jetblue777
Algebra: Solve This Problems
Thu Apr 14, 2011 2:08 am
Got the idea from the math problem thread, this is a little bit complicated because it’s word problem. And No, this is not my homework. LOL. It was in the Integrated Algebra Regents (NY)
1) A group of 148 people is spending five days at summer camp. The cook ordered 12 pounds of food for each adult and 9 pounds for each child. A total of 1410 pounds of food was ordered. Find the total number of adults and children in the group.
You have to solve it by using elimination
Show All Work.
2) Find the perimeter of the square whose diagonal is 12. Write your answer in simplest radical form.
Enjoy
It's a cultural thing.
Ken777
RE: Algebra: Solve This Problems
Thu Apr 14, 2011 2:32 am
I liked the other math thread - the answer was 2.
I'll pass on this one, however, as I'm on a diet.
dc9northwest
Thu Apr 14, 2011 2:44 am
1) The total amount of adults and children in the group is 148--unless you count infants separately.
2) Too simple. I'm afraid I'll give it away if I say it.
Airstud
Thu Apr 14, 2011 2:48 am
For the first one, all I've gotten so far is
a = number of adults
c = number of childrens
12a + 9c = 1410
Except how bad am I at algebra? I have no clue what the next step is, that's how bad. Nice going.
The second one I think is pretty easy; the diagonal of a square cuts yon square into two right triangles; so we need only to use the Pythagorean theorem. The diagonal is the hypotenuse, and the hypotenuse squared equals the sum of the squares of the other two sides. So if the diagonal of the square is 12, its square of course is 144; and since this is a square we know the other two sides will be the same length; the sum of their squares must equal 144 so the square of each side is 72. The square root of 72 is 8.48528137etc; multiply this by cuatro and we get the perimameter: 33.9411254 etc.
Whew - I think I at least know something!
[Edited 2011-04-13 19:49:41]
Pancakes are delicious.
KingFriday013
Thu Apr 14, 2011 2:51 am
For #1:
Set up two equations:
12x 9y=1410 and x + y=148
Let's simplify the first one to 4x + 3y=470 (divide both sides by 3).
And the second one to 3x + 3y = 444 (multiply both sides by 3).
Note that both of these have the term "3y" in them.
So if we just subtract one from the other
(4x 3y) - (3x 3y) = 470 - 444 = 4x + 3y - 3x - 3y = 4x - 3x = x = 26
So we get x = 26.
At this point we can just plug in x to our original equation (either one).
x + y = 148 = 26 + y
Therefore:
148 - 26 = y = 122
So y = 122.
Therefore there were 26 adults and 122 children.
#2:
We know the diagonal is 12. Hence, by the Pythagorean Theorem, which states a2 + b2 = c2, and since the square has four identical sides (i.e., a = b):
122 = 144 = 2a2
We divide both sides by two and get
72 = a2
Take the square root of both sides and we get
√72 = √a2 = a
Since we have 4 sides, we multiply our value by 4, i.e., 4√72. This further simplifies to 24√2, which is the answer.
-J.
EDIT/NOTE: For some reason the plus signs aren't staying when I push "Post The Message!" If there's a blank space between the numbers then pretend there's a plus sign. If you want, send me a message through my profile and I'll just email this to you. j
[Edited 2011-04-13 19:58:33]
Tho' I've belted you an' flayed you, By the livin' Gawd that made you, You're a better man than I am, Gunga Din!
Maverick623
Thu Apr 14, 2011 2:54 am
Quoting JetBlue777 (Thread starter):
Quoting Airstud (Reply 3):
Fail.
Answer is 24√2
Still working on the first one...
"PHX is Phoenix, PDX is the other city" -777Way
Maverick623
Thu Apr 14, 2011 3:00 am
Quoting KingFriday013 (Reply 4):
Let's simplify
Gosh darn it.... it's always the simple steps that throw me off on these. I couldn't figure out how to merge the two equations.
trvyyz
Thu Apr 14, 2011 3:16 am
2 unknowns need 2 equtions to solve
A+C=148 ie, C=148-A ------------ (1)
12A+9C=1410 ----------------------(2)
12A+9(148-A)=1410
=>3A=78; A=26, C=148-26=122
Second
12=sqrt(x^2+X^2)=Sqrt(2X^2)=Xsqrt(2)
=>X=12/sqrt(2)
perimeter=4X= 4*12/sqrt(2)=2*sqrt(2)*12=24*sqrt(2)
ie, 24√2
CXfirst
Thu Apr 14, 2011 3:24 am
1. Using Augmented Matrices (not that it is necessary for this easy example, but it is neater for presentation).
x = number of children
y = number of adults
x + y = 148
9x + 12y = 1410
[ 1 1 | 148 ]
[ 9 12 | 1410 ]
[ 1 1 | 148 ]
[ 0 3 | 78 ] R2 --> R2 - 9xR1
using back substitution
3 y = 78
y = 26
x + y = 148
x + 26 = 148
x = 122
There are 122 children and 26 adults in the camp.
2.
The diagonal of a square is one which creates two right angle triangles, with a 2 angles of 45 degrees within them.
This is a special triangle with sides equivalent of a ratio 1:1:sqrt(2)
giving one side of the triangle length x, you get the ratio
x/1 = 12/sqrt(2)
x = sqrt(144)/sqrt(2)
x = sqrt 72
perimeter = 4x
p = 4sqrt(72)
p = 24sqrt(2) This is the simplest radical form
seb146
Thu Apr 14, 2011 3:50 am
The immediate area around JetBlue777 would be my answer...
148. People over-think things.
Patriotic and Proud Liberal
DocLightning
Thu Apr 14, 2011 5:30 am
I did this all 20 years ago. Since then I've earned three degrees.
I'm not doing it again.
-Doc Lightning-
-Carl Sagan
Mir
Thu Apr 14, 2011 5:45 am
Quoting seb146 (Reply 9):
I like it.
And you're correct, too - if they had wanted the total numbers (plural) of adults and children, then you'd have to go through the whole simplifying two equations deal, but they already gave you the answer, so why bother?
Just goes to show that math people shouldn't try and write word problems without a grammatical consultant.
-Mir
[Edited 2011-04-13 22:58:14]
akiss20
Thu Apr 14, 2011 6:03 am
http://i.imgur.com/nzdmf.jpg
Let's step it up a notch
Comeon Doc, you got this!
Change will not come if we wait for some other person or some other time. We are the ones we've been waiting for. We are
DocLightning
Thu Apr 14, 2011 7:14 am
Quoting AKiss20 (Reply 12):
As soon as you identify this diagnosis:
http://aapredbook.aappublications.org/content/images/large/2006/1/124_79.jpeg
-Doc Lightning-
-Carl Sagan
Mir
Thu Apr 14, 2011 7:19 am
Quoting DocLightning (Reply 13):
A kid is sick.
-Mir
DocLightning
Thu Apr 14, 2011 7:25 am
Quoting Mir (Reply 14):
A kid is sick.
Yes. He's miserable. T=101.2° F (38.4° C) since Sunday, generally higher at night, lower in the morning. The ibuprofen makes it better for a few hours. He's not eating, either. And he itches. Oh, does that rash itch. Mom's tried Benadryl but it doesn't do anything.
You have to help him, Dr. Mir and Dr. Kiss! Look at the poor little guy!
-Doc Lightning-
-Carl Sagan
Mir
Thu Apr 14, 2011 7:42 am
Quoting DocLightning (Reply 15):
Hey, I'm not the one trying to one-up people with crazy technical knowledge. I have no clue what that is. My best WAG is some sort of food allergy - I had something like that once (though not nearly as extensive), and it went away in a few days. But I'm not a doctor, nor do I play one on TV, nor did I stay at a Holiday Inn Express last night, so...take that and $6 and buy yourself a coffee at Starbucks.
In my experience, Benadryl doesn't do jack - the only thing it's good for is putting you to sleep. Which does make you stop itching, but only by virtue of being unconscious.
-Mir
KingFriday013
Thu Apr 14, 2011 9:22 am
Quoting Mir (Reply 16):
I was really enjoying this thread... until all that happened...
Anyway, for the people who were saying #1 is simpler than it looks, I just assumed that the original poster meant to ask for the total number of adults and the total number of children as separate entities -- as would be expected on a NYS Regents Exam. They wouldn't do something stupid like that... and if they did, they would want the separate numbers as well.
-J.
Springbok747
Thu Apr 14, 2011 10:11 am
Addisons disease?
אני תומך בישראל
Luftfahrer
Thu Apr 14, 2011 11:30 am
Measles?
ojas
Thu Apr 14, 2011 12:06 pm
Show All Work
Let number of adults be x, number of children be y.
So total people is x+y = 148 ---> equation (1)
9 lbs per child and 12 lbs per adult which comes to a total of 1410
12x + 9y = 1410 --> equation (2)
you have to solve these equations
12x + 9y = 1410 (2)
x + y = 148 (1)
Multiply (1) by 9
12x + 9y = 1410 (2)
9x + 9y = 1332 (1)
Now subtract .... do (2) - (1)
you get 3x = 78 (as 9y - 9y equals zero) which means x = 26 which means adults are 26 and the number of children are x + y = 148; 26 + y = 148; which means y = 122 which means there were 26 adults and 122 children
The area of a square is also expressed as "half of the product of the diagonals ". the rule is valid for all Rhombuses (i.e quadrilaterals with equal sides).
So the area of this Square = 1/2 * 12 * 12 = 72 sq. units
Which means length of each side is Square root of Area = sqrt of 72 = 6 * sqrt 2
So the premieter is 4 times the length of each side = 24 * sq rt of 2
DocLightning
Thu Apr 14, 2011 2:20 pm
I'll give you a big hint that if you google it, you will get the answer.
That tongue looks like a strawberry... (sorta). Strawberry Tongue.
-Doc Lightning-
-Carl Sagan
seb146
Thu Apr 14, 2011 3:22 pm
Quoting DocLightning (Reply 21):
Yes. I googled your hint and it became very obvious. I will give Mir a chance to respond.
My answer for this one is "banana"
garnetpalmetto
Thu Apr 14, 2011 3:44 pm
Based on that back rash, I'd guess Scarlet Fever. No I'm not a doctor, though I often curse you people to the heavens. Why oh why can' t you people write medical records legibly?
South Carolina - too small to be its own country, too big to be a mental asylum.
baroque
Thu Apr 14, 2011 3:53 pm
Quoting DocLightning (Reply 10):
Reminds me of a old, old question from the 11+ exam in the UK. The following letters are part of an infinite series:
O..T..T..F..F..S..S
What are the next three letters in the series?
Plea for mercy, use only simple methods.
garnetpalmetto
Thu Apr 14, 2011 4:04 pm
Quoting Baroque (Reply 24):
O..T..T..F..F..S..S
E..N..T
This one's rather simple. Each letter is the initial letter in a number (One, Two, Three, Four, Five, Six, Seven). Thus Eight, Nine, and Ten would be next.
Moose135
Thu Apr 14, 2011 4:10 pm
O..T..T..F..F..S..S
E...N...T
Eight
Nine
Ten
baroque
Thu Apr 14, 2011 4:11 pm
Quoting garnetpalmetto (Reply 25):
E..N..T
Indeed. But it turns out that the success rate for 11 year olds is much much higher than for 20+. And even worse if you try it on unsuspecting mathematicians. The maths folk work out that the double letters are nearly symmetrical around the middle of the alphabet and the only thing that worries them is how a series starts out with single letters and then doubles.
All depends on how difficult a problem you think it is.
As someone remarked about the initial question
A group of 148 people is spending five days ...... Find the total number of adults and children in the group.
Answer, 148! No algebra required. Just reading skills.
Dazed767
Thu Apr 14, 2011 4:30 pm
I suck at math, but that is scarlet fever.
dc9northwest
Thu Apr 14, 2011 4:47 pm
Geez, people actually solved the first problem   I'm surprised. I remember doing this sort of problem probably around 4th grade... But I'm in college-level Analysis now, and math does not include any numbers anymore
petertenthije
Thu Apr 14, 2011 5:36 pm
148 * 9 = 1332 - people multiplied by childrens portion to get minimum requirement of food
1410 - 1332 = 78 how much more food had been ordered above the minimum requirement
78 / (12-9) = 26 the amount of people that have bigger rations (= adults)
148 - 26 = 122 the kids
Thus: 122 kids and 26 adults calculated without the hassle of algebra.
Attamottamotta!
fridgmus
Thu Apr 14, 2011 5:38 pm
That's why I went to welding school, so I wouldn't have to do stuff like this!!!
F
The Lockheed Super Constellation, the REAL Queen of the Skies!
DocLightning
Thu Apr 14, 2011 6:07 pm
Quoting garnetpalmetto (Reply 23):
DINGDINGDINGDING!!!
We have a winner!
And the most (academically) appropriate treatment is?
The treatment we'd actually use is?
-Doc Lightning-
-Carl Sagan
akiss20
Thu Apr 14, 2011 6:39 pm
Quoting seb146 (Reply 22):
That's my theory for questions I don't know, write something amusing and pray the graders have pity on me. I remember on one intro bio pset there was a question as to why some genetic disease was more prevalent in Eastern European cultures. I had no idea so I put some BS down about how EE cultures encouraged inbreeding in the elite. Answer was totally wrong but the grader wrote "hilarious! +5" and I called it a good day.
@Doc. Academically use penicillin, clindamycin or erythromycin? Actually, no idea
ANITIX87
Thu Apr 14, 2011 6:41 pm
Quoting DocLightning (Reply 32):
Standard antibiotics. Pennicilin or erythromycin, IIRC. My dad had scarlet fever when he was little. And is a molecular biologist. So I've picked up some random knowledge I never thought I'd need.
TIS
garnetpalmetto
Thu Apr 14, 2011 6:44 pm
Ship 'em off to a leper colony and be done with 'em?
Seriously not sure what the academically appropriate treatment is, but an antibiotic course, usually penicillin. If the kid is allergic, then erythromycin. Keep the tyke out of school so the little darling doesn't infect any other little darlings. No clue what to do with the rash or the itchiness though.
DocLightning
Thu Apr 14, 2011 7:20 pm
Quoting AKiss20 (Reply 33):
Quoting ANITIX87 (Reply 34):
Penicillin V-K is the most appropriate medication. Erythromycin (really, Azithromycin) is used in the truly allergic patient. In the patient who gets a "rash" for penicillin/amoxicillin, I use cephalexin, which has less than 10% cross-reactivity.
Group A Beta-hemolytic strep, which causes strep throat (and thus, scarlet fever) remains exquisitely sensitive to penicillin. That and syphilis are the only two bugs that have never evolved a way around good, old-fashioned Penicillin.
However, penicillin oral suspension tastes like fungus and must be dosed three times daily for ten days. So most of us use amoxicillin, which tastes like bubble gum and may be dosed twice daily.
-Doc Lightning-
-Carl Sagan
Continental
Thu Apr 14, 2011 7:32 pm
Quoting DocLightning (Reply 36):
Whew! Good thing he was treated or that could have led to rheumatic fever! Right? What a coincidence, I'm studying microbiology right now!
garnetpalmetto
Thu Apr 14, 2011 7:43 pm
I still like my suggestion of shipping them off to a leper colony
Maverick623
Thu Apr 14, 2011 8:37 pm
Well, penicillin being basically fungus dung....
My best memories of being sick as a kid were getting prescribed amoxicillin. Yummm.
DocLightning
Thu Apr 14, 2011 8:59 pm
Quoting Continental (Reply 37):
Acute Rheumatic Fever is a rare but very serious complication of Group A strep infections including scarlet fever. It tends to occur 1-3 weeks after the infection clears, assuming that the infection was not treated within 10 days of onset.
Acute Rheumatic Fever is an autoimmune phenomenon thought to be triggered by the "M" protein on the Streptococcus bacterium. In ARF, there is fever, rash, arthritis and, most importantly, inflammation of the valves of the heart. So this can cause long-term heart issues.
The vast majority of patients with untreated strep infections do not develop acute rheumatic fever, but the consequences are so dire that we are aggressive about diagnosing and treating these infections.
Scarlet fever is caused by a strain of Group A Strep that elaborates a toxin similar to that of poison ivy. So in addition to the sore throat, the child develops the characteristic rash. Scarlet fever was once a very serious illness, but in the last century the strains of bacteria that cause scarlatina seem to have gotten less virulent (which may or may not have anything to do with antibiotics) and so the kids are ill, but usually not frankly toxic. The treatment is the same as for any other strep infection, plus symptomatic treatment for the rash to make the child more comfortable while the antibiotics work their magic.
-Doc Lightning-
-Carl Sagan
Mir
Thu Apr 14, 2011 9:15 pm
This thread is officially squawking 7500.
-Mir
jetblue777
Thu Apr 14, 2011 9:16 pm
For #1:
So we get x = 26.
Therefore:
148 - 26 = y = 122
So y = 122.
#2:
122 = 144 = 2a2
72 = a2
√72 = √a2 = a
-J.
Yes, both answers are correct and with all the necessary steps that you have to write to get the full points on the NYS Regents.
Now that you've mentioned it, they did mess up with the wording, but since it's a NYS Regents Exam, it's pure logic that you have to do all the algebraic steps and equations. Good catch, I shall tell my teacher tomorrow.
KingFriday013
Fri Apr 15, 2011 4:20 am
Quoting JetBlue777 (Reply 42):
They made mistakes like that when I took the Regents too. I don't think they'll ever learn...
-J.
Users browsing this forum: Dreadnought, salttee, seb146 and 2 guests
