1337Delta764
Dyson Airblade Vs. Excel Dryer Xlerator
Fri Nov 30, 2012 7:10 pm
This may seem like a strange poll, however, I am pretty sure everyone here has used at least one of these types of hand dryers before. Both claim to dry hands faster than conventional hand dryers, and are both super energy-efficient.
So, between the two, which do you prefer - the Dyson Airblade or the Excel Dryer XLERATOR?
My pick would be the XLERATOR. The XLERATOR seems easier to use and I like the feel of the massive amount of air produced by it. I also don't have to worry about touching the sides as well as the pooled water on the bottom of the Airblade. Furthermore, both units use about the same amount of energy, and the XLERATOR is only 1/3 the price of the Airblade.
Molykote
RE: Dyson Airblade Vs. Excel Dryer Xlerator
Fri Nov 30, 2012 10:16 pm
They are both mediocre. The Dyson always seems to throw water from one's hands all over the floor and needs a drain/receptacle for blown off moisture. The XLERATOR is about as aloud as a JT8D. I worked in the nuclear industry and I'd swear we had rooms quieter than that hand dryer that didn't require ear protection.
[Edited 2012-11-30 14:17:03]
Speedtape - The aspirin of aviation!
Alias1024
Fri Nov 30, 2012 11:03 pm
Dyson
Both do their job fairly well, but only one makes me wish I was wearing ear plugs.
A346Dude
Sat Dec 01, 2012 6:54 am
The Dyson sucks, it's almost impossible to not touch the sides.
You know the gear is up and locked when it takes full throttle to taxi to the terminal.
ANITIX87
Sat Dec 01, 2012 1:59 pm
I HATE HATE HATE HATE HATE HATE all blow dryers. With a passion normally reserved for hating rapists and criminals.
Some blow barely any air at all. They don't do anything. Others can blow 7000 cubic feet of air a second, at 6million degrees. It'll blow the damn skin off your hands. And what will you be left with? A skeleton still dripping with freaking water. I hate them. They're completely ineffective. I end up using them two or three times (negating the energy benefits) and I still have to wipe my hands on my pants when I'm done.
Put some damn paper towels in the bathroom, PLEASE!
[/rant]
TIS
zippyjet
Sun Dec 02, 2012 5:48 am
Quoting 1337Delta764 (Thread starter):
Is the Xlerator the one that is shaped square with the nozzel bottom center? If it is, I like this one better. It sounds like an RJ spooling up and I like the strong air volume that is strong enough to actually create that cool feeling on my skin and I believe does not get as hot. Dyson products look like quality but, I feel they go for the yuppie, trendy gee wizz design and you pay a premium for them.
I'm Zippyjet & I approve of this message!
N1120A
Sun Dec 02, 2012 7:48 am
Dyson. It isn't even close. It actually gets your hands dry. The other one is just a glorified version of the old style dryers.
bristolflyer
Sun Dec 02, 2012 3:15 pm
I prefer the Airblade. The Accelerator is just too loud - painful to use. Re the cost, pretty sure that everyone on here is an end user (as opposed to a buyer) so no one cares about the cost. I did see an invoice for an Airblade recently and they cost around $1,000 which I thought was a lot, but then I recall everyone saying their vacuum cleaners were a lot when they came out but they still sold masses of them. Quality and innovation doesn't come cheap.
Fortune favours the brave
Gingersnap
Sun Dec 02, 2012 3:23 pm
Quoting bristolflyer (Reply 7):
The Xlerator costs around about £500 FWIW.
Flown on: A306 A319/20/21 A332 B732/3/4/5/7/8 B742/4 B752 B762/3 B772/W C152 E195 F70/100 MD-82 Q400
DocLightning
Sun Dec 02, 2012 4:31 pm
Quoting ANITIX87 (Reply 4):
I do prefer the airblade. The issue with the AIRBLADE is that you have to understand that it isn't going to get your hands perfectly dry. It is going to get your hands about 80% dry in about 5 seconds, which is better than you can do with a paper towel or with the PW2098...I mean XLERATOR. The remaining 20% will occur over the next two minutes as you leave the restroom.
Those of you complaining about touching the side walls need to work on your hand-eye coordination. I'm terribly sorry to be the harsh bearer of bad news, but it's not exactly rocket science...or surgery.
It's true. Dyson makes some very high-quality and innovative products. They put huge amount of research into the exact airflow through their devices. The trouble is that the prices just don't justify the quality in the home setting to me. For example, the Dyson air multiplier fan was a great idea, but not worth $300 just to have a slightly smoother airflow than a traditional bladed fan for $30 or less.
-Doc Lightning-
-Carl Sagan
N1120A
Sun Dec 02, 2012 8:18 pm
Dyson backs their products with solid warranties and saves a ton of money and waste in paper towels. Probably makes up for the price.
Sun Dec 02, 2012 8:51 pm
Dyson for me. Though I wish it could dry my hands in one go rather than having to draw them out and then dart them back in for a second and maybe third attempt..
Quoting DocLightning (Reply 9):
Exactly my thoughts!
IMissPiedmont
Mon Dec 03, 2012 1:02 am
Never heard of either one but I am also strongly in the paper towel camp also. No paper towels and the floor gets awfully wet from me shaking off the excess water.
The day you stop learning is the day you should die.
hawaiian717
Mon Dec 03, 2012 1:22 am
I don't really have a preference between the two; I find them both to be much better than the old blow dryers. I've also seen a Mitsubishi dryer that works similar to the Airblade (though not as futuristic looking), and it does have a little drain hole to collect the water.
Mon Dec 03, 2012 1:26 am
Quoting hawaiian717 (Reply 13):
I saw one of those in Hong Kong in 2005.. Never saw another again though. It had hot air rather than the Airblade's cold air and was the original one of that style!
neutrino
Mon Dec 03, 2012 11:35 am
The good doc's words make my day.
I got a China clone over a year while ago. Works great, in fact just like the original - down to its attendant CFM56 aural effects. At abt US$60, it's a sound investment.
Potestatem obscuri lateris nescitis
smittyone
Mon Dec 03, 2012 12:50 pm
After suffering for so many years with hand dryers that are equivalent to having an asthmatic blow on your hands, both of the dryers mentioned are miraculous.
Molykote
Mon Dec 03, 2012 1:52 pm
Quoting N1120A (Reply 6):
The Dyson will get my hands dry, but I find "blade" to be deceiving (i.e. single pass as with a squeegee... that I've never been able to achieve with a Dyson Airblade).
Quick trivia on PW engine terminology for you (since you seem to enjoy technical nuances):
PW engine models are designated with 4 digits as you seem to be aware (PW#### for example).
The first digit represents the engine family (i.e PW1000, which could colloquially be called a "Pratt one thousand series")
The second digit represents the mating airframe for the engine family (0 = Boeing, 1 = Airbus, ....)
The third and fourth digits represent the thrust in thousands of pounds.
In an example, the PW 4098 is a PW 4000 series engine attached of a Boeing (777 obviously) making 98k of takeoff thrust). The PW2000 "maxes out" at a PW2043 to my knowledge (though the PW2000 is one of a small few of the currentlt operating commercial engine families with which I have no experience).
Of course, if your point was that the XLERATOR is as loud as a PW2000 running at over twice its certified thrust rating I'd probably agree with you.
njxc500
Mon Dec 03, 2012 5:25 pm
The point of air dryers is for them to be no-touch, and sanitary. I can't dry my hands in a dyson without touching it, it's just not right. The jet powered blow dryer is crazy loud, but works well. If you can get past the noise, it wins.
Nick
DocLightning
Mon Dec 03, 2012 8:44 pm
Quoting Molykote (Reply 17):
I think some of the late-delivery PMNW 752's had 2098 model number. I could be mistaken, though.
-Doc Lightning-
-Carl Sagan
Molykote
Thu Dec 06, 2012 8:29 pm
Quoting DocLightning (Reply 19):
PMNW? Something related to Northwest? As for the 2098, I don't believe it ever existed.
Users browsing this forum: Kiwirob, tommy1808, vrbarreto and 1 guest
