varigb707
Any Ubuntu Users Here? Need Your Help
Thu Jul 14, 2011 8:12 pm
So i downloaded Ubuntu version 11.04, "Run It With Windows" option. Works fine, except for the wireless part.
I tried everything i could, but the darn wireless, didn't work.
Any ideas or suggestions, on how to fix this issue? BTW, i installed on an old Compaq V2000 with XP Professional.
Thanks for any help.
First, I said 'hey' and then I said 'now'. "Hey Now!" - Hank K.
CplKlinger
RE: Any Ubuntu Users Here? Need Your Help
Thu Jul 14, 2011 9:05 pm
It could be a drivers issue. The tricky part about wireless cards in notebooks can be finding out exactly which card you have (Device Manager in Windows may not tell you enough info to get the right one). The spec sheet for the V2000 lists the following cards
Mini PCI communications cards
802.11b/g Broadcomm (for use in most of the world)
802.11b/g Broadcomm (for use in the rest of the
world)
802.11b/g Broadcomm (Japan, for use only on
HP Compaq nx4800 models)
802.11b Intel (for use in most of the world)
802.11b Intel (for use in the rest of the world)
802.11b/g Intel (for use in most of the world)
802.11b/g Intel (for use in the rest of the world)
Bluetooth® Wireless LAN
You might have to open up the cover on the memory compartment to look at it and get the info on exactly which one you have, so you can find the correct drivers for it. Intel and Broadcom are pretty good about Linux drivers, you just have to be choosy about which driver you need.
varigb707
Fri Jul 15, 2011 1:01 am
Quoting CplKlinger (Reply 1):
CplKlinger
Thanks for your reply. I'll take a look at it. Cheers.
HS
