richm
Running A Car On Vegetable Oil!
Thu Jan 27, 2011 3:42 pm
So with diesel fuel at £1.30 ($2.1 USD) a litre here, I've decided to try and save myself some money by running my diesel engined car on part SVO/vegetable oil, mixed with diesel in the same fuel tank.
The car seems more responsive now and as of yet, I haven't had any problems aside from the fact that I keep getting strange looks from people who see me pouring vegetable oil into my car while at my local supermarket car park. Oh, and the remarks from the cashiers who find it rather odd when I go to pay for 20+ litres of vegetable oil. "You must do a lot of cooking  " - I've heard that one more than a few times now! That said though, I've read many horror stories about it online. However many of those stories come from those who have "heard" things about it, as opposed to actually experiencing the problem themselves. Has anyone else tried doing this? If so, how did it go?
Rich
[Edited 2011-01-27 07:49:18]
Fly2HMO
RE: Running A Car On Vegetable Oil!
Thu Jan 27, 2011 3:50 pm
I've always wanted to try that myself. I've read that in older VW TDIs you can dump the veg straight in (after filtering it) with no modifications to the fuel system needed (maybe a heater if you live in colder areas). I dunno what the regulations are in the UK but here in the states there's guys that pick up barrels-worth of used deep frying oil from restaurants, and they get to drive their cars basically for free. The restaurants dispose of the oil either way, and you get free fuel, its a win-win situation.
Is it true your car's exhaust smells like McDonalds french fries? Big grin
[Edited 2011-01-27 07:51:20]
MD11Engineer
Thu Jan 27, 2011 3:56 pm
First, this only works with older diesel engines (modern, electronically controlled engines need fuel of very tight specs).
Secondly, depending on the climate you are operating in you´ll need to preheat the vegetable oil to get it to a lower viscosity, which the engine fuel feed pump and injection pump can handle (this is typically done using a heat exchanger coupled to the engine cooling system, which brings the oil to a temperature of about 60° C). I once broke the feed pump on my Landrover Defender after I filled up with raw rape seed oil in late November. You´ll also need a fine fuel filter for the vegetable oil.
Also, different vegetable oils have different properties. Those with unsaturated fatty acids tend to oxidise and to gum up (linseed oil is very well known for this).
A common practice is to have two tanks in the car, a small one for conventional diesel and another, larger, one for the vegetable oil. The vegetable oil tank gets equipped with a seperate electric feed pump and a larger diameter fuel line (due to the higher viscosity of the cold oil) to the heat exchanger. Then there has to be a changeover valve installed between the heat exchanger and the engine feed pump.
You´ll start the car on conventional diesel, let it run warm and then switch over to the veg oil tank for the largest part of the trip. About ten km before you reach your destination you´ll switch back to normal diesel again to flush the injection system for the next start.
Here in Germany we can get raw rape seed oil at low price (and properly taxed) at farm supply stores. I cannot use cooking oil legally, because it is sold with a reduced VAT for foodstuffs.
I understand that your use of cooking oil in your car is illegal in the UK due to taxation issues and that Her Majesty´s government fdrowns upon such abuse.
Jan
RussianJet
Thu Jan 27, 2011 8:26 pm
Quoting richm (Thread starter):
I wouldn't do that because.....
Quoting MD11Engineer (Reply 2):
.....I believe this to be correct.
✈ Every strike of the hammer is a blow against the enemy. ✈
richm
Fri Jan 28, 2011 12:20 pm
They changed the law a few years ago. People don't have to pay duty on it here in the UK unless they use more than a certain quantity a year. (2500 litres afaik)
idealstandard
Fri Jan 28, 2011 12:59 pm
Quoting richm (Reply 4):
   Correct.
My stepdad runs his Xantia TD on veg. We buy it in 50 litre drums from wholesalers.
RussianJet
Fri Jan 28, 2011 3:02 pm
I have duly eaten my words.
4.2.1 Exempt producers/users
If you have produced or used less than 2,500 litres of:
* any biofuel, or
* any other fuel substitute or additive
within the last 12 months, and/or expect to produce or use less than 2,500 litres in the next 12 months, you are an exempt producer and do not need to register with us and account for duty. However, there are simple record keeping requirements, which are described in paragraph 4.9.1.
Production includes the manufacture or processing of road fuel, and the setting aside of any product that has not been charged with duty, with the intention of using it as road fuel.
http://customs.hmrc.gov.uk/channelsP...5&propertyType=document#P160_15306
JBirdAV8r
Fri Jan 28, 2011 3:21 pm
Quoting Fly2HMO (Reply 1):
Actually yes! My friend has an old Excursion modified to burn veg.
falstaff
Fri Jan 28, 2011 4:42 pm
A good buddy of mine, Marty, makes biodiesel out of used vegetable oil. He "brews" his fuel in a 220 volt water heater. Marty began brewing biodiesel 8 years ago and has become very good at it and brews very good fuel. It took him a year or so to get his formula down. Some people like to go the SVO route, but that requires modification of the car, the stuff he brews requires no modification, but it requires a great deal of time to make. I have seen cars that ran SVO and have destroyed rings and injectors.
Marty burns his fuel in a 1985 Mercedes-Benz 300SD, 1991 Dodge Ram 2500 and a 1997 Saturn with a Cummins 1.3 Liter 3 cylinder diesel (a true one of a kind he built). Marty also runs his boat on his fuel, which he outfitted with a 3 liter I-5 from a 79 Mercedes-300SD.
Marty used to work for a small high school and ran three school buses exclusively on his biodiesel. The oil came from a chip manufacturer in Detroit. As far as cold weather goes; Marty runs about 80% Biodiesel in temperatures below freezing.
Quoting JBirdAV8r (Reply 7):
Not only fries, but whatever was being cooked in the oil. Since my buddy Marty makes his fuel out of oil used from the chip making process, his exhaust smells like chips. He also has used oil from fish places and the exhaust smelled like fish.
The quality of the oil directly relates to the quality of the fuel. A lot of bars fry a lot of stuff in their oil before they change it and that oil is full of crap. The better oils come from places that fry vegetables and fish and change their oil often.
Another example of government abuse of power. When they can't figure out how to tax something they just make it illegal. When a person can get around using gasoline or diesel he should not be penalized for being creative.
My mug slaketh over on Falstaff N503
N1120A
Fri Jan 28, 2011 5:10 pm
In fact, restaurants have to pay to dispose of oil, so they get a benefit.
Sort of. It basically smells like you are deep frying something.
Uses modern diesel engines and is known to pull over to Chinese restaurants and strain the used oil through a pair of jeans.
http://www.hlineconversion.com/
Quoting falstaff (Reply 8):
There are inexpensive replacement ring/seal kits out there that work better with SVO.
Fly2HMO
Fri Jan 28, 2011 5:21 pm
Hmmm. Is his fuel still cheaper to make than real diesel once you figure in electricity costs?
RussianJet
Fri Jan 28, 2011 6:50 pm
Quoting Fly2HMO (Reply 10):
One has to wonder. Here in the UK, there would be no question - our duty rates are massively punitive.
N1120A
Fri Jan 28, 2011 7:10 pm
Incidentally, aren't all these new "advanced" diesels coming from the factory as bio-diesel ready?
Almost certainly. The electricity costs are likely only a few cents a gallon, if that.
falstaff
Sat Jan 29, 2011 1:26 pm
Quoting N1120A (Reply 9):
But you are still taking the engine apart, the parts may be cheap, but unless you do it yourself the labor cost is going to be high.
The fuel costs about 47 cents a gallon to manufacture. Running a 220 water heater isn't all that costly. A lot of people are running one all day to heat their water. Of course some people have gas water heaters. You could brew in a gas water heater too, but then would have to run a gas line to their brewing station.
Here is a picture of Marty (left) and me (right) eight years ago when we sat the biodiesel brewing station up, just after the first batch was made. The water heater is the same, but today he has added a cone bottom tank to the mix. I sold Marty my 72 Mercedes-Benz 220D and he got this idea to brew fuel. I never really got into it, but I helped him set it up.
http://i204.photobucket.com/albums/bb309/NWA747/MartyandBryan.jpg
Here is a shot of his boat that he runs on biodiesel and the 79 300SD engine in it. The boat originaly had a GM 4.3 liter V-6.
http://i204.photobucket.com/albums/bb309/NWA747/R1-19.jpg
http://i204.photobucket.com/albums/bb309/NWA747/R1-9.jpg
Tue Feb 01, 2011 1:03 am
I thought they did this on Top Gear some time ago...
http://www.youtube.com/watch?v=GOFbsaNeZps
ual757
Tue Feb 01, 2011 1:27 am
Funny what happens when you forget a letter
Venus6971
Tue Feb 01, 2011 5:33 pm
Nothing new here, John Diesel the inventor of the engine that bears his name originally built it to run on peanut oil.
I would help you but it is not in the contract
MD11Engineer
Tue Feb 01, 2011 6:19 pm
Quoting Venus6971 (Reply 16):
The guy´s name was actually Rudolf Diesel. While having been born in Paris to German immigrant parents, he did his work later in the Bavarian town of Augsburg (where the truck and engine manufacturer Maschinenfabrik Augsburg-Nürnberg with it´s logo MAN still exists today).
Jan
falstaff
Wed Feb 02, 2011 4:17 pm
Quoting MD11Engineer (Reply 17):
That is correct. I have a 1970s filmstrip about him and his engine.
According to the film; his first design was made to burn coal dust. The engine didn't have a cooling system and it didn't work very well.
[Edited 2011-02-02 08:18:54]
aer lingus
Thu Feb 03, 2011 2:59 am
I run my car with various mixture of oils for four years on my HDi engine without modifications and I had no problems at all. But I only use vegetable oil mixtures during warmer months because I don't want to risk frozen fuel during colder months. I only use a small percentage of the mixture because I don't want to kill the fuel pump and the car not starting.
Below is all the various mixtures that I've used.
95% diesel/5% vegetable oil
90% diesel/10% vegetable oil
80% diesel/15% vegetable oil/5% unleaded petrol
80% diesel/10% vegetable oil/10% unleaded petrol
70% diesel/30% bio diesel
70% diesel/30% vegetable oil (runs well on hot days only, otherwise the car will be slow)
70% diesel/15% vegetable oil/15% unleaded petrol
50% diesel/50% bio diesel (higher fuel burn and less power)
While I don't have the perfect mixture formula and none of the above fuel mixture balances, they all worked fine apart from the two with higher % mixtures which has some performance issues.
I hope the above information would somehow be helpful to you.
Split Scimitar or Sharklets?
Users browsing this forum: 1337Delta764, af773atmsp, LAH1, LJ and 1 guest
