DocLightning
What Will Be The Next Portable Energy?
Thu Dec 22, 2011 6:42 pm
So at some point, combustion is going to have to go. Either we're going to run out of fossil fuels, mess up the planet to the point where we actually have to stop, or move somewhere without a ready supply of oxygen.
When that happens, energy will probably be generated mostly by nuclear fusion I'd imagine. But how will energy-dense mobile requirements be met?
Today, the most efficient way to transport energy is with fuel. Short of nuclear fuel (which has an enormous energy density by mass but requires even more enormous reactors to extract it), hydrocarbon fuels have the highest energy density per mass of any form of energy storage. This is why it runs cars, ships, trains, and planes.
Will it be supercapacitors? Will it be hydrogen/oxygen from hydrolysis? Something more exotic?
How would you power an airplane on Mars? Hydrazine?
-Doc Lightning-
-Carl Sagan
DfwRevolution
RE: What Will Be The Next Portable Energy?
Thu Dec 22, 2011 9:45 pm
Quoting DocLightning (Thread starter):
If we were serious about reducing oil consumption, we would substitute natural gas for transportation fuels like gasoline, diesel, and kerosene. No one alive will live to see the day when we will run out of natural gas. There is a stupid amount of proven natural gas and discoveries are outpacing production. Natural gas is a step-change cleaner and more economical than gasoline and diesel.
There is no reason to believe we will "actually have to stop" burning fossil fuels.
Tugger
Thu Dec 22, 2011 9:48 pm
Tiny jet turbine generators built on the nano level. They'll be small enough to fit inside button-cell battery size-shape.
Tugg
DfwRevolution
Thu Dec 22, 2011 9:56 pm
I guess I'm being a bad sport by saying combustion will all out live us. Playing along now...
It's not an unreasonable assumption that chemical batteries will continue to improve in power density. High-strength materials are continuously becoming stronger, lighter, and more economical. Compressed gas could be a feasible energy storage method.
Mars mission architect Robert Zubrin has advocated the use of a Sabatier reaction to produce methane and oxygen from hydrogen and CO2 in the Martian atmosphere. From our current understanding of the Mars hydrosphere, you would still need to bring the hydrogen to Mars, but 8 tons of LH2 would yield 112 tons of oxidizer/propellant.
DocLightning
Fri Dec 23, 2011 12:13 am
Quoting dfwrevolution (Reply 1):
If we are, say, colonizing mars, then that won't work. Even if there were natural gas there (and there isn't), there's no oxygen.
-Doc Lightning-
-Carl Sagan
DeltaMD90
Fri Dec 23, 2011 12:19 am
I'm rooting on algae. Some report 'said' (take that how you want it) that it will be viable around 2018. It creates CO2 but sucks up CO2 when produced. It can be farmed on arid land (or anywhere really,) even using sewage. It produces more fuel and at a faster rate than other bio fuels. Go algae!!!!!!!!!!
Ironically I have never flown a Delta MD-90 :)
LGWflyer
Fri Dec 23, 2011 12:24 am
Quoting DeltaMD90 (Reply 5):
Sounds interesting! Might have a look on google for some info about it.
3 words... I Love Aviation!!!
DocLightning
Fri Dec 23, 2011 12:45 am
Vertical photobioreactor-grown algae is the way to go. The big problems are scaling the production facilities up enough to produce enough fuel (it would take a few hundred acres of desert somewhere) and the fact that the algae grow SO quickly that they actually need to be fed concentrated CO2. You can't just blow air through the bioreactors.
-Doc Lightning-
-Carl Sagan
DeltaMD90
Fri Dec 23, 2011 12:46 am
Quoting LGWflyer (Reply 6):
http://en.wikipedia.org/wiki/Algae_fuel
And IIRC, that Continental flight a few months ago that was 100% biofuel was algae. I *think*
As far as mass produced energy, I foresee wind and solar and all picking up, but I think the big breakthrough will be cold fusion...
DeltaMD90
Fri Dec 23, 2011 1:49 am
Quoting DocLightning (Reply 7):
Oh, then just build them in Pittsburgh
AustrianZRH
Fri Dec 23, 2011 7:29 am
I think the LS9 approach is quite promising (using cellulosic biomass as feedstock for biofuels created by genetically designed bacteria).
www.ls9.com
WARNING! The post above should be taken with a grain of salt! Furthermore, it may be slightly biased towards A.
kpitrrat
Fri Dec 23, 2011 7:32 am
The way this world is going.....Wood.
[Edited 2011-12-22 23:33:05]
qf002
Fri Dec 23, 2011 11:21 am
Heat induction... Your mobile phone sits in your pocket all day, absorbing the heat that your body radiates, why not find a way to turn that heat into the electricity that powers it?
jollo
Fri Dec 23, 2011 3:12 pm
One possible and convenient way to quickly replace fossil fuels is through the so-called "methanol economy". Methanol is the simplest alcohol (CH3OH), liquid and stable at room temperature, and can be burned in internal combustion engines and turbines with very few modifications. It can also be transported and distributed with the existing transport infrastructure used for petroleum derivatives (pipelines, supertankers... down to the local gas station). So, unlike with hydrogen, you can switch to a methanol-based economy with minimal infrastructure changes.
Methanol can be produced from CO2, water and sunlight: basically, you electrolyse water using power generated by a solar panel (2 H2O + e → O2 + 2 H2), discard O2 in the atmosphere, put H2 in a reactor with CO2 taken from the atmosphere (needs a cheap metallic catalyser, plus some heath and pressure also powered by the solar panel) et voilà: CO2 + 3 H2 → CH3OH + H2O. Recycle H2O into the process (thus lowering H2O demand by 33%) and collect methanol for transportation.
Burning methanol and air (e.g. in an internal combustion engine) will create CO2 (2 CH3OH + 3 O2 → 2 CO2 + 4 H2O), but if it is produced with the above described process (getting CO2 from the atmosphere), the production-combustion cycle is carbon-neutral and leaves no pollutant by-products (aerosols, NOx, aromatic hydrocarbons, etc..).
Methanol does has a few problems to be worked around: it is highly corrosive for aluminium (and a few other metals, anti-corrosion treatments notwithstanding), so a few components along the whole cycle might have to be re-designed accordingly. Methanol’s specific energy density (19.7 MJ/kg) is less than half than gasoline's (46.4 MJ/kg), but packing a little less punch in your car engine will not kill anyone (in your aicraft engine that might be a slightly worse problem...  Smile but I'm confident ways around can be found). It is toxic if ingested, but not more than gasoline. On the other hand, unlike gasoline, it is very bio-degradable (7 days half-life in water).
The real problem is that feeding production with atmospheric CO2 gives very low production yields: you would need to crop the whole Sahara for sunlight and CO2 in order to compete with middle-east petrol production (just imagine the piping network needed to feed production with water!). So basically the only drawback is that jump-starting a methanol economy would be very capital-intensive: mind you, not a lot more than our petroleum-based economy, but much of that capital has been invested spread over a century or so. Another little problem is that current investors will not be very welcoming of a competing economy needing only sunlight, water and lots of free land...
But, if anyone wants to invest in the idea, I'm all for it!
Cheers!
[Edited 2011-12-23 07:16:44]
Klaus
Fri Dec 23, 2011 7:54 pm
Quoting qf002 (Reply 12):
The main problem with that is indeed interesting: It is already very much possible to extract energy from heat, but thus far only from a difference in temperatures, not from absolute heat.
The phone in your pocket is pretty much uniformly at body temperature (or not far from it). The temperature differential is too low to be exploited efficiently with current technology.
At least for planetary energy needs a converter which turns absolute heat into electrical energy would pretty much solve all our problems (a kind of thermal battery which gets cooler when you extract electric energy from it and which is powered by the absolute heat around it).
That would effectively be the holy grail of terrestrial energy – everything else is much more cumbersome. We "just" haven't discovered the way around the laws of thermodynamics which would be necessary for that. Not a piece of cake since you'd need to establish conditions outside of their base assumptions (ordered materials not just behaving statistically on the atomic and molecular level).
So unfortunately until someone cracks this problem, we'll probably have to settle for the usual methods (various electricity generation methods plus renewable sources of combustion fuels such as solar algae reactors).
For serious space exploration none of that would really "fly" since chemical fuels carry too little energy and even with hypothetical thermo-converters there would be too little thermal energy in most regions of space – some kind of nuclear energy source would probably be the only way to generate enough energy to efficiently travel in space. Star Trek proposed matter/antimatter reactions, but fusion or fission could theoretically work as well if the weight/mass requirements and the radiation problems of the respective reactors could be solved (don't hold your breath).
Users browsing this forum: Airstud, Bing [Bot], TheF15Ace, tommy1808, WIederling and 2 guests
