Fly2HMO
Help! Corrupted Fonts In Win7
Fri Mar 25, 2011 2:07 pm
Or I'm pretty sure that's the problem... anyways....
Last night I installed Firefox 4. All was well until I noticed coming into a.net that almost all the text shows up bold. At first I was like whatever probably just a glitch, then I noticed it happened in google too, and 80% of all the other websites I go to. Then I think it's FF's fault, but then I fire up IE9 and get the exact same thing! I already did a system restore, several days back, that didn't correct anything. I tried this too: http://support.mozilla.com/en-US/kb/...hows%20up%20bold%20after%20upgrade
Didn't work.
I've tried to extract fonts from the win7 disc then overwrite them but can't seem to find them on the disc.
Going to the fonts control panel and resetting everything to default doesn't help either.
From what I've been Googleing like mad it seems like people just end up reformatting, and even then the problem may come back.
So I'm trying to avoid formatting at all costs. I know very well how to do it but I'll admit it's kind of a blow to my ego since I haven't had to format a computer due to a glitch in years, I ALWAYS have found a solution, and frankly I think there has to be an explanation for such a silly yet annoying glitch.
Any ideas?
ALTF4
RE: Help! Corrupted Fonts In Win7
Fri Mar 25, 2011 2:32 pm
Are the OS fonts different? For example, are the menu bars or the items in the start menu different than they were before?
The above post is my opinion. Don't like it? Don't read it.
ALTF4
Fri Mar 25, 2011 2:36 pm
One other thing - A.net always shows a little more 'bold' in Safari for me and any WebKit based browser, most likely just due to rendering differences. Could you screenshot how the site looks and post it? Did you ever open IE9 before you had FF4 installed? If so, did it render things 'normally' before FF4? I'm assuming you mainly used FF3 before....
Fly2HMO
Fri Mar 25, 2011 3:41 pm
Quoting ALTF4 (Reply 1):
Nope, weirdly all the OS fonts are unchanged.
Quoting ALTF4 (Reply 2):
FF and IE had always looked exactly the same font-wise, I haven't used safari in forever but it did look a bit different, but not so obvious. Chrome was the same as IE and FF. But I'm almost certain this is a font screw-up and not some funky rendering problem.
Google looks the same.
Yup, it was fine before.
Yeah I use FF 99% of the time. This is the first time it has failed me. I just don't see why the heck it would mess up my fonts.
I guess I could wait for an update to FF and hope for the best but they take forever to release them and I doubt that would fix anything in my other browsers
ALTF4
Fri Mar 25, 2011 5:31 pm
I can't seem to reproduce the issue on WinXP.... but I'll take a look at it when I get home on Win7.
I'm not convinced its really the Windows fonts right now. I've got some ways to freeze changes on certain directories on my computer @ home so I'll try that then install FF4 and see if I get a similar issue. If I do, its not the fonts, as no fonts would have changed. If I don't... well... it could be the fonts or something else.
In the meantime, try this:
•Open Mozilla Firefox 4, go to the address bar and type about:config
•Search for the property gfx.direct2d.disabled
•Double click on it to set it to True.
Restart FF. If it doesn't fix anything, then undo the changes.... but I have a feeling it might do something for you. Granted, its hard to diagnose over the interwebs...
[Edited 2011-03-25 10:32:14]
ALTF4
Fri Mar 25, 2011 5:41 pm
And check this out: http://pinoytech.org/su/question/261...x-4-is-displaying-all-text-as-bold
Either download the fonts from the link on sourceforge, or insert you Win7 DVD and open the install.wim using 7-zip (Google it)... open the 4 or 5 directory, then go to the windows directory and find fonts. Copy Arial, paste into your Windows install font folder, and ***install the font by clicking install in the menu bar***.
I'm going on memory from opening the install.wim image, so I might be off a little on the exact path to it.
Looks like we're both right - hardware acceleration in FF4 will mess things up, but only messes things up because of an issue (that it made I suppose) with the arial font in the fonts folder. As a result, all pages that have arial on them will be fuzzy/blurry or bold, depending on the computer.
Strange thing is, A.net lists Arial as the third preferred font. I guess FF or win7 don't have the other two fonts.... or maybe those are messed up as well and need to be 'fixed' too.
Lots of speculation on my part, hopefully some of it helps.
Fly2HMO
Fri Mar 25, 2011 6:04 pm
Quoting ALTF4 (Reply 5):
Finally, that did it! Though I had tried a variation of that and that initially didn't quite work out.
Thank you, good sir!
Now that it works the "normal" text in FF4 does indeed look a bit different compared to FF3, looks like IE9 text actually. Hardware acceleration at work I presume.
[Edited 2011-03-25 11:08:54]
ALTF4
Fri Mar 25, 2011 6:18 pm
Quoting Fly2HMO (Reply 6):
Good, glad it worked!
If you'd like, you can turn of FF4 font hardware acceleration (come on now, fonts are a few pixels... the CPU can handle that) using the about:config thing I posted earlier. You'd be better off doing that than unchecking the "hardware acceleration" box in the options menu, becuase that could affect Flash and HTML 5 video.
I'll bet you get used to it over the next week though
Cheers!
Fly2HMO
Fri Mar 25, 2011 6:43 pm
Quoting ALTF4 (Reply 7):
Well I ended up uninstalling FF4 altogether, went back to FF3. I was extremely disappointed. I mean its great, IF it works. It is extremely buggy and crashes every 5 minutes. I guess I'll wait till they put out an update. FF3 was super reliable.
[Edited 2011-03-25 11:52:04]
Geezer
Sun Apr 03, 2011 4:40 am
Here's an even better idea; buy yourself a Mac and never have to worry with all those problems again ! As long as you stick to windows and PC's you're gonna have problems !
Stupidity: Doing the same thing over and over again and expecting a different result; Albert Einstein
Fly2HMO
Sun Apr 03, 2011 8:33 pm
Quoting geezer (Reply 9):
cerretaman
Sun Apr 03, 2011 8:57 pm
I have had nothing but PCs and never had any major problems.
u mad cause i'm stylin' on you?
Springbok747
Sun Apr 03, 2011 9:02 pm
That was clearly not the answer the OP was looking for...
In any case..
אני תומך בישראל
Users browsing this forum: mmo, wingman and 3 guests
