2707200X
Brown Dwarf Stars, What Would You Call Them?
Wed May 09, 2012 5:55 am
By now, most of us know have herd of brown dwarfs. From what we know, brown dwarfs fill the gap between the largest or most massive of the gas planets and the smallest or least massive of the "M-class" red dwarf stars. The mas varies between 90 times the mass of Jupiter and 10 times the mass of Jupiter. Like stars they glow "dimly" and they are orbited by planets but like planets, they have no fusion in the core. NASA's WISE mission has discovered over 100 brown dwarfs.
What do you think about the brown dwarfs and what would call these stars?
"And all I ask is a tall ship and a star to steer her by." John Masefield Sea-Fever
Mir
RE: Brown Dwarf Stars, What Would You Call Them?
Wed May 09, 2012 6:16 am
Is something wrong with "brown dwarf stars"?
I'm kind of on the "if it's not broken, don't fix it" bandwagon here....
-Mir
seb146
Wed May 09, 2012 6:40 am
Quoting 2707200X (Thread starter):
"M-class"
red dwarf
I thought M-Class were planets most close to Earth and red dwarf was a mining ship...
Patriotic and Proud Liberal
connies4ever
Wed May 09, 2012 7:54 am
Quoting Mir (Reply 1):
Quoting seb146 (Reply 2):
Yes, M-class planets are the rocky ones like Earth (Venus, Mercury, Mars). The rest are gas giants except for Pluto which looks like it might be a comet that wandered in from the Kuiper belt and got trapped. Interestingly, Pluto itself has a satellite system (Charon, Nix, Hydra, and the dramatically named S1/2011).
Charon is larger in proportion to it's primary than any satellite in the Solar System.
There are still more hunks of ice/rock further out: Quaoar, Eris, and Santa to name a few. Many more will be discovered, of that I am quite sure. Be frickin' cold out there, that's for sure. And dark:the Sun wouLd be a mere point at 40-60 AU.
vikkyvik
Wed May 09, 2012 8:11 am
I typically call them brown dwarfs....
Quoting connies4ever (Reply 3):
You may have missed the joke there....
Aesma
Wed May 09, 2012 9:33 am
Apparently they were called black dwarfs at one point, and other name contenders are planetar and substar.
connies4ever
Wed May 09, 2012 10:23 am
Quoting vikkyvik (Reply 4):
Not really, I got the joke. Here's a joke: Santa has been determined to have it''s own satellite, informally called Rudolph. Both names I believe still have not been offically adopted by the IAU.
Aloha717200
Wed May 09, 2012 5:36 pm
I don't know if a body large enough to have achieved hydro-static equilibrium can still be considered a "comet". It'll be interesting once New Horizons reaches pluto and gives us a better understanding of its true composition versus what we can infer from telescope imagery.
As for brown dwarfs...the name seems to work for me. It'd be interesting to find one that's a mere 1 jupiter mass away from becoming a star.
connies4ever
Wed May 09, 2012 6:10 pm
Quoting Aloha717200 (Reply 7):
Yes it will be fascinating to see what New Horizons discovers. 3 years to go now. As for hydrostatic equilibrium, not forget that smaller objects such as the asteroids Ceres and Vesta (more or less) have done so, as has the Moon and several satelllites of the gas giants.
Jupiter is already almost a brown dwarf. It radiates at radio frequency.
GrahamHill
Wed May 09, 2012 6:31 pm
Absolutely not!
Quoting connies4ever (Reply 8):
But what is the parameter for a small object to be called dwarf planet or asteroid? To me, Ceres and Pluto are dwarf planets because, on top of gravitating around the sun, they could achieve hydrostatic equilibrium. But since Vesta has not achieved hydrostatic equilibrium, I can't really call it a dwarf planet.
Am I wrong?
"A learned fool is more foolish than an ignorant one" - Moliere
Aloha717200
Wed May 09, 2012 6:36 pm
I believe that Ceres is now classified as a Dwarf Planet, wheras Vesta is still considered an asteroid. The difference, it appears, lies in the hydrostatic equillibrium. Vesta just about got there, Ceres got all the way there. But I believe that composition plays a big role in whether a body qualifies as a comet. If Ceres was a ball of ice and managed to get close enough to the sun to develop a tail, I bet it could be considered a comet. But Ceres is quite a bit smaller than Pluto. I wouldn't think that Pluto would technically qualify.
But. Semantics.
DarkSnowyNight
Wed May 09, 2012 7:02 pm
The moon would be a planet of not for its orbiting of ours. The same can be said for Titan and a few others.
Jupiter is less than ten percent the size a body needs to be to be classified as a dwarf star of any kind. I think it's a myth to say it was "almost a star." Several exo-planets have also been discovered that a quite larger than Jupiter and still not stars either.
Be A Perfectionst, You're Nothing If You're Just Another; Something Material, This Isn't Personal...
2707200X
Wed May 09, 2012 8:13 pm
I have no problem with calling brown dwarf stars brown dwarfs, I actually like that term. One thing is fore sure, the spacing between the what makes a large gaseous planets and and the smallest of sub-brown dwarfs is almost nil if even that. Look at TrES-4b it's diameter, twice as wide as Jupiter clearly exceeds Gliese 229b which is about the same size as Jupiter and look at WISE 1828+2650, only 300K or 80F and Venus is how much? The defining factor is of course mass when determining what makes a planet and a star. We know that physics tells us that red dwarf star Ross 154 will never be a red giant, the Sun will never end up as a black hole but nature is not going to stop a 8, 10, 12 or 17 Jupiter mass body from forming. That's really the mystery and fun of Astronomy in all of this.
connies4ever
Wed May 09, 2012 10:37 pm
Quoting GrahamHill (Reply 9):
Am I wrong?
Not really, but Vesta's unusual shape more likely comes from a catastrophic collision with another asteroid millions of years ago, not inability to achieve equilibrium. Don't know if you''ve seen any photos from Dawn, currently orbiting Vesta, but the scar on that body is HUGE (and deep).
http://dawn.jpl.nasa.gov/multimedia/images/PIA15602-700.jpg
http://dawn.jpl.nasa.gov/multimedia/images/632419main_pia15493-700.jpg
http://dawn.jpl.nasa.gov/multimedia/images/RC3_color_05-full.jpg (looks reasonably spherical)
Quoting Aloha717200 (Reply 10):
Correct to my knowledge, but...
http://en.wikipedia.org/wiki/Dwarf_p....22nearly_certain.22_dwarf_planets
Quoting DarkSnowyNight (Reply 11):
Some have called Earth-Moon a twin planet. The Moon doesn't exactly orbit the Earth, the two bodies rotate around the centre of mass of the joint system. Which is below the Earth's surface, but not that far, and definitely not at the geometric centre. Titan and others do orbit because of the huge mass disparity between the secondary and the primary. The centre of mass for Saturn-Titan or Jupiter-Ganymede is not far from the geometric centre.
DocLightning
Thu May 10, 2012 12:59 am
Yes. Stars have nuclear fusion at their cores. Brown Dwarfs do not. I think simpy "Brown Dwarfs" is sufficient.
-Doc Lightning-
-Carl Sagan
flyboyseven
Thu May 10, 2012 1:51 am
The moon would only be a planet if it satisfied the three criteria for being a planet. The first is to be massive enough to form into a spheroid which it has satisfied. The other two are that it has to orbit the sun, and that it must have cleared out its orbit around the sun.
If there were no earth, then it would satisfy the second also, but it would fail on the third count. It would be kicked out for the same reason that pluto was. Its gravity would not be enough to clear out its orbit out debris.
Quoting connies4ever (Reply 13):
While it is true that the earth and moon orbit around the systems center of mass, and that it happens to be just inside the earths surface, the same is true of all orbiting bodies. On the larger planets it is just a lot less apparent, but the same thing is going on. The earth and all the the other planets have the same relationship with the sun, as do other planets around other stars. This effect is actually one of the leading ways of discovering exo-planets. You can see the spectra of the star show small variations in its red or blue shift and that can tell you about the planets orbiting them.
The reason the earth moon system is dubbed a twin planet is because the relative size of the moon is so great. The same is not true of its mass however which is several orders of magnitude below that of the earth.
I would simply call them brown dwarfs for simplicity, but they are not stars per-se. They occupy the grey area between star and planet, and are not really one or the other. Given that the first brown dwarf to be verified as such was in 1995, there is a lot more study needed to fully figure out what they are, and how exactly to define them. It was not until 2006 that there was a formal definition for a planet, so don't hold your breath for one about brown dwarfs!
Cheers!
Graham
As long as the number of take-offs equals the number of landings...you're doing fine.
prebennorholm
Thu May 10, 2012 2:03 am
Quoting DocLightning (Reply 14):
That's not entirely true. They have, however, no hydrogen fusion.
Brown Dwarfs greater than roughly 13 Jupiter masses have deuterium fusion. If greater than some 65 Jupiter masses they have lithium fusion as well.
Real main sequence stars all have hydrogen fusion. The minimum size for hydrogen fusion is normally considered to be 75-80 Jupiter masses. The upper limit varies with the lithium contents. The more lithium, the more a brown dwarf "balloons", and the more mass is needed to reach the critical core pressure to start hydrogen fusion.
Due to the always low deuterium (and lithium) contents compared to hydrogen, and due to the lower mass, the energy creation in a brown dwarf is extremely low compared to a hydrogen burning star.
connies4ever
Thu May 10, 2012 3:52 am
Quoting flyboyseven (Reply 15):
I believe I said that. Perhaps not clearly enough. Lunar volume is about 1/64-th of the Earth (I think, but it's late), density is lower, so a rough mass estimate is about 1% of the Earth, or perhaps a little less. I'm sure you can look it up.
Quoting prebennorholm (Reply 16):
Indeed. Jupiter's emissions of radio noise doesn't have a nuclear source, it's magnetic:
http://science.nasa.gov/science-news...ce-at-nasa/2004/20feb_radiostorms/
DarkSnowyNight
Thu May 10, 2012 4:47 am
About 1700km into the Earth IIRC, yes. But I don't think that makes us co-orbital with it. This brings a question then of what is needed for it to be considered to orbit in the truest sense. I've always been satisfied that this means that center of mass is below the surface of the larger (by mass), inner body.
As for the others I mentioned, I was really going by all-up mass rather than positioning and orbit. Since they have hydrostatic equalibrium, their size would class them as planets were they on track without any others and not orbiting (or co-orbiting) any other.
Depends on what you mean by debris, but at its mass, it is more than sufficient to clear out anything that Mercury could. If we were talking about being placed in the Asteroid Belt or somewhere in the Oort cloud, there may be enough Ceres sized objects to pose a problem, but here it's hard to fathom something that the moon couldn't clear out without dramatically altering its own orbital mechanics.
connies4ever
Thu May 10, 2012 7:19 am
Many of you may appreciate this link for possibilities beyond Pluto: going all the way out to the Kuiper Belt:
http://www.spacedaily.com/reports/Be...Exploring_the_Kuiper_Belt_999.html
KaiGywer
Crew
Thu May 10, 2012 10:07 am
Please tell me I wasn't the only one that didn't think of anything to do with space when I saw the thread title.....
connies4ever
Thu May 17, 2012 2:48 pm
A little bit more about Vesta, an interesting discovery courtesy Dawn:
http://www.aviationnow.com/Article.a...l/asd_05_17_2012_p04-02-458339.xml
So it appears as though Vesta had a molten core at one point. And that there were two, not one, massive collisions that caused the South Pole crater to be formed.
The Dawn mission, hopefully, will continue for some time. Supposed to leave Vesta in August for Ceres, perhaps this can be extended to another body like Eros, which is definitely not a protoplanet.
N1120A
Thu May 17, 2012 9:52 pm
Pluto is a planet, damn it!
Tugger
Thu May 17, 2012 10:01 pm
How about "Hispanic (or Latino) little-people entertainers"?
Quoting KaiGywer (Reply 20):
Nope you weren't.....
Tugg
connies4ever
Thu May 17, 2012 11:00 pm
Quoting N1120A (Reply 22):
   With you on that one, bro. I was totally against the decision by the IAU. Pluto was initially identified as a planet. Even if it does not meet the (new) criteria, I believe it should be grandfathered.
The size and characteristics of some of the recently-discovered dwarf planets is interesting, though. Eris, for example, seems to be larger than Pluto, and probably more massive. But it is really a long way out, about 67 AU, with a period of ~550 yrs. Not a KBO, but seems to be part of the original accretion disc that formed around the Sun.
There is talk of extending New Horizons beyond Pluto/Charon (see Reply 19). The question uppermost is which one to aim for ? Which depends on orbital characteristics, fuel on board, etc. Not sure if Eris could be reached, particularly due to it's extreme orbital inclination, but since it is really "out there", it would be interesting on that basis alone.
Users browsing this forum: AirplaneWizard, edgaren, NIKV69, OA412, salttee, TheF15Ace and 2 guests
