DocLightning
CFL Vs LED Advice
Tue Nov 20, 2012 8:28 am
My old thread on the subject is locked/archived, so I'll start a new one.
We just bought a new home. All the lights are incandescent and that has to change immediately. I don't need to rack up those kids of electricity bills.
Now, I'm well aware of the disadvantages to CFL's. Breakable, mercury, less efficient, warm-up time, dimming works poorly.
BUT... before I sink $1,300 into LED lighting that will last me until I'm 50, I want to make a careful decision. It seems to me as if LED lighting technology is rapidly maturing. The new Philips L-prize LED has a CRI of 90 at 2700K and uses 10W for 900 lumens (60W incandescent equivalent). It comes in one power (10W/900 lumen) and the other bulbs of other powers are CRI of 80.
But Philips already has introduced into some markets the "DimTone" LED. This LED is fully dimmable and changes the color temperature as it is dimmed to a richer, warmer light just like an incandescent. If the L-Prize 10W is out, when will that technology be combined with DimTone?
See what I mean? I'm hesitant to buy LED's because I'm worried that they will quickly go obsolete. I'm tempted to wait a few years until the ones with features I like become available.
What are your thoughts?
[Edited 2012-11-20 00:29:09]
-Doc Lightning-
-Carl Sagan
Francoflier
RE: CFL Vs LED Advice
Tue Nov 20, 2012 8:40 am
I know I'd wait.
And I think there's no guarantee that LEDs that you buy today will last you forever either.
LEDs themselves suffer almost no wear, but heat dissipation is their major issue. LEDs are more efficient but actually produce more heat than an equivalent incandescent. The higher the power rating, the better the heat dissipation system must be to ensure a long lasting bulb...
I'm guessing that integrating LED spots in enclosed areas like false ceilings or the like where there is little ventilation is still relatively challenging...
Here's a good article from a good website on the subject:
http://www.ledsmagazine.com/features/2/5/8
DocLightning
Tue Nov 20, 2012 9:00 am
It occurs to me that a lot of the fixtures in the house are closed, so I guess we'll get stuck with CFL's for a little while, anyway.
-Doc Lightning-
-Carl Sagan
Rara
Tue Nov 20, 2012 9:25 am
I too wouldn't invest a lot of money in LED lighting at the moment. I'd replace the incandescents that are used the most with high-quality CFLs with a warm color range. Those really are okay, not perfect but very usable. Then in a few years buy LEDs when the market has stabilized.
Samson was a biblical tough guy, but his dad Samsonite was even more of a hard case.
Kiwirob
Tue Nov 20, 2012 10:46 am
Quoting francoflier (Reply 1):
That's not true LED's dim over time, you can already see it in instilations where a LED has failed and been replaced, the new one will be brighter than the older ones.
Personally I'd wait a while and wait for the prices for LEDs to drop as the technology maturers. What I would do is replace the incandescents with something like the Osram Halolux energy saver lamps, they give the same kind of like as incandescent, are cheaper to run and have amuch longer life, they are also significantly cheaper to buy than good quality CFL's. 60w is reduced to 42w, yet the output is the same and energy consumption reduced with a longer lifetime.
The new OSRAM LED's are specifically designed for this kind of instillation, so long as they are installed within a box it's not a problem.
swissy
Tue Nov 20, 2012 11:03 am
We have made the switch 3 years ago.... have maybe 3 or 4 CFL's left in the house just because there is nothing available on the LED side. Most of these LED's are in the "daylight" range. No regrets so far and non of them had to be replaced and they works just fine in our cold winters in Canada   They all do loose brightness over time.... I do not pay attention to the watts, lumens is what I look for and compare between all these bulbs. Majority are made by Lights of America...
Cheerios,
falstaff
Tue Nov 20, 2012 2:00 pm
Quoting KiwiRob (Reply 4):
They sure do. My dad sells and services railroad signal equipment and has been selling and servicing LEDs for 11 years and he tells me they do wear out over time. Railroads like them because they are bright, use less energy and last longer than traditional lamps, but they will not last foreever.
LEDs can also have issues with the circuitry that makes it works. The LEDs may be in perfect shape, but a failed circuit still means a failure.
I would also go with the CFLs until the LED technology gets cheaper. CFLs aren't the best, but I made the switch 8 years ago when they were fairly pricey and I have only replaced two inside the house. I have replaced the ones in my porch lights about once a year, I guess they can't take the Michigan winter more than once.
My mug slaketh over on Falstaff N503
Superfly
Tue Nov 20, 2012 2:26 pm
Quoting DocLightning (Thread starter):
Hang on to them for now. You can install dimmer switches for the moment and turn down the lighting when you don't need that much light.
....and may hurt your dog if they break.
Remember what Congressman Ted Poe said;
http://www.youtube.com/watch?v=Tv59PJ30WeM
Wait a while before something else comes along. The charming vintage Victorian you recently bought really shines and brings out the fine details of your walls, boarders, arches and other ornate details found in home of this era with traditional incandescent light bulbs. You don't want to put in cheap factory lighting (CFLs) in your new home.
Bring back the Concorde
fr8mech
Tue Nov 20, 2012 4:38 pm
I've put a couple of LED lights in the kitchen (we also just bought a house, and strange how bulbs seem to be burning out), replacing incandescent. Both the wife and I commented that the light was 'different' We bought Bright White with a 75 watts equivalent.
We're hesitant to experiment with Daylight and Softwhite, due to the cost of experimentation.
I replaced a couple of basement bulbs that are on dimmers with a dimmable LED and they seem to work OK. Those bulb sit right next to incandescents and, except at the dimmest setting, I really can't tell the difference.
We will probably just replace bulbs on an attrition basis.
I will assure you of one thing...CFL's are coming out of this house. The light is just too harsh and the warm-up time (though getting better) is annoying. Three or 4 years ago, I swapped the whole house over to CFL and that was a mistake.
Quoting Superfly (Reply 7):
I think it would look much better by gaslight.
Quoting DocLightning (Reply 2):
Doc, what do you mean by closed? I haven't found a fixture that won't accept an LED. In fact, I have found that the LED's are closer to mimicking the shape and size of a comparable incandescent than some CFL's are.
[Edited 2012-11-20 08:43:59]
mham001
Tue Nov 20, 2012 4:51 pm
Incandescent lights are not the huge drain if you turn them off when not in use.
I heard about new 3M bulbs this weekend. They believe they have solved the heat problem by surrounding the led with a cooling liquid. Passively cooled allowing for smaller size bulbs. Fully dimmable. Supposedly Walmart will be carrying them but I could not find them online.
DocLightning
Tue Nov 20, 2012 6:23 pm
Dimmer switches are already installed. I can use dimmable CFL's or dimmable LED's.
I think you're used to the CFL's that have the 5000-6000K color temperature. That color of light is horrible and is exactly like cheap factory lighting.
Proper domestic CFL's have a 2700K color temperature and a good CRI. The light quality is indistinguishable from those of an incandescent to the human eye. I'm more concerned about the environmental impact both in the home (if one breaks when it is warm) and also globally (mercury).
Quoting mham001 (Reply 9):
I've heard about these and the DimTones and it just appears as if they aren't yet available.
For now, I am putting LED's in all open fixtures around the house and I will put dimmable CFL's in the closed fixtures. The closed fixtures (and for that matter the open fixtures) are all completely fugly and eventually (when I have some of that green stuff around), I'd like to replace them with something a bit less "grandma."
[Edited 2012-11-20 11:07:47]
-Doc Lightning-
-Carl Sagan
Superfly
Tue Nov 20, 2012 7:04 pm
Quoting fr8mech (Reply 8):
True but then there is the fire hazard - the dog might knock it over or an earthquake and then his investment is up in smoke.
That wouldn't be good.
Quoting DocLightning (Reply 10):
I haven't bothered to check. As long as incandescents are on the market, I'll continue to buy them.
Have you considered lava lamps and other inexpensive mood lighting?
DocLightning
Tue Nov 20, 2012 7:09 pm
Quoting Superfly (Reply 11):
Most of the lighting in our rental house right now is CFL (that I put in). They've more than paid for themselves. The big problem with CFL's as far as light is concerned is the warm-up time. When you turn them on, they come on at less than 30% brightness and then require anywhere from 1-10 minutes to warm up completely.
However, once they are on, they look like incandescents if you can't see the bulb itself.
-Doc Lightning-
-Carl Sagan
Superfly
Tue Nov 20, 2012 7:45 pm
Quoting DocLightning (Reply 12):
I'm a bulb-snob
Kiwirob
Tue Nov 20, 2012 7:53 pm
Hate to burst your bubble Doc but not all dimmer switches will work with all dimmable LEDS, there's both analogue and digital dimming, they are not interchangeable.
mham001
Tue Nov 20, 2012 9:14 pm
Quoting KiwiRob (Reply 14):
Good point. Many dimmers cannot deal with the low wattage of leds.
Flighty
Tue Nov 20, 2012 9:42 pm
CFL has been a failure until MAYBE now.
LED is most likely a failure at this very moment -- bad quality, bad light, production defects and too expensive.
CFLs last a very long time if you never turn them off. This strikes me as an irrelevant and misleading fact. They do die, and regularly.
I use CFLs for the majority of my lighting. i like Cool color temps, not sickly yellowish "warm" lights. GE Reveal is a bit too reddish for me, but it gets close. The goal is something similar to daylight. At least some of us enjoy that.
fr8mech
Tue Nov 20, 2012 9:56 pm
Quoting Flighty (Reply 16):
I agree. It seems I was changing CFL bulbs more than I expected. I seemed to always be localized around a coiple of fixtures, though. I cleaned the contacts and checked the voltage at the bases, but still 3 or 4 fixtures kept burning those CFL's out.
Rara
Tue Nov 20, 2012 11:04 pm
Quoting fr8mech (Reply 17):
That's strange, I've been using CFL's for 10 years now and I still have to have a single one die on me. Quite unlike incandescents which you have to replace rather often. The CFL's do lose their full power though. I already replaced one or two because they don't go to full brightness anymore.
ALTF4
I actually just bit the bullet and bought a bunch of LEDs. I'm leasing an apartment and just renewed the lease for a year, and fully plan on taking these with me when I move. Yes, I did box up all the old incandescent lights to put them back in the fixtures.
One of the luxuries of being a young, single guy making way too much money is I can start silly projects and have fun. I have started automating my apartment, and have built my own electronics to do that, and all the control mechanisms using computers, I have programmed and built myself.
The next step was to get controllable lighting. I did not want to play around with solid state relays in light switches, so I bit the bullet and bought some LEDs that Philips makes. They only sell them at Apple stores.
http://www.meethue.com/en-US
They aren't cheap: http://store.apple.com/us/product/HA...ps-hue-connected-bulb-starter-pack
And additional bulbs are $60.
They're fun because I can dim them, turn them into any color I want, and adjust the warmth all from my iPhone/iPad/Android. I have also written a custom application so I can control them over a HTTP call... and can then control them over a webpage or a phone prompt.
As for the LEDs themselves, they are bright and well-built. I think the light is just as good as incandescent bulbs - I never liked the CFLs.
The above post is my opinion. Don't like it? Don't read it.
DocLightning
Wed Nov 21, 2012 12:18 am
Quoting ALTF4 (Reply 19):
The question is how good the CRI is. If the bulb is based on just RGB, then the CRI will be poor.
-Doc Lightning-
-Carl Sagan
ALTF4
Wed Nov 21, 2012 1:40 am
Quoting DocLightning (Reply 20):
The LEDs inside are not RGB - they are closer to orange, lime-green, and violet. Right now I have them in about half the sockets around the apartment, and the other half are incandescent. I have set the warmth of the LEDs such that they are truly indistinguishable from the incandescent bulbs.
I do have some knock-off LED accent lights as well, which are RGB. I was unhappy with those, as the light was always bright white. The two schemes are definitely different, with different color productions possible with each. The Philips LEDs are more "pastel" - that's the best word I can come up with.
DocLightning
Wed Nov 21, 2012 1:48 am
Quoting ALTF4 (Reply 21):
Even still, that's going to hit the CRI. Colors that absorb and reflect frequencies between those emitted frequencies will appear very dull.
-Doc Lightning-
-Carl Sagan
sccutler
Wed Nov 21, 2012 4:56 am
If you are counting on changing out bulbs to "save money," you must leave a lot of lights on a lot of the time!
I have replaced most lights that I use a lot with CFLs, and I know that they use a lot less power (and emit less heat, which in Texas in the summer is a good thing). Nonetheless, I have also found that CFLs fail more frequently than we are told to expect - I have come around to the habit of coding the date of installation to track this; very disappointing.
Also (and this is something we hear little of), CFLs will occasionally fail "noisy" - the electronic circuitry making a huge amount of electrical noise (they are transmitting RF, over the home's wiring). It interferes with radios and remote-control devices. Big pain to troubleshoot the first time I encountered it.
I have great hopes for LED lights, but the cost is just stupid right now, and having watched the price curve, I am confident that they will make a lot more sense economically in a couple of years.
...three miles from BRONS, clear for the ILS one five approach...
DocLightning
Wed Nov 21, 2012 8:03 am
Quoting sccutler (Reply 23):
Well, you save money on a light that lasts 15 years and burns little energy in a setting where energy is expensive.
There are a number of factors that affect CFL lifetime and one of them is frequency of on/off. Every time you turn a CFL on and off, you shorten its lifespan, much as for an incandescent. For this reason, CFL's are good for lights that will be cycled infrequently and left on for a long time.
I use incandescents for closets and other such spaces where the light will only ever be on for a few seconds at a time. In such a setting, a CFL will age quickly and require "warming up" to get to full brightness and an LED is simply not cost-effective.
I use LED's for open fixtures. They have all of the benefits of CFL's (even better efficiency), last 10-20 years, start instantly, and don't care how often they're turned on and off. Also, most LED bulbs today are dimmable, although the color temperature starts to look odd once they are very dim.
I use CFL's for closed fixtures because LED's currently handle closed fixtures. Fortunately, in my home, most of the closed fixtures are in side rooms (the office, the bedrooms) where they would likely not be turned on and off frequently and will be left on for a long time.
But each technology has its niche.
-Doc Lightning-
-Carl Sagan
Kiwirob
Wed Nov 21, 2012 1:00 pm
Quoting DocLightning (Reply 24):
They do care, same with most electronics, the number of cycles effects them.
falstaff
Wed Nov 21, 2012 1:16 pm
Quoting Rara (Reply 18):
I have had them for 7 or 8 years now and I have only replaced two inside the house. The outdoors ones don't last as long, but neither did standard bulbs.
swissy
Wed Nov 21, 2012 1:34 pm
We did a bigger scale test with my wifes poultry barns.... 400 bulbs  , the worst ones are the CFL's by far, lighting is controlled by computers, we averaged changing 8-15 bulbs every 9 weeks, dimming was bad towards the lower end, CRI was @87 and was fine, color was at 2700K... not so good for poultry.
Now we are in our 3rd year with LED's and we have changed so far 8 bulbs!! and we are using 10w per bulb on average, CFL's was 15w... These barns are washed after each flock of birds are gone, if its -20 during empty time barn is that cold too, no issues to fire them up or flicker....
Would stay away from the high priced LED's for now and try it out with some more reasonable priced LED's and see
Cheerios,
DocLightning
Wed Nov 21, 2012 5:29 pm
Quoting KiwiRob (Reply 25):
Not the diode itself. In fact, LED's last longer when cycled. The underlying solid-state electronics may degrade, but much slower than the diode will.
The fact that diodes may be switched on and off very quickly (on MHz frequencies even) is one reason why they get used in displays and as pumps for pulsed lasers.
-Doc Lightning-
-Carl Sagan
Kiwirob
Wed Nov 21, 2012 5:40 pm
Quoting DocLightning (Reply 28):
You have to consider the diode and the electronics behind it as one in the same, you can't replace the diode when the circuit board dies. I have no idea where you get LED's last longer when cycled from, I've been selling light for nearly 6 years and have never heard that.
mham001
Wed Nov 21, 2012 7:26 pm
Quoting swissy (Reply 27):
Not even close. Resistors and whatnot can fail for a number of reasons, in fact the big problem leds have is the circuit board getting too hot and that is often what is failing because where does the heat rise? Electronics can even go bad from long periods of disuse.
Superfly
Wed Nov 21, 2012 8:41 pm
DocLightning:
Have you considered halogen lights?
They may not be as efficient as the CFLs but more efficient than incandescent yet still dimmable and can be romantic.
Marcus
Wed Nov 21, 2012 8:42 pm
These look good...don't know about prices but since these are sold in Apple stores they will not be cheap...
http://www.youtube.com/watch?v=LoQj08SluXo
Kids!....we are going to the happiest place on earth...TIJUANA! signed: Krusty the Clown
ALTF4
Wed Nov 21, 2012 8:50 pm
Quoting Marcus (Reply 32):
Flighty
Wed Nov 21, 2012 10:27 pm
Quoting Superfly (Reply 31):
When going for a premium clean look, halogen is perfected technology.
DocLightning
Thu Nov 22, 2012 1:36 am
DocLightning:
Can't use halogens in closed fixtures. Also, halogens still radiate the vast majority of their energy as heat and, while they save about 10-20% on energy over a standard incandescent, they still use a lot of power.
Quoting mham001 (Reply 30):
Again, LED's do not age based on being turned on and off. In fact, some commercial LED's actually flicker at about 100Hz during normal operation.
One major use of LED is in displays where they are rapidly cycled on and off. The diode itself does not decay with this use. The electronics in a well-designed LED bulb are designed to operate under the normal conditions for which the bulb is designed. They only generate heat when powered, so if they are turned on and off ten or fifteen times per day, their lifespan is not affected. In fact, LED's are excellent for motion-sensing floodlights, which may turn on and off twenty times during a night.
-Doc Lightning-
-Carl Sagan
Revelation
Thu Nov 22, 2012 2:36 am
I've avoided CFLs because of the warm-up factor.
Also the early ones had transformers in them that would hum, which would drive me nuts.
I've still got lots of ol' fashioned incandescents here.
I am pretty careful about how long I leave lights on.
I tend to leave the plasma TV on longer than I should, but like the incandescent, the follow-ons aren't as good and I see no reason to replace it.
Now that's what I need!
I used to do such things when I was young, but now I get all the jollies I need from my day job.
I tend to have larger silly thoughts these days, converging on the new Tesla model.
Think of it as a big light bulb!
I think I have a few years before I'd need to pull the trigger on that, though.
Inspiration, move me brightly! Light the song with sense and color.
Hold away despair, more than this I will not ask.
Faced with mysteries dark and vast, statements just seem vain at last.
Some rise, some fall, some climb, to get to Terrapin!
sccutler
Thu Nov 22, 2012 4:04 am
Looks like our approach to lighting is consistent, Doc. Good analysis.
DocLightning
Thu Nov 22, 2012 5:19 am
A "closed" fixture is a fixture that is not open to the air.
An "open fixture" is open to the air.
This is important because LED's generate a fair amount of heat. LED's do not perform well in a hot environment and suffer degradation both in light output and lifetime. They require open fixtures that allow air to circulate so that heat can be removed. Many LED bulbs come with radiator fins as part of the bulb assembly.
If air cannot circulate freely in and out of the fixture the bulb will overheat.
CFL's can tolerate a warmer operating environment than an LED and also do not generate quite as much heat, so they are compatible with closed fixtures.
I keep hearing this about CFL's (and LED's) and the problem is that you are buying CFL's that are "daylight" or "bright white."
You want to buy "Warm White" or "Soft White" bulbs. They should list a color temperature between 2700K and 3000K. This is a pleasing, yellowish color that is visually indistinguishable from an incandescent when the bulb is hidden behind a baffle.
2700K-3000K is appropriate for relaxing settings, like home. This is probably because this is similar to the quality of daylight at sunset. By contrast, 5000K-6000K is a harsher, bluer light that is appropriate for work settings, which is probably because this color temperature is similar to the quality of daylight at mid-day.
-Doc Lightning-
-Carl Sagan
zippyjet
Thu Nov 22, 2012 5:32 am
Since they are an investment, start gradually. I can vouch for outdoor LED floods I purchased within the past six weeks. I use them on my patio. This fixture is an photocell on at dusk, off at dawn unit. These canno't handle CFL's but, I wanted bright economical lighting. So I invested in two of them. Cost me about $60 give or take. I'm very happy with them. So my advice is switch to LED's for say flood lights, maybe outside like myself or if you have a hard to reach ceiling light go LED for that one. Rapidly, there are more choices and prices are starting to come down a bit. And my LED's which I bought at Home Depot were bright light and on sale. They look like regular flood lights, not those funny "ET" looking earlier LED's.
I'm Zippyjet & I approve of this message!
Superfly
Thu Nov 22, 2012 6:58 am
Quoting Flighty (Reply 34):
My condo has both halogen and incandescent bulbs.
All of the halogen and some of the incandescent bulbs are on dimmers switches.
Looks great at night with the halogens dim and looking out over the Bangkok skyline.
Quoting Revelation (Reply 36):
I still use a CRT for TV and computer monitor.
Yes!
...and they use a single energy efficient 40watt incandescent bulb.
Quoting DocLightning (Reply 38):
That's not true. Hiding a CFL behind a fancy light fixture is like putting lipstick on a pig. It still has that depressing, dim light look.
Kiwirob
Thu Nov 22, 2012 7:45 am
Quoting DocLightning (Reply 35):
Jesus Doc where the hell do you get this kinda rubbish information. This kind of halogen you can use in any fixture open or closed. Osram Halolux Classic Energy Saver.
No but the controlling electronics do, you see the diode you're forgetting that the diode by itself is useless, the diode and the controlling electronics need to be treated as a single unit.
Revelation
Thu Nov 22, 2012 4:35 pm
Quoting KiwiRob (Reply 41):
I'm really surprised the controlling electronics would degrade with switching. Use of solid state electronics in switching applications is as old as the hills, at power levels waaaay above what we're talking here.
DocLightning
Thu Nov 22, 2012 6:31 pm
Oh. I've never see those before. Cool!
Quoting Superfly (Reply 40):
I've done side-by-side comparisons with doubters like you and they've been shocked.
-Doc Lightning-
-Carl Sagan
Kiwirob
Thu Nov 22, 2012 6:36 pm
Quoting DocLightning (Reply 43):
Standard 60w is replaced by a 42w, lights have a design life of 3000 hours and are cheaper than quality CFL's.
Superfly
Thu Nov 22, 2012 7:21 pm
Did you stick their wet finger in the socket?
mham001
Fri Nov 23, 2012 2:13 am
Quoting Revelation (Reply 42):
But are those switches sitting next to the hot led going through heat cycles? A flashing led would only be half hot and might explain where he heard they last longer. It probably really depends on the length of cycle and ultimate temperatures but circuits do not like heat cycling.
DocLightning
Fri Nov 23, 2012 6:26 am
Quoting Superfly (Reply 45):
Quoting KiwiRob (Reply 44):
Still not doing it for me. I can cut it to 12-14W with a design life of 5-7000 hours and negligible radiated heat. There are about 20 bulbs in the house that will be replaced with CFL alone. That's 600W right there if you assume 30W savings per bulb. When you add in the other 15 or so that are LED that burn similar wattage to a CFL, that's now 1.2kW.
While a 25% savings is nice, an 80% savings is better.
Liquid-cooled LED's will be on the market in the next few years. Around the time that my CFL's start to wear out, I'll be ready to replace those in the closed fixtures with these. Alternatively, I may choose to replace my closed fixtures with track lighting or something else. Those fixtures are ugly.
-Doc Lightning-
-Carl Sagan
DocLightning
Fri Nov 23, 2012 6:30 am
Quoting mham001 (Reply 46):
That's part of it. It takes a while for an LED to reach full heat. Usually a half hour on or so.
Here is an example of rapid LED cycling. It's called the Cubitron and it is a featured Burning Man art exhibit every year.
http://www.youtube.com/watch?v=XnjdYQzm68s
(Warning, some profanity in the background comments).
-Doc Lightning-
-Carl Sagan
Superfly
Fri Nov 23, 2012 9:38 am
Quoting DocLightning (Reply 48):
That is amazing and would look even more trippy if you're on something.....
Users browsing this forum: Baidu [Spider], TheF15Ace and 3 guests
