:31 pm
Quoting Baroque (Reply 4):
Isn't that just Turkish Coffee?
desertjets
RE: Coffee For One
Mon Aug 02, 2010 4:34 pm
The french press makes a lot of sense and makes a good cup of coffee. But I am not convinced my half awake, running out the door brain could manage that. Granted getting up 15 minutes earlier would solve that problem.
corey07850
RE: Coffee For One
Mon Aug 02, 2010 4:39 pm
I have a Senseo and have no complaints at all. A few years ago they had a limited selection of coffee types to choose from but now they have quite a few. It's not programmable but you really don't need it to be -- hit the button and it's ready in a few seconds
They might be a little more than 50 bucks though
http://www.senseo.us/Pages/Home.aspx
DocLightning
RE: Coffee For One
Mon Aug 02, 2010 4:48 pm
You may have to go a bit higher to get decent quality. Fact is you'll be saving a lot over the drive-through and it will pay for itself quite quickly.
-Doc Lightning-
-Carl Sagan
planeguy727
RE: Coffee For One
Mon Aug 02, 2010 5:27 pm
I have a keurig machine at home - if you use a dark roast coffee it makes for easy and decent coffee to start the day. While no timer, I turn it on, go to another room to "make room for the coffee", and by the time I return it is ready to go (max 2 minutes). Many varieties of coffee available for the machine.
It's above your price point, but worth the investment.
Personally I buy Green Mountain Coffee to go with it...
I want to live in an old and converted 727...
vandenheuvel
RE: Coffee For One
Mon Aug 02, 2010 6:06 pm
I have a Senseo at home, it's not really coffee in my opinion. As it tastes so much different from regular coffee. At work we have a professional Nescafe machine, which I hope I can afford myself someday.
I recommend you take the extra afford and buy yourself a regular coffee machine.
baroque
RE: Coffee For One
Mon Aug 02, 2010 6:28 pm
Quoting NoUFO (Reply 5):
The local expert's comment when given a Turkish coffee by a Turkish lady after we left was:
"You don't get very much and it is not very strong either."
So the idea might be similar but the execution is a bit different.
greasespot
RE: Coffee For One
Mon Aug 02, 2010 7:19 pm
I really like star bucks instant coffee for those times I want coffee at home.
No really it is good. Not at all like instant from years ago
Gs
Sometimes all you can do is look them in the eye and ask " how much did your mom drink when she was pregnant with you?"
desertjets
RE: Coffee For One
Mon Aug 02, 2010 9:27 pm
Quoting vandenheuvel (Reply 10):
The Senseo machines are rather pricey, even basic ones are pushing $100 here. Through in the added cost of the coffee pods vs. buying whatever I want and I am not too sold on it. I'd much rather deal with an inexpensive french press and buy premium coffee.
Quoting greasespot (Reply 12):
I still have memories of Folger's crystals growing up. I think it was all my dad drank whenever he would have coffee at home. I am pretty sure they finally bought a regular old coffee maker in more recent years.
aloges
RE: Coffee For One
Mon Aug 02, 2010 9:51 pm
Get a French Press and shop around for the coffee brand you like the best, then find out the ideal brewing time - it's very important that you don't leave the coffee in for too long because it may end up undrinkable if you do. Apart from that, those things are pretty idiot-proof and you can get a decent one for much less than your $50 budget.
greasespot
RE: Coffee For One
Mon Aug 02, 2010 10:25 pm
Starbucks via coffee is not floggers or sank a or any of those gross instants. It is almost as gweood a s their premiums
Gs
cpd
RE: Coffee For One
Tue Aug 03, 2010 12:12 am
If you have a stove - just buy some Illy / Lavazza / Segafredo Zanetti ground coffee from the supermarket and get a stainless steel moka-pot to brew your coffee.
Get yourself some little espresso cups and drink real coffee - an espresso - each morning. That's coffee, in its purest form.
No need for Starbucks at all.
Tugger
RE: Coffee For One
Tue Aug 03, 2010 12:38 am
My favorite site for checking out stuff I may want to buy:
.www.consumersearch.com/one-cup-coffee-makers
It basically consolidates and reviews the reviews of products.
Looks like the Black & Decker "Brew 'N Go" might be a good, inexpensive option. The site states the following:
brews a 15-ounce cup of coffee into its included thermal mug. It's inexpensive and takes regular ground coffee,
Overall, we were pressed to find poor reviews for this simple machine, especially considering its low price.
The other ones listed cost a lot more.
Tugg
baguy
RE: Coffee For One
Tue Aug 03, 2010 1:41 pm
We have a magimix Nespresso machine at home and although it's more expensive than say a cafitiere, the coffee is fantastic - it is like fresh coffee except it uses the pods so it doesn't go off - good if your'e on your own!
www.nespresso.com
BAguy
fca767
RE: Coffee For One
Tue Aug 03, 2010 2:02 pm
You should try Instant coffee, that's mainly what we use in the UK  It's just as good, nescafe, douw egberts etc.
NoUFO
RE: Coffee For One
Tue Aug 03, 2010 4:45 pm
Quoting fca767 (Reply 19):
Cellini Instant Espresso is not bad, a lot better than Nescafe, but still a far cry from a *real* Espresso. I have just emptied my new favourite coffee, a wild harvest (hence organic) coffee from a Fair Trade cooperative in Ethiopia's rainforest.
Tastes as good as good as Illy but leaves you with a better conscience.
Aeri28
RE: Coffee For One
Sun Aug 08, 2010 8:32 am
Just buy the Starbucks Via instant packets. They are quite good and have helped me in a pinch. I don't like S'bux normal hot coffee in the shops to be honest (I'll get an Americano at S'Bux or also here in Honolulu, I'll try and go to Bad Ass coffee on Fort Street in downtown on my way to work if I have time, but those packets are not bad at all.
I'm sure with that suggestion, I am already being branded by the coffee eliti as gauche and uncouth, but so be it. I can say I've sat in the fine cafes of italy and france (and lived in coffee loving san francisco for years), but to not have to worry about fixing it each and every morning, those little packets are a blessing and cost saving at about $0.90 cents per cup if you buy the 12 pack for under $10.00. They really have redefined the word "instant" and taste nothing like the instant you may be thinking of.
A french press is wonderful. Honestly. But really, it's a bit time consuming plus you always risk breaking the dammmed glass (which I've done several times). You have to heat the water and let it steep for about 4 minutes and plunge it. If you're in a hurry, not a great solution, plus those grounds that can get in your cup if you don't plunge properly. Perfect for weekend when you have time to relax and enjoy it.
Nobody here will know if you buy the S'Bux packs. They even sell cool little containers that are perfectly measured to just add your hot water, close and go.
edited to say: I see I m not the first to suggest the Starbucks instant packets. Also, to others, no one is disputing french press or keurig or moka pot is better and more authentic, but he's in a hurry and like many of us, just needs to get going.
I remember so well back in the late 80s when i was going to school in France, we were in a rush to get to class and me and a few others would fill our coffee cups (with moka pot coffee or nescafe) and walk through the streets of Aix en Provence with our coffee in hand. THat was simply not done back then lol.
[Edited 2010-08-08 01:38:12]
fca767
RE: Coffee For One
Sun Aug 08, 2010 9:40 am
Quoting NoUFO (Reply 20):
Nice. I'm not a coffeeholic but I might try real coffee one day   I think I had a little back in 2009 once
STT757
RE: Coffee For One
Mon Aug 09, 2010 3:09 am
The new Starbucks Via's are awesome, use them all the time. Taste nothing like instant, they are better than most fresh coffees.
http://www.starbucks.com/coffee/starbucks-via-instant-coffee
greasespot
RE: Coffee For One
Mon Aug 09, 2010 11:19 am
Finally. It is Not just me pushing the star bucks via.
Gs
STT757
RE: Coffee For One
Tue Aug 10, 2010 4:36 pm
Quoting greasespot (Reply 24):
They're awesome, I started out with the Colombian but have since moved on to the Italian roast.
desertjets
RE: Coffee For One
Tue Aug 10, 2010 4:55 pm
Quoting STT757 (Reply 25):
well the next time I hit up the grocery store I'll check these out.
Boeing744
RE: Coffee For One
Tue Aug 10, 2010 11:11 pm
I was given a Bosch Tassimo last year as a gift. It was great for my dorm room. It is a little bit higher than your price range, but I believe they are going for about $100 right now.
The positives are that it is extremely easy to clean and operate. It requires virtually no maintenance. To brew a cup of coffee all you have to do is press a single button, no questions asked. It scans a UPC code on it's coffee "tab" which tells the machine how to brew that particular beverage. It makes coffee, tea, hot chocolate, esspresso and lattes (although I find it's best for just coffee and tea). The quality of the drinks varies with the brand of tabs that you buy. My favourite are the Starbucks Verona tabs which are superb tasting but pricey. I mainly stick to Nabob tabs when I'm low on cash and it works out to about 30 cents per cup. The machine is very fast and makes a cup in under 30 seconds.
The only negative I have experienced is that you are limited to buying prepackaged tabs which may not be simple to find. I am lucky enough to have a grocery store near me that sells them, but only a limited variety. Online you can many more types.
Overall I would enthusiastically recommend the machine.
Flighty
RE: Coffee For One
Wed Aug 11, 2010 12:27 am
Get a french press. Get a water boiler. They only take about 1 minute. then you pour boiling water into the press. Wait 3 or 4 minutes. Press the plunger and pour yourself a cup. Takes 4 minutes but you don't need to watch it steep, you can help yourself to something else while it is doing that. And you can pour + go if in a hurry. Better than Starbucks anyhow.
Quoting Aeri28 (Reply 21):
So get up earlier. I've never broken the glass either. IMO
EASTERN
RE: Coffee For One
Wed Aug 11, 2010 12:45 am
Quoting Flighty (Reply 28):
I was going to suggest this. Just flip the switch on when you wake up. Pass through the kitchen and pour the water into the French press and allow it to brew while you are getting ready. Starbucks also has portable French presses. They are essentially a traditional French press with a thermos top, and hold a single serving. You could use one of those, and then you can even skip the step of pouring from the French press into the travel mug. French press coffee is a bit stronger than drip coffee, which is good to get the day started with.
http://www.starbucksstore.com/products/shprodde.asp?SKU=168985
A quick search got me to that. Great solution for you, I think. Also, one less thing to wash since you make the coffee in the travel mug itself.
I would stay away from pod or capsule-type coffee makers. I hate that I can't choose the intensity of my coffee. My espresso machine can use ground coffee or pods, and I rarely use the pods. Plus, if I run out of coffee I can always go to any corner store and get some coffee grounds. I don't have to go to a speciality store if I run out.
P from NYC
Aesma
RE: Coffee For One
Wed Aug 11, 2010 2:29 am
I'd say it's the nescafé machine that is not making real coffee, after all nescafé is instant coffee.
I'm French but my mother is Italian so I'm used to a coffee pot like that (moka pot) :
It exists in every size, you have to know that an Italian cup is quite small so you might want a 2 or 3 cups one (or even 6).
The classic one doesn't go on induction cooker (Italians are few to use induction) but it can be found, I got that one now :
The brand of both is Bialetti.
I used a "French pot" a few times and managed to get burned, and it just doesn't taste the same.
Now I know Americans like lighter coffee than Europeans (and Italians like very dark coffee), I don't know if the moka pot works as well with less coffee, I couldn't say because I wouldn't like the result, good or bad !
Users browsing this forum: johns624, Kindredmsg, LittleFokker, mmo, sovietjet, TheF15Ace and 1 guest
