varigb707
Should I Change From XP To Win7?
Fri Jul 13, 2012 12:08 pm
I have a Presario V2000 (purchased in 06), running XP Home.
- Crashed 2 years ago, installed XP Home.
- Working fine with all the security and anti this and anti that,Avast, MSN Essentials, yada yada yada.
- It gets quite hot after 35/45 minutes of usage, which may require a cleaning.
Now the question is : should I go ahead and upgrade to Win 7, instead, or clean it and keep XP?
First, I said 'hey' and then I said 'now'. "Hey Now!" - Hank K.
ajd1992
RE: Should I Change From XP To Win7?
Fri Jul 13, 2012 12:11 pm
Windows 7 won't help it be cooler so you might want to find a walkthrough online and completely dismantle it to clean it out. Don't just blow in the vents as it pushes the dust further in.
If you really feel like upgrading then go ahead. Check the specs before you do though - with it being a 6 year old laptop it may not run so well with all the fancy aero graphics (I have them turned off on my netbook - 1.8GHz dual core processor, 4GB RAM and a small graphics card so by no means the worst spec Windows 7 runs on)
What are the specs out of interest?
[Edited 2012-07-13 05:13:11]
varigb707
Fri Jul 13, 2012 1:21 pm
Quoting ajd1992 (Reply 1):
Definitely. My upgrading option was only towards a better computing experience. Not that there's anything wrong with XP, which runs very well by the way.
I reckon I may just clean it and keep it as it is. After all I only use that machine at home.
Thanks for your reply though. Cheers mate.
mham001
Fri Jul 13, 2012 3:15 pm
You will be able to upgrade to Win 8 for as little as $39.99 when it is released this (next?) month.
ajd1992
Fri Jul 13, 2012 3:24 pm
Quoting mham001 (Reply 3):
Depends on the specs of the computer. If it's not a good enough spec then it'll just run like treacle.
mham001
Fri Jul 13, 2012 3:40 pm
Quoting ajd1992 (Reply 4):
I'm not sure what treacle is but it should also run just like Win 7.
ajd1992
Fri Jul 13, 2012 3:49 pm
Quoting mham001 (Reply 5):
Very thick, sticky, syrup like stuff :P
It is 6 years old so it might not even run Windows 7 so well. XP sounds like the best idea for that laptop.
AF1624
Fri Jul 13, 2012 4:30 pm
I agree with the above, the conservative choice would be to stick with WinXP. A clean install of WinXP+updates.
einsteinboricua
Fri Jul 13, 2012 4:47 pm
If it ain't broke, don't fix it.
I wish my laptop could be running XP, though some perks of Windows 7 do come in handy.
Unfortunately, a limitation about getting a laptop is that its hardware may not run future versions of an OS. You can certainly increase RAM, but what good is it if the HD is the same? For instance, my Dell Inspiron has only 125GBs of memory. RAM was boosted to 2GBs from 250MBs and yet it still runs slow; hence why I bought another, modern laptop...stay away from ACER
"You haven't seen a tree until you've seen its shadow from the sky."
mham001
Fri Jul 13, 2012 5:21 pm
Quoting ajd1992 (Reply 6):
Understood, just pointing out that Win 7 will be inexpensively outdated very soon.
His computer can come in a variety of configurations, some that might work just fine. Others won't. Nobody can say for sure without knowing his specs (and checking drivers). I have run Win 7 on a 10 year old Thinkpad and is currently running Ubuntu, although admittedly, not real well. I'm not sure I would invest much in an old Compaq though. Microsoft does have it's compatibility check.
[Edited 2012-07-13 10:22:47]
[Edited 2012-07-13 10:24:07]
varigb707
Sun Jul 15, 2012 1:19 am
Quoting einsteinboricua (Reply 8):
stay away from ACER
Always have, Always will...
Longhornmaniac
Sun Jul 15, 2012 1:45 am
There's not even a question: YES!
Cameron
Cameron
Ps76
Sun Jul 15, 2012 2:30 am
Hi!
Personally I would stick with Xp. Like other said I would go with "if it ain't broke why fix it". I have Xp on one PC and Vista on another and really there is very little difference in the experience between them. I surf the web, I play games, I write the occasional letter. Ok Vista has a picture viewer and a newer version of Windows Media Player but neither does anything which couldn't be done previously.
I would say stick with Xp unless there is a particular feature of Windows 7 that you really want or need.
Only my personal opinion though!
Happy computing!
Pierre
StarAC17
Quoting varigb707 (Thread starter):
I have updated a system from 2005 to Vista back in 2007 and in ran better than it did on XP and 7 is a more efficient OS that Vista. The biggest things to look into to ensure it runs effectively is RAM (1GB is needed 2GB or more is desired) and your graphics capability to make sure Aero works well without slowing down the system to a crawl.
One thing to check is if you Laptop has or had "The Windows Vista capable" sticker. If it has that because it was purchased in 2006 you should be fine. 7 and VIsta have the same requirements IIRC.
The biggest factor is if you plan on keeping this laptop long term MS is going to cut off XP support soon if it hasn't already, so 7 might be the better option for consistent updates. If you were to wait a few months you might get a bargain on a 7 licence because IIRC Windows 8 is due in the fall.
Engineers Rule The World!!!!!
varigb707
Sun Jul 15, 2012 12:35 pm
Thanks everyone for your opinion, ideas and suggestions. Much appreciated.
RayChuang
Sun Jul 15, 2012 2:03 pm
Unless your computer supports more than 2 GB RAM and can run x86-64 CPU instructions, I do not recommend upgrading to Windows 7.
My laptop computer--which uses an Intel Core i3-2330M CPU with 4 GB of RAM--runs Windows 7 very well indeed.
planejamie
Sun Jul 15, 2012 8:59 pm
For your own sake, stick with XP - I have a higher spec 7 year old PC and it didn't like 7 at all, I reinstalled XP Professional and still run it now, getting a new Retina Macbook Pro in a few weeks (as I don't really like 7 either to be honest):
Have you seen/used the developer previews of Windows 8? God help us all, it is awful. Possibly the worst Microsoft OS since Vista or Windows ME. It'll run well, but confuse the hell out of everyone as well as decrease your productivity completely. It will only barely work on a touch screen/tablet, not a desktop/laptop at all - not due to specs or anything, due to the user interface only being touch screen friendly really.
Revelation
Sun Jul 15, 2012 11:48 pm
As noted elsewhere, W7 needs boatloads of memory to be tolerable, and it needs to be fast too.
I think 2GB of main memory is the starting point, and it should be at least DDR2 or hopefully DDR3 standard at the highest speed your system will support.
Given that 4GB upgrade kits for modern PCs cost $30-$40 or so, you should not skimp on it.
If you don't have a modern PC, then you very well should consider staying on the older OSes.
Personally I like a lot of the usability improvements that come with W7, such as the Start menu having a search box, etc. but it's not what I'd call revolutionary.
Time after time you are reminded that good old Windows is still its same old self.
Cost of memory per byte is more for older systems because it wasn't made in the high densities we now use.
It is also slower per byte because the interface specs it has are just slower.
Some older systems may also have limits on the total amount of memory.
I recommend going to a reputable memory vendor web site like crucial.com and running its system scanner.
It will tell you what standard of memory your current system uses as well as its max capacity, and will propose various upgrade packages.
Their prices are usually decent, but you can always write down the specs of what they are trying to sell you and see if you can't get it cheaper elsewhere.
Quoting mham001 (Reply 9):
Good point.
Quoting StarAC17 (Reply 13):
Indeed, and you can choose to turn Aero off.
Quoting varigb707 (Reply 10):
stay away from ACER
You get what you pay for. I have purchased a few of them as dirt cheap desktops and in that role they were fine. I doubt their laptops would put up with any real use so I don't ever buy them.
Quoting planejamie (Reply 16):
I'm told you can fall back to a Win7-like desktop interface if you like, but time will tell.
The gun is NOT a precious symbol of freedom
It is a deadly cancer on American society
Those who believe otherwise are consumed by an ideology
That is impervious to evidence
mham001
Mon Jul 16, 2012 12:02 am
Yes I have. Win 8 is basically the same as Win 7. If the computer will run Vista, the computer will run Win 8. You can easily change the UI to look just like Win 7.
The answer is quite simple given the information we have. Windows Compatibility Check.
varigb707
Mon Jul 16, 2012 12:42 am
- Yes on my W7 machine. Had to re format, restore, do it all over, etc.
-You can say that again
andz
Tue Jul 17, 2012 7:23 pm
I have a 4 year old HP 6710b with 2GB RAM which I upgraded to W7 a couple of months ago and it runs fine. Better, faster and cooler than with XP. I upgraded it because I don't have a recovery disk and using a normal copy of XP caused all sorts of problems. No such issues with W7.
The only problem is that the touch keys above the main keyboard (wireless on/off, volume etc) don't work and the so called fix from HP makes no difference.
Sometimes all a laptop needs is a good reformat and reinstall to restore performance.
Users browsing this forum: TheF15Ace and 38 guests
