Airstud
Ubuntu Routing/network Problem
Sun Dec 30, 2012 12:21 pm
Here I am in my apt building lobby using the free WiFi. My Panasonic Toughbook runs Ubuntu 10.04 and has built-in Wi-Fi, my Tecra 8000 (sitting next to me, Win2K) does not. I have set up a wired Ethernet connection between the two and they can ping each other. I have manually configured a Class C subnet on the Ubuntu machine's eth0 interface, 10.1.1.0/24. The Ubuntu machine's address is .1, the Tecra's is .2. The Tecra has 10.1.1.1 configured as its default gateway. The Ubuntu WiFi is using DHCP.
Yet I doubt that any of this addressing info matters; what's driving me batty is that the WiFi on the Ubuntu box shuts down whenever the wired eth0 interface is active. I have Firefox up, "trying to connect" to google.com, and it just keeps trying. Then when I click "disconnect" on the eth0 connection on the connections, menu.... (John Madden voice) BOOM!!
I want to install OpenOffice on my Tecra. I've gone mad trying to get my Zyxel WiFi CardBus adapter to work on the blamed thing, so I figured I could just bring both boxes to this here WiFi zone, connect the Ubuntu box to the web as I so often have done, then configure a routing daemon so the Tecra could get a web connection over the ethernet link to the Ubuntu box. And I am absolutely int the wilderness as to why my Ubuntu box won't allow two connections - over TWO DIFFERENT PHYSICAL INTERFACES - to work at the same time, and how to remedy this.
Any ideas?
Pancakes are delicious.
moo
RE: Ubuntu Routing/network Problem
Sun Dec 30, 2012 12:26 pm
Make sure that both the wifi and eth0 networks aren't trying to set a default route, as that would cause the issue you describe.
Airstud
Sun Dec 30, 2012 12:37 pm
Aha... point taken
(how do I check to see if they're trying to do that?)
damirc
Sun Dec 30, 2012 2:02 pm
Try netstat -rn to check for default routes. (check /etc/network/interfaces and under the "eth0" stanza comment out the "gateway" directive.
You'll need to enable ip routing ( /sbin/sysctl -w net.ipv4.ip_forward=1 )
Also, you'll need to use iptables to masquerade the Tecra's traffic going outbound towards the AP (if your wireless card's interface name is different, than substitute wifi0 for the appropriate name):
iptables -t nat -A POSTROUTING -o wifi0 -j MASQUERADE
To make sure everything works (don't suggest using this full time though):
iptables -P FORWARD ACCEPT
D.
Klaus
Sun Dec 30, 2012 2:56 pm
Quoting Airstud (Thread starter):
That is not a class C address!
And that may well be the cause of your problem, since the network interface cannot use the NAT router this way and it will catch all traffic and thus block any secondary interface.
The router would normally have something like 192.xxx.xxx.yyy as the class C network range, with a net mask of 255.255.255.0, where 192.xxx.xxx is effectively the ID of the class C network and yyy the individual address of your machine within that network (the first byte can actually be 192...223 to indicate a class C network, but 192 is what most networks use).
Have the machine get its address via DHCP (which will almost certainly be set up in the router) and you will see the local network range. In most cases that is also the preferred mode of operation.
Usually you should also have the router and DNS server set automatically via DHCP if the router supports that properly. Manual changes are possible, but can be a source of problems if you don't know very well what you're doing.
damirc
Sun Dec 30, 2012 3:19 pm
Quoting Klaus (Reply 4):
The /24 (CIDR notation) is a 255.255.255.0 subnet, so technically a so called C class   (while I agree that RFC791 does specify network 192.0.0.0/3 as a C class range a /24 subnet is usually referred to as a C class no matter where in the address space it is).
So as long as his wifi address does not overlap with 10.1.1.0/24 he's good to go.
His problem is that his W2000 box does not have wifi, and he wishes to use his primary notebook as the router between the said W2000 box and the wifi segment. DHCP is out of the question here. He could technically bridge the segments on his Ubuntu computer and then DHCP would be possible and there would be no need for routing, but I find that usually people have a harder time understanding (and working with) bridges than routing (and NATing).
D.
Klaus
Sun Dec 30, 2012 4:22 pm
Quoting damirc (Reply 5):
No, it is not a class C network. It's class A, and in this case with an incorrect net mask being set.
I've not used routing daemons under Linux so far, so he'd have to check out its particulars separately, but the network configuration is already wrong.
Remedy:
• Set up WifFi on the Ubuntu machine via DHCP and look at its network ID (for instance, it might be 192.100.1.yyy) and choose a different class C network ID for your wired connection, such as 192.100.2.zzz, both with the proper net mask of 255.255.255.0 each.
• Manually set an address in that secondary class C range for the Ubuntu machine (zzz), but set no router or DNS server on that interface, since the Ubuntu machine shall not route any of its own internet traffic through it, only its own local traffic to the Tecra.
• Set up the routing daemon on the Ubuntu machine, routing your WiFi connection to that secondary class C network interface.
• If the routing daemon provides DHCP, have the Tecra use DHCP on its wired port and it should get an address in the newly set up secondary subnet, with the Ubuntu machine set as the server and likely also as the DNS (an external internet DNS server might also be used). If the routing daemon doesn't offer DHCP configuration, you may have to set the router and DNS addresses on the Tecra manually.
The Tecra should then work normally with the Ubuntu machine with its secondary class C network being its router.
The Ubuntu machine should route its own internet traffic through its WiFi router (since that is where it sees a router itself) and the routing daemon running on it should act as a router to the Tecra box on the wired interface.
The Ubuntu machine should also see the Tecra box by its 192.100.2.aaa address and should be able to talk to it.
Depending on the capabilities of the routing daemon it may also be able to provide access to any other machines in the primary class C subnet (in the example 192.100.1.xxx) by routing that as well, but in that case you'd have to set up a second subnet interface on the Tecra for that, and configure the routing daemon accordingly.
Note: The order of the network interfaces can also matter; On the Mac you can simply drag and drop the network interfaces into the desired order in the Network control panel; Under Linux I haven't modified the order yet, so I'd have to check where that configuration is done there.
[Edited 2012-12-30 08:30:49]
damirc
Sun Dec 30, 2012 4:33 pm
Quoting Klaus (Reply 6):
Klaus. You really need to get off of your high horse. Any /24 subnet is referred to as a C class, just as well as any /16 is referred to as a B class and just as any /8 is referred to as an A class - and as said. While not technically conforming to RFC791 (writtein in 1981 mind you) it's a term generally used in IT. The key is the /24 network length, not where the network space is located.
And for the rest - why the heck would he run a dynamic-routing daemon (OSPF, RIP, BGP?!) for one single box? Overengineering the solution. If you mean routing itself - that is taken care with:
And while your solution seems snazzy, you're forgetting one thing. The wireless access point/router will have no way of knowing how exactly to route the traffic originating from the Tecra back to the said Tecra unless you NAT it. So the Tecra will not be able to connect to the Internet in your proposal.
D.
[Edited 2012-12-30 08:40:49]
Klaus
Sun Dec 30, 2012 5:11 pm
Quoting damirc (Reply 7):
Using irregular address ranges with non-matching network classes invites address range collisions, blocked access to parts of the regular network and some mechanisms potentially not working right.
One can disagree, but I see no reason to get personal about such basic technical matters. This is risky and a source of unnecessary complications, particularly when in fact the interface does not work correctly.
The primary issue here is the interface shadowing problem which may well be connected to exactly this. It seems like this is the main problem here, and that was what I was addressing.
Why don't you address that while you're at it, instead of focusing on personal digs?
The sequence of the respective interfaces is one factor, and each interface's address range and potentially configured routers matter, since on an outgoing access the interfaces are checked in order for a match to their respective address ranges. An "earlier" interface with an incorrectly set network ID and mask can indeed catch connection attempts and shadow the other interfaces, and the exact rules of interface matching are key here.
Apparently Airstud's wired interface is configured to catch all outgoing traffic (since eth0 is by default the first interface to be checked), which appears to be one of the problems here, so why don't you help out there?
On the Mac I would simply drag the WiFi interface to first place, re-check again (it should work again) and then have another look at the wired interface's address setup. Debugging under Linux would likely work similarly, I just haven't needed it there yet.
No. I was of course referring to a proper routing daemon including NAT, because that would be the only thing making any sense in that setup.
As I've said: I have not had a need for this kind of thing yet, so I have not researched the details under Linux there.
So if you have a simpler solution that actually works, please, dish!
mmedford
Sun Dec 30, 2012 5:16 pm
Stupid question;
Why not get a wireless bridge and just connect to the Wifi network; and provide yourself a feed?
Something from Engenius and a 10+ dbi yagi antenna should be fine.
ILS = It'll Land Somewhere
damirc
Sun Dec 30, 2012 5:27 pm
Quoting Klaus (Reply 8):
Sorry for it sounding personal. I could've answered differently - my mistake.
The solution is described in post #3.
D.
Klaus
Sun Dec 30, 2012 5:46 pm
Quoting damirc (Reply 10):
Okay. Resolved.
What exactly does it do? Does it forward the local Wifi network to all interfaces, including broadcasts and thus the main router's DHCP?
I don't see eth0 specified explicitly and although I've seen many "howto"'s of that kind, I've not yet found an actual explanation of how this specific forwarding mechanism exactly operates.
[Edited 2012-12-30 09:57:02]
damirc
Sun Dec 30, 2012 5:56 pm
Quoting Klaus (Reply 11):
enables the kernel to route traffic between (all!) interfaces.
Tells the firewall to use ACCEPT as the policy for the FORWARD chain (ie: traffic whose ingress and egress interfaces differ). I suggested this since good security policies will typically set that to DROP or DENY. If he has a firewall installed (and it would be a good idea to have one) then this will allow the traffic to pass.
... is trickier. So when a packet arrives from eth0, the kernel would check the router to see where to send the packet next (the default route is set to the wifi0 interface). Without using this command the packet would pass normally towards wifi0, but no response to it would be received, since the AP/router has no clue where to send the return packet. So what the above command does is - once the next hop is decided for a packet, if it exists through network interface wifi0 (-o wifi0) it is masqueraded (ie: it's source address is changed to the IP address of the wifi0 interface (technically it's a source NAT) and the communication tuplet (source ip, source port, destination ip, destination port, protocol) is entered into the connection tracking table so any response packets will automatically be redirected to the correct recipient (so a destination NAT happens and the packet is automatically rewritten).
D.
Klaus
Sun Dec 30, 2012 6:21 pm
Quoting damirc (Reply 12):
Okay; Is it possible to specify only certain interfaces? In this case it won't matter, but in others it might.
Okay, thanks so far. Doesn't look entirely different from what I've described, just with onboard facilities.
But what about address assignment on the wired interface?
Is that to be configured manually, with manual setup of the Ubuntu machine as the known router on the client machine? And what about the apparent interface shadowing problem on the Ubuntu machine itself in that case? It would appear to remain unresolved.
Or is the Wifi subnet including router information also forwarded to the client automatically? DHCP broadcasts should normally not get through to the client via the kernel router, so how is that aspect done?
damirc
Sun Dec 30, 2012 6:38 pm
Quoting Klaus (Reply 13):
Unfortunately not on this level. This just tells the kernel that it is allowed to route (IPv4) packets between interfaces. You are however able to filter what exactly is forwarded with iptables.
So while the suggested solution used iptables -P FORWARD ACCEPT (which enables all forwarding on all interfaces, but is not really advisable due to security concerns) you would then limit exactly what to forward like this:
iptables -X FORWARD
iptables -P FORWARD DROP (set the policy)
iptables -A FORWARD -i eth0 -s 10.1.1.0/24 -o wifi0 -j ACCEPT
iptables -A FORWARD -i wifi0 -o eth0 -m state --state RELATED,ESTABLISHED -j ACCEPT
What this does:
-X FORWARD : flush the FORWARD table (effectively emptying it)
-P FORWARD DROP : by default do not forward packets between interfaces (unless an explicit rule exists)
-A FORWARD -i eth0 -s 10.1.1.0/24 -o wifi0 -j ACCEPT : pass (forward) all packets incoming from eth0 with a source address of 10.1.1.0/24 and outgoing to the wifi0 interface (remember, the routing table decided what the outgoing interface will be)
- A FORWARD -i wifi0 -o eth0 -m state --state RELATED,ESTABLISHED -j ACCEPT : pass (forward) packets incoming from wifi0 and outgoing towards eth0, but whose states are related or established. iptables effectively peeks inside packets and decided whether a certain packet is allowed to be passed based on previous communications (unfortunately as in all firewalls this can be abused for UDP firewall piercing, but alas - best you can do with limited resources and still reasonably safe unless used in a high-security scenario where different rules and different firewall types come into play ).
Well, the OP stated that on his ubuntu machine he has 10.1.1.1/24 set and the Tecra already has 10.1.1.2/24 so we need not worry about it. If we'd have to allocate address, than a dhcpd bound to eth0 would work (of course configured for the network on eth0, but that's beyond the scope of the op's question).
I suspect we're talking about interface overlap? Well, that's the duty of the OP to ensure that the wireless router's address does not fall into the 10.1.1.0/24 range (any other range will be fine).
You are correct, a DHCP broadcast would not get through (and it should not, since the IP address offered would be invalid for the wired segment) - a router separates broadcast domains. So on the wired segment in this case you would either employ static addressing (as the OP described) or use a dhcpd bound to the eth0 interface.
D.
cmf
Sun Dec 30, 2012 6:48 pm
Sub-netting is standard procedures.
The only risk is if you don't understand what you're doing, and then you had no business doing it to start with.
There is absolutely no difference in using a /24 net under 10.x.x.x than using a /24 under 192.168.x.x.
Don’t repeat earlier generations mistakes. Learn history for a better future.
Airstud
Tue Jan 01, 2013 12:42 pm
I have not begun to digest all of the expert info posted here by Klaus and damirc.
I just can't tell you how sorely I wish I had specified in my original post that the WiFi interface is assigned via DHCP to a 192.168.bla.bla network.
I am also sore, though a little less so, that I used the term "Class C" to refer to what is more technically a 24-bit subnet of a Class A network. Though the fact that it was a 24-bit subnet I thought was sufficiently communicated by me specifying the exact subnet mask length I had assigned to the interface.
So with eth0 on 10.1.1.0/24 and wlan0 on 192.168.1.0/24, address range overlap ain't the issue here.
I will implement damirc's suggestions and report back.
Peace, dudes.
Users browsing this forum: Braybuddy, Dano1977, jetwet1, OA412, TheF15Ace, Thunderboltdrgn and 4 guests
