varigb707
Experts Warn To Disable Java Over Security Threat
Fri Jan 11, 2013 8:44 pm
The U.S. Department of Homeland Security urged computer users to disable Oracle Corp’s Java software, amplifying security experts’ prior warnings to the hundreds of millions of consumers and businesses that use it to surf the Web.
Hackers have figured out a way to exploit Java to install malicious software enabling them to commit crimes ranging from identity theft to making an infected computer part of an ad-hoc network of computers that can be used to attack websites.
http://i45.tinypic.com/256xy6o.jpg
[Edited 2013-01-11 12:45:40]
[Edited 2013-01-11 12:48:39]
First, I said 'hey' and then I said 'now'. "Hey Now!" - Hank K.
Maverick623
RE: Experts Warn To Disable Java Over Security Threat
Fri Jan 11, 2013 9:02 pm
Java has always been extremely vulnerable to exploitation... I don't see anything new here that hasn't been said for the last 10 years.
"PHX is Phoenix, PDX is the other city" -777Way
casinterest
Fri Jan 11, 2013 9:19 pm
Based on what i have read this is basically one of those issues we all have know about for awhile.
Don't click on the links from suspect sites.
Either way , I would expect Sun is working on this one.
Department of Homeland Stupidity apparently has no clue what Java is or does for so many websites and interactions. Shut it down sounds cute, but it's kind of like telling everyone to kill the power to the house because you might stick a fork in the electrical socket.
Older than I just was ,and younger than I will soo be.
dragon-wings
Fri Jan 11, 2013 9:58 pm
I just got a automatic update for Java to address the security issues right after I turned on my computer today.
Don't give up don't ever give up - Jim Valvano
Klaus
Fri Jan 11, 2013 10:22 pm
Quoting casinterest (Reply 2):
It's Oracle now.
Are you really extra certain you know so much better than your so reviled Homeland Security department?
Java is indeed used in many server backends, driving what web sites and other services serve back to you, but that is most likely not the issue here. This kind of issue deals with browser-based Java applets, which is a fundamentally different thing, namely Java code being served to your browser so it will actually run it locally on your own machine, not Java running on the server that's answering normal page requests.
So client users should indeed keep the Java plugin in their browsers disabled, ideally at all times unless they are really extra certain that they really, really need Java applets in their browser and they really, really know about the current threat level that entails. Which effectively means practically everybody should throw out Java from their browsers and leave it disabled for good. There is hardly anything on the web that actually still has Java applets, and those sites are generally obsolete and irrelevant anyway.
Which has nothing whatsoever to do with JavaScript which is entirely unrelated to Java (but which can have its own bugs and security issues, in that case usually specific to certain browsers).
Server-based infrastructure is generally not affected by applet security issues since it works completely differently, so 99+% of where Java is actually still needed will not have much of a problem here.
By the way: Apple has automatically blocked the Java browser plugin already on the Mac, until there is a new version that resolves the issue for those users who actually need Java applets (see above).
Quoting dragon-wings (Reply 3):
What version is it now, exactly?
[Edited 2013-01-11 14:40:38]
dragon-wings
Fri Jan 11, 2013 11:14 pm
Quoting Klaus (Reply 4):
For mine it says 1.6.0_37
Braniff747SP
Sat Jan 12, 2013 1:02 am
Apple has already disabled Java 7 remotely on all Macs.
The 747 will always be the TRUE queen of the skies!
Klaus
Sat Jan 12, 2013 2:02 am
Quoting dragon-wings (Reply 5):
No, that is not a fixed version – it is still vulnerable!
Your machine may just now accidentally have pulled down a routine update, getting the still-vulnerable version, however:
http://www.oracle.com/technetwork/ja.../javase/7u10-relnotes-1880995.html
There is no fixed version yet as far as I can tell, so please immediately disable the browser Java plugin if you have not done that already!
If the plugin had still been active, your machine may already have been infected by now. Keep your anti-malware programs up to date through the coming weeks at the very least – even if there can't be any guarantee.
Mir
Sat Jan 12, 2013 2:12 am
http://www.aviationweather.gov/adds/airmets/java/
I use it on a regular basis, and various other Java tools on that site (and they all still work, thankfully).
Quoting Braniff747SP (Reply 6):
The fact that they can do that sort of thing is rather unsettling.
-Mir
Klaus
Sat Jan 12, 2013 2:29 am
Quoting Mir (Reply 8):
If you have the plugin enabled, you're at a high risk of having your machine infected.
Java has always been a high-risk entry point for browser attacks, and right now the risk is extremely elevated to the point of recklessness.
I'd have liked an explicit notification about this particular change, but I am extremely glad they're on top of it. It is part of the Software Update and protection mechanism.
I almost always had the plugin disabled with one specific exception. Exactly yesterday I had such an exceptional need for it. I was aware of the generally problematic nature so I took extensive precautions before temporarily enabling the plugin, but it was apparently blocked already. That is where I would have liked a notification instead of launching into debugging mode, which I ultimately gave up and chose an alternate solution for my problem.
Which now obviates my one residual use for Java, most likely for good, so I'll just leave Java uninstalled completely from now on. That's been it.
[Edited 2013-01-11 18:32:07]
Braniff747SP
Sat Jan 12, 2013 4:00 am
Quoting Klaus (Reply 9):
Well, they don't exactly disable anything, nor does it use software update.
http://www.macrumors.com/2013/01/11/...ddress-widespread-security-threat/
Quoting MacRumors:
Apple has, however, apparently already moved quickly to address the issue, disabling the Java 7 plug-in on Macs where it is already installed. Apple has achieved this by updating its "Xprotect.plist" blacklist to require a minimum of an as-yet unreleased 1.7.0_10-b19 version of Java 7. With the current publicly-available version of Java 7 being 1.7.0_10-b18, all systems running Java 7 are failing to pass the check initiated through the anti-malware system built into OS X.
Basically, Apple's built-in malware checks against a list which Apple controls; it seems that Apple has updated the list, similar in the way Google would update Chrome's web browser security.
Klaus
Sat Jan 12, 2013 5:08 am
Quoting Braniff747SP (Reply 10):
Yes, they do. The plugin has been blocked by this and will not be loaded by Safari any more.
Which is a pretty good point for reconsidering whether to keep Java installed at all any more.
CAUTION: Firefox on the Mac appears to still run Java Applets even so, bypassing the automatic protection and likely exposing the machine to this vulnerability after all. Java must apparently be disabled separately in Firefox like this:
http://support.mozilla.org/en-US/kb/...20to%20turn%20off%20Java%20applets
Which I have not claimed:
Software Update is a part of this complex, since it provides and updates the basis on which the protection mechanism operates (and it itself has been rolled into the App Store mechanism in Mountain Lion).
Braniff747SP
Sat Jan 12, 2013 5:39 am
Quoting Klaus (Reply 11):
They block it from running, which is not exactly the same. I do see your point.
Never said you did. What I meant was that Apple has not actually added or deleted anything from the computer, something which could anger some (and rightly so.) They are merely stoping an action from happening on their web browser; not much different than Norton stopping X applet from running.
Java is still useful in some instances, and it is not going away anytime soon. I'll still place my faith in Apple (and Oracle) updating their software proactively as they have in the past.
Klaus
Sat Jan 12, 2013 6:00 am
Quoting Braniff747SP (Reply 12):
The lacking notification does still suck as it is now, however. That sure needs some improvement.
In the browser it's on its last legs and it is about to go away. Except for a few stragglers it's already dead.
Which is one reason why on the Mac the plugin now automatically deactivates itself after a while of not actively being used and requires an explicit re-activation by the user to run again, which is a good choice, since most people don't even know it's on even though they never need it.
Actually, Apple has bounced almost the entire responsibility for Java back to Oracle at this point. There is no Apple-supplied Java any more.
Mac OS X does not install Java any more at all. You now have to explicitly get and install it if you really want to use it.
Apple is only keeping an eye on it, yanking the plug on it in cases like this one if it is actually installed.
Apple had been criticized for sluggish updates of their own Java distribution in earlier times and with some justification; The new policy gets rid of almost the entire problem for pretty much everybody.
Especially for the majority of users who never need Java anyway, who will now not be bothered with it at all any more.
As I've said above, Java running on servers responding to incoming regular web page requests is a completely separate issue and usually is not affected by browser-based security issues. In that niche Java will likely continue to exist.
But in the browser it has long been more trouble than it's worth and should be replaced completely. Sites which still require it put their own users in jeopardy.
moo
Sat Jan 12, 2013 10:55 am
Aside from...
It's Oracle now.
Oracle knew about this vulnerability as far back as August 2012, but hasn't done anything about it, so don't keep your hopes too high.
Java really is a cluster flick these days - at one point, it was the huge poster child for many open source advocates but its just become totally unmanaged and a pile of smelly stuff.
dragon-wings
Sun Jan 13, 2013 12:24 am
Since I had a older version of Java installed on my computer I just un installed it a few minutes ago from my computer. I did download the newest Java version, but I think I will wait a little bit before I install it. If I wait maybe there will be a updated version that addresses the security risk..
Klaus
Sun Jan 13, 2013 12:44 am
Quoting dragon-wings (Reply 15):
Just throw it away. It is still the vulnerable version.
A fixed version is not available yet, but exploits of the current vulnerability are already active in the wild.
Klaus
Mon Jan 14, 2013 2:01 am
Looks like Oracle has provided an update which is supposed to fix the most recent vulnerability:
Version 7 Update 11
http://java.com/en/download/index.jsp
Oracle Ships Critical Security Update for Java
If you still have an older version active, it is most likely advisable to upgrade now if you still intend to keep using Java in the browser.
I would still advise substantial caution:
• If you do not explicitly and seriously need Java applets in the browser, better keep the Java browser plugin disabled in all browsers and keep Java uninstalled completely unless you do still need it for locally installed Java applications (for which the browser plugin is not needed, however).
• If you really need it for specific tasks in the browser, it may still be a good idea to be cautious: It would still enhance security if you normally kept the browser plugin disabled and only before accessing that Java-requiring site you closed all tabs and windows, enabled the plugin, performed the access and disabled the Java plugin again before accessing other sites.
• Keeping the Java browser plugin active all the time will keep you exposed to any further vulnerabilities Java might still have or develop later on, so this should be avoided even if this new version can be hoped to be free of any such holes, but I wouldn't bet on it.
• Downloading and running java applications from dubious sources locally outside of the browser can still be a security risk just as with native applications – the browser plugin vulnerability just allowed criminals to perform an unnoticed "drive by" injection of malware through the browser without you doing anything, but programs you invite in yourself still have free reign and should still be treated with great caution, be they native code, Java, Flash or in other languages (such as executable scripts).
• If you still need Java applets, you might also install Java on an OS in a virtual machine which does not contain any exploitable data of yours and which you use for nothing else; That at least puts up another line of defense which is not trivial to break through for invasive malware. Keeping such a VM up to date and as free of vulnerabilities as possible is still a good idea. VMs such as VMWare also have the option to make a "snapshot" of the VM in a pristine state to which you can always reset it after using it, so that any infection would also be reset if one should have occurred.
I personally have just scrapped my last use of Java and I'll most likely keep it disabled from now on.
Whatever you do, be cautious, apply common sense and use safely!
[Edited 2013-01-13 18:06:32]
Klaus
Mon Jan 21, 2013 5:55 am
Unfortunately, Oracle's "fix" appears to be more like a preliminary band-aid which leaves some attack vectors open:
Oracle's Java patch leaves a loophole
So remain extremely careful, uninstall Java or at least the Java browser plugin from your browsers if you can, or if you decide to leave it in there, at least disable execution of all unsigned applets.
Also, criminals are using this situation to attack users via bogus "Java updates" which are in fact trojans loaded with malware. So be extremely cautious about where you get such updates from (the original updates are to be downloaded directly from Oracle).
[Edited 2013-01-20 21:58:10]
Klaus
Tue Jan 29, 2013 5:24 pm
The loophole that's still open is in fact exploitable. The warnings above unfortunately need to be reiterated.
http://seclists.org/fulldisclosure/2013/Jan/241
Elite
Tue Jan 29, 2013 5:48 pm
Quoting Klaus (Reply 19):
What's taking so long for this to be patched?
moo
Tue Jan 29, 2013 9:06 pm
Elite, the issue is rooted in the fact that the Java VM security model is not a layered one, it's a called one - in other words, when a developer implements a JVM feature they have to do the security checks there and then, rather than there being an over arching security model which sits between the feature and the core method they are calling. All too often the developer is either not handling the securit call correctly, or omitting it altogether.
Just one of Javas deep bedded issues...
Birdwatching
Wed Jan 30, 2013 10:47 am
I got rid of Java a while ago and I haven't missed it for anything on the internet. Seems to be really obsolete now.
But then I realized I can't play Minecraft anymore!
Is there a way I can have the Java Runtime environment on my PC but not be vulnerable / not have the browser extensions?
Soren
All the things you probably hate about travelling are warm reminders that I'm home
Klaus
Thu Jan 31, 2013 4:00 am
Quoting Birdwatching (Reply 22):
Yes, but you need to be sure to disable the Java plugins in all your browsers – don't miss one or it can be an opening for an attack.
And you must re-check every time you've updated a browser.
[Edited 2013-01-30 20:01:18]
Braniff747SP
Sat Feb 02, 2013 2:59 pm
moo
Sat Feb 02, 2013 3:52 pm
Quoting Braniff747SP (Reply 24):
Possibly. We shall see.
Braniff747SP
Sun Feb 03, 2013 4:48 am
Quoting moo (Reply 25):
Well, it'll be exploited again... but for now, it's safe.
Users browsing this forum: bananaboy, Dutchy, Francoflier, Scorpio and 4 guests
