Airstud
Excel VBA Question (yes HERE, Why Not...)
Sun May 20, 2012 9:48 am
I have posted about this in a VBA forum but have not gotten a response and I am an impatient dude so why not go ahead and post it ici:
See, I do not have much experience with the VBA, but I want to write a program part of which will locate a certain row or rows in a spreadsheet that contain certain data in Column X (like "Henson" or "Nguyen" or "Hutchens"); then extract other data from a couple other columns in that row and spit it into a different spreadsheet (and then do the same thing until it's hit all the criterion-satisfying rows).
It seems that the Range.Find method is the way to do this. Am I wrong? VBA's documamentation says that the return value for this method is "A Range object that represents the first cell where that information is found."
When I run this code:
Resulticus = Range("X:X").Find("Henson")
MsgBox (Resulticus)
The MsgBox says "Henson Stewart". Which is indeed the content of the cell I expected to be found, but "Henson Stewart" is a string o' text. I want a Range object a)because consarn it, that's what the documamentation said I'd get; and 2)because I need to get the row number of this cell so I can copy the other four cells' worth of data out of that row, stick it into my other spreadsheet, and allow my for-next loop to go merrily along.
Does Range.Find actually return a object? When I commented out the MsgBox and used either "Resulticus.Select" or "Resulticus.Activate" I got a runtime error 424 "Object required." So I went into the General/Declarations section of the code editor and did a "Dim Resulticus as Object", and then I got runtime error 91 "Object variable or With block variable not set"
Wha goin' on is...how do I get this Range.Find method to work?
Pancakes are delicious.
DfwRevolution
RE: Excel VBA Question (yes HERE, Why Not...)
Sun May 20, 2012 3:15 pm
If there is nothing else you are trying to automate with the VBA code, would a pivot table get the job done? I try to avoid VBA like the plague.
Goldenshield
Sun May 20, 2012 6:44 pm
VBA is based on VB6, which is NOT object oriented in how we know it via .NET, although it does contain objects.
Anyhow, what you are doing is using the default action of the Range type, which is .text, and that's not what you want. You need to get its address.
This is what you need to do:
'Define the range object
Dim c As Range
'get the first instance of the what we are searching for
c = Sheet1.Range("a1:a500").Find("test")
'test if anything was returned
If Not c Is Nothing Then
'Get the row and column where the search passed
Dim Row As Integer
Dim Col As Integer
Row = c.Range.Row
Col = c.Range.Column
MsgBox ("The row you want is: " & Row)
End If
Airstud
Fri May 25, 2012 9:29 am
Thank you, Goldenshield.
I tried this code, and at first I got a compile-time error highlighting the word "Range" in
Row = c.Range.Row
The code that I'm running now goes:
Private Sub CommandButton1_Click()
Application.Workbooks.Open ("H:BASICTUESDAY_FLAT010312.xls")
Worksheets("T_TUESDAY_FLAT").Activate
C = Worksheets("T_TUESDAY_FLAT").Range("X:X").Find("Henson")
If Not C Is Nothing Then
Dim cRow As Integer
cRow = C.Row
MsgBox ("The row you want is: " & cRow)
End If
End Sub
And I am again getting that 'runtime error 91 "Object variable or With block variable not set"' error, with the
line highlighted when I click "Debug"
hooboy...
airmagnac
Fri May 25, 2012 10:14 am
Try adding a "Set" in front of the range object declaration :
Set C = Worksheets("T_TUESDAY_FLAT").Range("X:X").Find("Henson")
My goal as an engineer is to fill my soul with coffee and become immortal
Goldenshield
Fri May 25, 2012 10:28 am
Quoting airmagnac (Reply 4):
That's my bad. I don't use VB6/A as often as I used to.
Another thing in your code is that you failed to declare C as a Range object (as I did in the top of my code,) and instead are just naming a variable without telling it what it is.
Turning on OPTION STRICT and OPTION EXPLICIT may cause you a lot of headache when you turn them on, but will beat a lot of bad coding habits out of you.
[Edited 2012-05-25 03:41:07]
airmagnac
Fri May 25, 2012 11:40 am
Quoting Goldenshield (Reply 5):
That's my bad
And even when you use it fairly frequently, it's still sooooo easy to forget. I wasted 2 full days a couple of months ago, trying to solve this very same problem...Gotta love VBA !
Users browsing this forum: BaBaby, MaverickM11 and 2 guests
