kaitak
Arab States Want To Invade Syria?
Fri Feb 24, 2012 7:10 pm
In an interesting - potentially explosive - development, Arab States (led by Qatar and Saudi Arabia) - have voiced support for a plan for direct involvement in Syria.
http://news.sky.com/home/world-news/article/16176096
Quite apart from the significance of Arab states taking this stance, there are significant issues to be discussed here:
1. On the regional chessboard, this has the potential to isolate Iran; how will it react? Saudi Arabia is too big to hit, but Qatar ...?
2. How would the mechanics of this work; would Iraq and/or Jordan allow Saudi troops to cross its borders, or even participate; I could see Jordan being involved, but given the ability of Iran to make life very difficult for Iraq, if it put its mind to it, I couldn't see Iraq being involved (although it could probably be persuaded to turn a blind eye to the use of its airspace?)
3. What's the goal here? What kind of a government would the Wahhabist Saudi authorities want to put in place. Like Iraq, Syria - although very repressive - was not as hardline about the repression of women as Saudi Arabia is; what would it gain from this?
4. How would Israel feel about this; somehow I don't see the Arab League phoning Netanyahu for his views, although I can't think that Israel would object greatly to Assad being bounced out on his rear end.
5. How long would the Syrian army be able to hold out against KSA and other Arab states; could this actually be an "all-Arab" affair?
In the context of the whole Middle East situation, a very interesting development; it will be interesting to see Iran's response to this.
johns624
RE: Arab States Want To Invade Syria?
Fri Feb 24, 2012 9:17 pm
I believe that they want the UN or NATO involved to do the "real" fighting.
SOBHI51
Fri Feb 24, 2012 9:21 pm
They want to send forces to defend the civilians, that is not similar to an invasion.
GIANCAVIA
Fri Feb 24, 2012 9:35 pm
None of them will invade, All no balls nations who purchased military equiptment to control their own populations. Which one of them can lecture the Syrians on the way its treating its population without looking at itself as a major hypocrite?
Bahrain? Saudi? Yeah right..
Realisticly it will drag on a little longer.. Then the Russians/Chinese will be influenced to exert a little pressure and it will die down but probably continue at a level where the rest of the world fails to care.
I would be surprised if it ended differently.
SOBHI51
Fri Feb 24, 2012 9:43 pm
Quoting Giancavia (Reply 3):
Well then i suggest you go there as a reporter and lets see if your if this is the ending you predicted.
Just like to remind you that the number of killed people so far is over 12,000.
GIANCAVIA
Fri Feb 24, 2012 9:49 pm
Quoting SOBHI51 (Reply 4):
What would me going there as a reporter achieve exactly? I dont even understand your point to be honest..
I dont remember denying large numbers of people have died or condoned it. I said what I see happening, No Arab states will invade.. Be realistic.. and none of those states have a leg to stand on when they shoot people protesting in their own countries. What gives them the moral highground? Fewer innocent people killed? heh..
mercure1
Fri Feb 24, 2012 9:53 pm
What I find quite bizarre is the lack of will, or care about Syria until only recently compared to Libya.
Things in Libya were no where as bad the as mass slaughter day after day of civilians by the Syrian government but the world has chosen to mostly look the other way for the last 12-months.
Pretty amazing what the lure, or in this case lack of petrol does....
zckls04
Fri Feb 24, 2012 10:01 pm
Quoting mercure1 (Reply 6):
The reason why nobody wants to go into Syria is that, unlike in Libya, there is not a cohesive opposition force with clear leadership. The Libyans were organised and pretty clear in their objectives- they just needed a bit of a helping hand, which was why the war was quick and relatively easy. Not so in Syria where the opposition is divided and unclear in its aims. Civil war is the likely outcome.
Four Granavox Turbines!
SOBHI51
Fri Feb 24, 2012 10:02 pm
Quoting Giancavia (Reply 5):
Well you never acknowledge it, and by comparing what is happening in Bahrain with Syria you are putting 24= over 12,000
And when was the last time when KSA used it's F15 or there naval forces or even tanks to kill there own people?
Again the Arab armies will go there to set a buffer zone between the civilians and the Syrian army, it happened before in Lebanon.
GIANCAVIA
Fri Feb 24, 2012 10:06 pm
I think the lack of "petrol" is irrelevant on this one. Russia has Military bases in Syria & a Veto. Until its influenced enough with other sweetners to convince Assad to stop I think it will continue. There is not alot people can do otherwise.. As per usual just talk talk talk and watch people die unfortunately.
At most I think you may see the Saudis or the Americans arm the "rebels" but look how that has turned out in Libya.
GIANCAVIA
Fri Feb 24, 2012 10:12 pm
Quoting SOBHI51 (Reply 8):
I am a Human being.. I dont need to acknowledge that civilians being bombed or murdered is a bad thing.. it should be expected anyone would find that disgusting naturally.
Numbers are irrelevant.. on a global polotical scale. How can Bahrain lecture about innocent civilians being killed when it killed its own unarmed people that were protesting? They have zero credibility making their statements look hypocritical. Same with Saudi and its Human rights.. how can these voices carry any weight when they dont practice what they preach?
There will be no buffer zone dude..
Not until the minds of the Russians are changed.
SOBHI51
Fri Feb 24, 2012 10:19 pm
Quoting Giancavia (Reply 10):
When you send an army to be a buffer zone you need the approval of both sides, no?
Here where Russia should play a role, that is if they value human life more than a couple of bases.
prebennorholm
Sat Feb 25, 2012 2:33 am
There are a few geopolitical issues:
1. Russian naval bases are at stake.
2. Iranian oil for China is at stake.
3. One day the Russians would like to see payment for their weapons deliveries. A new Syrian government is unlikely to consider payment for the weapons used against themselves to be a high priority issue.
Quoting SOBHI51 (Reply 2):
...the Arab armies will go there to set a buffer zone between the civilians and the Syrian army...
When Syrian military is shelling cities from its outskirts, then creation of a buffer zone means invasion and war. No more, no less. I don't see any relevant countries which are able to do that.
The most sensible proposal I have seen is from Turkey: To create border-zone refugee camps. Even if doing nothing more than that most likely means that Syria digs itself deeper into the swamp of Somalia, Sudan and such over the next few years or even decades. Or like Congo in the 60'es, 70'es and 80'es, and still not fully solved.
It is hard to be an optimist. Only one thing is sure: Syria will never be the same again. That said, they have always left a lot of room for improvement.
L410Turbolet
Sat Feb 25, 2012 3:09 am
Quoting SOBHI51 (Reply 11):
Russia is fully supporting Asad, because Putin is a politican of the same breed and one day he might find himself in Asad's shoes. And as far as "valuing human life" is concerned... that has never been too high on the priority list over there. There really is not that much difference between carpet bombing of Grozny and shelling of Homs.
How can Arab League send a mission of "observers" to Syria only to appoint gen. Al-Dabi, a founder of the Sudanese genocidal janjaweed militias, as its head? I bet someone like him would not notice any wrongdoing even standing in the middle of the courtyard at Tuol Sleng circa 1977ish.
http://www.foreignpolicy.com/article...rst_human_rights_observer?page=0,1
tu204
Sat Feb 25, 2012 11:16 pm
Quoting L410Turbolet (Reply 13):
Russia and China are supporting Assad because he is the head of Syria and because we have had enough NATO meddling in the affairs of foreign countries. Might I remind Libya? How is it going for them by the way?
As far as valuing human life? Well look at the situation is Syria. It is not all coming from one side. The Russian draft resolution is more than reasonable: Condemming violet actions coming from BOTH SIDES. Or do you think only the military there is doing the shooting?
I do not dream about movie stars, they must dream about me for I am real and they are not. - Alexander Popov
cedarjet
Sat Feb 25, 2012 11:57 pm
Poor Syria. I was arrested in Damascus in 2008 for flying a roundtrip on a Yak-40 to Deirezzor, there-and-back. Understandably suspicious but me and my buddy spent about six hours being questioned by these truly evil guys who spoke German, trained by the Stazi you see, and after that experience we could see exactly how this benighted country functioned, and these spooks were EVERYWHERE. One guy came up to us on the beach the next day and started asking us casually about every topic we had discussed in our hotel room the previous night and was so sexually predatory that I was genuinely afraid of him. Leaving the country on our last day, in the international departures area of DAM airport, again, spooks everywhere, even a couple from foreign intel services (tie clips, lapel pins), these people with genuine evil in their hearts watching the crowds. The airport itself was a total disgrace, LED signs above each desk intended to show destinations, all broken, with handwritten, even MISSPELLED names on pieces of paper scotch taped over them. Baggage belts were all broken as well. It felt like air travel in Europe would a few years after a limited nuclear exchange, a wrecked system trying to get on it's feet and failing.
I felt sick thinking about what would happen if any of the guys who oversaw this system would do if they really got their hands on you. The Syrian secret police have invented and perfected more torture devices and methods than a medieval lord. I see tu-204's point about the world being sick of NATO interventions and I don't support one in this case but Assad and his crowd have to go.
Syria is different to Libya in two major ways, one is that the rebels in Libya had Benghazi, whereas in Syria there is no real rebel stronghold. I doubt Assad has many fans in Homs but it's hardly able to function as a capital in waiting, or even function at all - and it isn't a port city. The other big difference is Syria's strategic importance to the Russians. The Russians have NUKES in Syria, for god's sake. Their naval base in Tartous is their only base outside the CIS. It would be a strategic disaster for them if (when) Assad falls.
Re civil war, yep, this will be fought to the last man. If the rebels lose this, they know will all end up facing firing squads if they're lucky and in Assad's torture dungeons if they're unlucky. And equally, if the government spooks up to and including Assad himself lose this, they know they will hang from lampposts if they're lucky and in their own torture dungeons if they're unlucky. There is no going back now.
Quoting kaitak (Thread starter):
God, you're joking, the Israelis LOVE undemocratic dictators. Why do you think the US gave Mubarrak billions of dollars in "aid" each year? These guys (Mubarrak, King Hussein of Jordan, Assad, Ben Ali et al) kept their populations under the kosh and were never going to do anything to risk their power by embarking on a risky (indeed suicidal) escalation with Israel. If Arabs vote, they will vote for Arab interests, not Israeli / US interests.
Correct, sending in soldiers to keep two warring factions apart is not an invasion. What the US / UK did to Iraq is an invasion - attacking a united and non-expansionist country and decapitating the leadership, wiping out a tonne of civilians, that's an invasion. And no, there will be no intervention in Syria, see Russia, strategic position, above.
MillwallSean
Mon Feb 27, 2012 12:16 am
I really like west Syria, its a great place to be a tourist.
But Assads regime is a bad one, a full dictatorship and not a pleasant one at all with a real bad arse security police.
the time for such regimes are up. But the gulf states isn't much better and it would be ironical to see them intervene in Syria stating they want people power...
Bahrain percentage wise isn't much different than Syria. But the war in a few cities in Syria is probably worse than what we ever saw in Bahrain.
But Bahrain is not sustainable, you cant oppress 75% of the population for decades and expect them to be happy about it. the shias will eventually be powerful enough to topple the leaders of Bahrain.
Isolate Iran, Irans positions in the region is stronger than it has been for 30 years. Iraq isn't an enemy but today a rather close ally. Hezbollah took on Israel rather successful in Lebanon.
Iran has caused severe internal problems in Yemen and Bahrain. They have established a powerbase in Afghanistan. Its eastern border with Pakistan is calmer than its been for the last 2 decades. Pakistan doesn't allow any anti iran organisations to use baloch territory and the border to afghanistan is secured by friendly relations.
Iran is stronger and less vulnerable in the middle east now than before.
these days troops have to come across water to get at Iran.
Saudi isn't strong enough to invade Syria.mainly because they don't have the troops that's up for it. The usage of ex pakistani special forces only works if the Saudis dare to allow ex pakistani officers and Saudi don't. The Pakistanis are good soldiers but their Saudi officers that always have to be in charge of them are questionable at best?
the Saudis haven't exactly been excellent in Yemen and Syria is a lot tougher than Yemen ever will be.
Add on a Russian navalbase largely symbolic but still and no Saudi wont step in there. Not powerful enough to do so.
Iraq has a shia controlled government and is very close to Iran in its policies. Its rulers spent most of the Saddam years free of charge in Iran. Most respectable websites and poundits refer to Iraq as Irans new best friend in the middle east and that's for a reason. See iraq's votes in the UN over the last 12 months for example. or even simpler see what Iraq voted on the Syria resolution...
Iraq wont allow anything in Syria unless Iran agrees to it. Iraq isn't a Iran puppet but they are as close as the US and Israel.
Jordan are fearful of to much Saudi influence. They would prefer not to and Jordan would only allow it when they realised all others supported it.
Syria is ruled by the alawites a sort of shiite offspring. They are pitted against the majority sunnis. Saudi will do a lot to topple the alawites. the alawites in Syria sees full support from the other minorities that also remember what it was like to live under a sunni controlled Damascus.
if the Saudis sent their troops int hey would just like they demand everytime they fund a mosque abroad that they adhere to their form of islam. a very strict one and the rulers they put in would be conservatives to put it mildly.
Syria is diverse, you can drink beer at restaurants and see some of the sexiest women around on the streets. lets hope that Syria can continue to create its own identity rather than a Bedouin Saudi one.
The christians, kurds, druze and alawites (plus a few more small cultures) or about 25% of the county's population will support the present government to the last drop of blood. Remember the father of Assad went against a Saudi sponsored muslim brotherhood uprising 2 decades ago in a very bloody campaign. probably the bloodiest and only successful crushing of a national islamist group in the middle east north Africa. he more or less levelled the city where they were HQ:d though...
The opposition in Syria is very fragmented and even though some gulf states will support them financially and with weapons they will have a very hard sell to convince the people of Syria of their great intentions. Assad has a power base, Ghaddafi didn't, and last time the sunnis rules Syria all minorities were severely restricted. The minorities remember this all to well.
The Syrian army is mainly made up of the minorities and Russia supplies it with weapons so does Iran.
Israel has nothing to loose here. They can get rid of Assad. Not that he or Syria is a threat to Israel but he does support some of Israels worst enemies.
Israel if they play their card rights can only gain from agreeing to what the west and the arab states says. Better stay out of it, observe and later reap praise for doing little. Besides Iran needs to divert more attention to Syria right now, that can never be bad for Israel.
Syrian army can hold out a long, long time against a pure gulfstate invention.
If the west lent air support it might be different. But a gulfstate invention wouldn't be popular in the western parts of Syria and we would likely see a guerilla war. To be honest I wouldn't wanna see the gulf states armies walk into the christian maronite, druze or alawite homelands. That would be bloody indeed and would destabilise the entire region. Im not sure Israel has to much to win rom a destabilised Syria, lex Lebanon...
The Country that can take out Syrias regime is Turkey to the north.
No One Likes Us - We Dont Care.
Acheron
Mon Feb 27, 2012 7:55 am
Thats one heck of a spin right there.
The most amusing part was reading about the Saudi Arabia foreign relationships' minister thinking it was an "excellent idea" to give weapons to the syrian population.
I think I agree with him. As long as we give weapons to the shia minority in Saudi Arabia as well to make things even.
Saudi Arabia should really STFU and keep their hands to themselves. Particularly when its notorious they like to play the terrorism sponsorship game as well.
SOBHI51
Tue Feb 28, 2012 8:13 pm
Quoting Acheron (Reply 17):
KSA will be helping the Sunni majority to get there freedom from the dictatorship of the minority Alawites.
KSA will do whatever it takes to help the civilians in Syria. I do not know how people can stay indifferent when a 6 square miles in Homs has been shelled with tanks, missiles, heavy machine guns and helicopters for the last 24 days so far.
Yeh here we go with the terrorism accusation, when there is no real argument to offer there is always this, whatever,
The people of Syria need help and they will be free sooner than later.
ba6590
Tue Feb 28, 2012 8:39 pm
What people fail to realise that the opposition over the past few months has been doing there own share of sectarian killing. Many Alawites have been kidnapped, raped, and murdered.
I am not supporting the Assad regime, and I never will. I grew up in Homs, and I would love to see a democratic Syria.
Unfortunately that will not happen if Assad falls.
What we will end up with is a Sunni led government, which will try to impose its medieval customs on what up till now has been a fairly secular country.
I would love to see Assad fall, I would love to see a democratic Syria. I just don't see it happening.
Acheron
Wed Feb 29, 2012 8:03 am
Quoting SOBHI51 (Reply 18):
And who will help the shia minority of saudi arabia from the oppresion of the wahabi nutjobs that rule the country?.
Yeah, I'm pretty sure Saudi Arabia's effort to export wahabism through whatever means necesary its a made up argument.
Sorry, but noone buys the idea you want to go there "for the people". No one joins a war just for the good of the people of a country unless they have something else to gain.
And a country run by fucktards like Saudi Arabia is no different.
SOBHI51
Wed Feb 29, 2012 11:04 am
Quoting Acheron (Reply 20):
Well it seems that human suffering, lack of food and medical help, humanitarian goals is beyond some people understanding, that's not the fault of KSA, those people need to look deep inside them maybe they one day can understand and share in helping.
BTW if this army becomes a fact it will include forces from a coalition of Arab countries not only Saudi.
The Shia minority need not protection in there homeland, unless you are talking about those few who are agents of the Iranian trouble makers.
I also find that your name calling of my country offensive but with you that is not surprising, when you feel that you are loosing an argument insults start showing up.
Acheron
Wed Feb 29, 2012 7:17 pm
Quoting SOBHI51 (Reply 21):
So, when will the charitable, noble and humanitarian(LOL) Kingdom of Saudi Arabia is going to start helping, I don't know, the people of Sudan, or Burkina Faso which last time I checked has also oppressed people.
Or how about Bahrain?. The noble and humanitarian Kingdom of Saudi Arabia actually sent troops but it wasn't exactly to help the bahraini people, was it?.
Lol, sure they don't. I guess it is a lie they don't even enjoy the same rights that sunni muslims...
Not really insulting your country but its King and the other people ruling it.
And to be honest, I find it more insulting the fact that you think the rest of us are idiots who buy into the notion that the KSA wants to invade Syria just to help people and not just mere powerplay to stablish a wahabi foothold within the iranian(and Russian, so you could say that KSA is also doing the US' dirty job) sphere of influence.
The powerplay against the Iranian just happens to have nice side effect PR wise that makes the KSA look like "the savior of Syrian people" which is a load of crap.
SOBHI51
Wed Feb 29, 2012 10:22 pm
Quoting Acheron (Reply 22):
The idiots as you put it are the people who do not understand the difference between invasion and humanitarian purposes at no time KSA is interested in invading Syria.
Do you have any proof that they don't, or is it the Iranian propaganda that you only listen to?
When somebody insult the king he insults my country and myself.
If you call over 12000 dead, 50000 injured, millions starving crap then there is no reason to continue this useless discussion
par13del
Thu Mar 01, 2012 1:23 pm
You answered you own questions with the last line below.
How and why would the Russians and the Syrian govermnent allow the creation of a safe zone area for a defined opposition to take shape and set down roots, unless it was a ploy to get them all in one area to get rid of them?
As mentioned by others, there is no clearly defined opposition movement in Syria, which makes it difficult for third parties to get involved, allowing the creation of a buffer or safe zone to allow creation of such an opposition is not in the best interest of those in power or their supporters.
tu204
Thu Mar 01, 2012 4:08 pm
SOBHI51
Thu Mar 01, 2012 4:48 pm
Quoting tu204 (Reply 25):
Interesting video
http://www.youtube.com/watch?v=JDTjR...g-all&context=G24f4fedFAAAAAAAAIAA
Interesting indeed. But it seems they forgot to mention that in Syria it is the president army killing his own people.
raffik
Thu Mar 01, 2012 9:49 pm
It is a humanitarian crime that nothing has been done to attempt to help those suffering in Syria.
Assad is literally getting away with murder in that country (and outside).
I think that it is a much more complex problem than what happened in Libya.
Any possible attempt at "invasion" could be met with retaliatory force from Hezbollah, who I believe
are a very well armed supporter of the Syrian regime. Not to mention Iran..
I agree with Cedarjet regarding the Syrian oppression of its people. I visited Homs a few years ago
and secret police are everywhere. My father got detained by them in 2006 after a "waiter" overheard
my father telling a friend (in Homs) that he believed that it was the Syrians who assassinated Lebanese
PM Hariri. He was followed to his hotel and then detained for several hours.
Thankfully we got them out of Lebanon but I envisage any sort of action, whether it be by the Arabs or
UN to be met with resistance by Iran & Hezbollah
- Alec
Users browsing this forum: Airontario, petertenthije, readytotaxi and 1 guest
