TheSultanOfWing
Icon: Land Rover Defender 110, Should I Buy It?
Sun Apr 28, 2013 5:30 pm
Hey you,
I imagine there will be some 4 * 4 fans out there, perhaps even a Land Rover Defender owner / freak.
Tata will produce the Defender till 2015 only......I have been told!
An uphill battle......
I have been considering this icon for quite a while but it was always a tad too bare-bone-basic to my liking, and I went with a Mitsubishi 4 * 4 instead.
Then, I think in 2007; the "new" Defender came out with a new Diesel engine (hence the bonnet hump) plus a brand new dashboard. A buyer would need the some of the extra options though as the basic-version is exactly that: BASIC.
The roof in a different color than plain white, nice rims.....or electric windows: you pay!
I test-drove the "new" Defender 90 when it first came out in my country, nice!
But it broke my wife's bones in the rear, so I'd go 110, no doubt.
My question is: what is your opinion?
Are they reliable?
Or do they give the headaches that some people suspect with anything Land Rover?
Should I buy an icon before it disappears?
[Edited 2013-04-28 10:35:00]
I feel like the A318 at times: I am probably worth more parted out than as a whole.
PlymSpotter
RE: Icon: Land Rover Defender 110, Should I Buy It?
Sun Apr 28, 2013 5:56 pm
Quoting thesultanofwing (Thread starter):
Are they reliable?
Insanely so. Several people I know have them for use on their farms. They get driven over ploughed fields, rough roads, kicked by cows, have sheep thrown in the back and generally get hammered day in and day out. They only get serviced when something goes wrong, and the last one they bought 8 years ago still hasn't had a service.
I've not heard this before about Defenders. Freelanders, Range Rooneys and the Discovery yes, they have not fared well, but the Defender is a soldier which takes some killing. Most things which need replacing arise from the driver getting cockey and doing something daft, like trying to drive over a tree or through a deep river.
I don't buy that they will disappear from production for good. To me it's a bit like the Twin Otter - the market for new models isn't great because even the old ones just won't die, so the second hand market is buoyant. But ultimately the only thing you can replace a Defender with is another Defender.
Dan
Kiwirob
Sun Apr 28, 2013 6:24 pm
Are they reliable?
My brother has owned a 2006 model 110 since new, he's never had a problem with it, it's regularly used to tow a 3000kg boat, he off roads it and uses it as a daily driver (not something I would do with it). I don't find them very comfortable, I hope you're not a big guy, anyone over 5'10 and about 90kg is going to feel very cramped behind the wheel.
Bongodog1964
Sun Apr 28, 2013 7:30 pm
Do you need its more or less unique features ?
Brilliant grip off road
Alloy body panels soak up punishment, scrapes and dents don't rust
Huge towing ability
Rear able to be hosed out in order to remove residue of dead sheep etc.
Pedals large enough to use when wearing wellies.
Able to have a full length roof rack fitted that can carry more on top than most vehicles can carry inside
If you need any of these its a good choice, as nothing else is quite so practical.
However, can you cope with the following:
Terrible comfort, driving position grim to say the least
Front visibility rather like driving whilst looking through a letter box
0 - 60 time you measure with a calendar.
terrible body roll on corners (due to excellent off road suspension)
1940's design, built using 1940's technology. It is possible to fill and sand down spot weld marks, Land Rover haven't quite grasped it yet though.
MD11Engineer
Sun Apr 28, 2013 7:38 pm
I own a 1986 model 110 (before they were called Defenders). It is a bastard, since the original engine, the 2.5TD, the worst engine Landrover ever built, has been replaced with the 200TDI engine of the 1996 model. This engine again is, together with the ROW (rest of the world, as opposed to the EU and US versions) and British Army version´s 300TDI, maybe the best and most reliable engine Landrover ever built. As long as you replace the timing belt every 80.000 to 100.000 km and make sure that there is always enough oil in it, it will run forever. Unfortunately this engine, with it´s mechanical injection pump, doesn´t pass the EU and US emission tests. The newer TD5 (5 cylinder pump nozzle injection, electronic control) and TD4 (4 cylinders common rail engine, built by Ford) are less reliable and they are not really repairable in the field.
The V8 petrol engine delivers a lot of torque, but unfortunately uses a lot of fuel as well. I politely refused one because I don´t own an oil well. The diesel models are relatively economic with 9-11 liters for 100 km for a 2.5 -3-5 ton vehicle.
The basic design of the Defender is great, but, like many British cars, it suffers of sloppy manufacturing. One issue is corrosion of the internal door frames (due to historical reasons the body consists of aluminium sheeting over a steel frame), because they never isolated the aluminium from the steel, leading to dissimilar metals corrosion.
Older Defenders also suffer from electrical problems due to mthe use of components by the British manufacturer Lucas Electrics (Sir Lucas wasn´t for nothing known as the "Prince of Darkness"), though it became better when Bosch bought the company. Also Landrovers tend to leave oil stains wherever they are parked.
Most spare parts are very cheap, at least here in Europe, mainly because the truck´s main use as a military and utility vehicle, especially if you buy generic or aftermarket parts and not those with a LR logo on them.
Same as with the older Toyota Land Cruisers (aka the Bush Taxi), there doesn´t exist a proper replacement for the Defender. The trend goes to yuppyised wannabe 4x4 vehicles for cities. The German mountain rescue organisation has been forced to b uy old Toyota Landcruisers abroad and to modify them locally because they can´t find any modern truck suitable for their needs. Possible replacements might be the Tarpan Honker from Poland and the Iveco Massif.
The Defender is a slow truck on the road, so better get used to drive in the truck lane. If drive at more than 100 km/h
it becomes very noisy inside. It has a high centre of gravity, so if you go into a curve too fast, you can topple it over.
The springs arer very hard, because the truck has been designed to carry a ton of cargo. A few hundred kgs in the back make the ride much smoother.
Be prepared to do a lot of maintenance yourself, like lubricating the prop shafts every 5000 km and also, if it is a model with an older LT77 gearbox, to remove the transfer gearbox input shaft every 5000 km to lube the internal splines with grease or else you´ll end up with an expensive gearbox change due to wear of said splines. From a certain model on (I can´t be @rsed to look it up now) LR introduced to holes in the shaft, which allow gear oil to reach this area. Working under the car is quite easy, because there is lots of space.
You also have to adjust the rear drum brakes from time to time, butthis isn´t a big job.
I´m 6 ft tall and weighabout 87 kgs and I´m quite comfortable in the driver´s seat (with the seat fully back, there exist extensions for the seat rails, but I don´t use them). After long distance driving I feel more refreshed in my Defender than in a modern car in this semi reclined armchair position).
Hope this helps.
Jan
BMI727
Sun Apr 28, 2013 7:39 pm
What the hell is wrong with you that you even have to ask? Of course you should buy it. Buy it before anyone tells you not to.
Kiwirob
Sun Apr 28, 2013 7:53 pm
Quoting MD11Engineer (Reply 4):
That's rather stupid why don't they buy new 70 series vehicles, which are as tough as old nails, have been in production since 1984 and are probably what the German Mountain Rescue Service are buying second hand? They must have some rather special demands if something like a Hilux can't do the job, they are just as capable and as tough as the 70 Series.
You must be the exception. Long motorway hauls are tiring to the extreme, Defenders wander all over the place. Don't get me wrong I do like them, they are very good at what they were intended to be used for but as a daily driver they are not in any way ideal.
MD11Engineer
Sun Apr 28, 2013 8:04 pm
I have been using my 110 every day since 2007. I´m thinking about buying a Smart though as a second car. 95% of my trips are within 30 km around my home and I´m usually alone. I don´t need to drive 2.5 ton vehicle to buy groceries or to go to work.
Jan
TheSultanOfWing
Sun Apr 28, 2013 8:27 pm
Hope this helps.
Thanks for the detailed answer!! Interesting read!
But the preventative maintenance you described, does this apply to the "new" models (2007 and up) as well?
Because others stated:
Quoting PlymSpotter (Reply 1):
Quoting kiwirob (Reply 2):
So I still wonder, are the newer models pretty much maintenance free (like a modern car) in day to day use, or do I have to buy myself a good toolkit?
Quoting Bongodog1964 (Reply 3):
Fair points! Alas, I can't tick any of these boxes.....yet I still want one! What does that say about me!?
I don't remember that from the test drive.....but yes, maybe the extended rails are a good idea.
Hope you're right!
Quoting BMI727 (Reply 5):
I guess I'd better get my skates on and talk to the importer.......
I still wonder where they are built, in the UK; correct?
Kiwirob
Sun Apr 28, 2013 8:58 pm
Or a 70 Series Land Cruiser.
You won't see Defenders in the Aussie Outback very often but you will see 70 Series troopies everywhere, many held together with no. 8 fence wire and gaffer tape, they just don't die.
MD11Engineer
Sun Apr 28, 2013 9:11 pm
The gearbox issues got fixed, but you still need a grease gun to lube the prop shaft universal joints. Even a modern Defender is essentially 1960s/1970s technology (with some reaching back to WW2). Btw., the brakes need getting used to as well.
Quoting kiwirob (Reply 6):
I understand that the same rules, which ban the introduction of LR Defenders in the EU also ban the older Toyotas, essentially all smaller trucks (less than 4-5 tons) with a ladder frame. While the ladder frame is very suitable to customised modifications, it is considered to be too sturdy in collisions, as it provides no crumble zone. The high ground clearance of these true off road vehicles also puts the front bumper at a height, which is bad if you hit a pedestrian. You might notice that all 4x4 vehicles sold in Europe during the last few years have pretty low ground clearance and have a self supporting body. This is one reason why LR killed the Defender in Europe. Production will end IIRC next year, as no new ones can be registered over here.
Existing ones are being grandfathered.
Jan
Kiwirob
Sun Apr 28, 2013 9:54 pm
Quoting MD11Engineer (Reply 10):
That's not true, there are a fair number of 4wd utility vehicles like the Toyota Hilux, Mitsuibishi Triton, VW Amorak ....... all built on separate ladder chassis which you can buy all over Europe.
JJJ
Mon Apr 29, 2013 8:01 am
Iveco Massif
Not available since the Santana factory closed down.
The tooling was sold, IIRC, to some Iranian company.
TheSultanOfWing
Fri May 03, 2013 6:01 am
How is the fuel consumption of this Diesel?
Aesma
Fri May 03, 2013 4:57 pm
I would only buy it if I owned a big property in Africa or something like that, certainly not as a car.
aerorobnz
Sat May 04, 2013 1:54 am
Buy one and then go and drive to Dakar. I dream of driving a Defender around the whole of Africa - or the Bowler Wildcat equivalent.
Flown to 120 Airports in 44 Countries on 73 Operators. Visited 55 Countries and counting. Wanderlust is like Syphilis, once you have the itch it's too late for treatment.
Ken777
Sat May 04, 2013 2:23 am
The only negative comment I have heard in years is that you need to check the trade in value - the old "friend of a friend" comment was that it lost a lot of value.
As far as the white roof goes - that can be important in areas where it gets pretty hot. Half a century or so ago Gulf Oil ran a simple test on 2 identical Beech Kings. One had the top painted white and the other was left bare metal. The planes were left out in the Houston sun for a few hours and they found the King with the white top was 11 degrees cooler than a silver top. Figure out how that black top would be.
I can remember when we lived in PER you could but a second top for the Land Cruisers. That left an air gap between it and the "normal" roof.
As much as I love black I don't want it on my cars.
Superfly
Sat May 04, 2013 2:46 am
Nice looking vehicle! Go for it!
Will this Land Rover be safe in El Salvador? Is the place as violent as people say it is?
Considering this is an expensive truck, would it make you a moving target?
Bring back the Concorde
MD11Engineer
Sat May 04, 2013 7:29 am
Quoting Ken777 (Reply 16):
Here they hold their value pretty much (or even increase in value) because of their cult status. Not bad for a machine developed as a farm tractor.
Quoting Superfly (Reply 17):
They are not so expensive when you buy them, especially the more utilitarian older models (lots of them have been build for construction companies, forest guards, fire brigades, police and the military as working vehicles). They keep their value though.
Quoting thesultanofwing (Reply 13):
Mine, with the 200TDI engine, uses 9-11 leters of diesel for 100 km, depending on how and where I´m driving. I´m driving mostly country highway in rural area.
That roof was only available for the older Series Landrovers (Series 2 to Series 3), those with the recessed radiator grille, up to the early 1980s.
Jan
TheSultanOfWing
Sun May 05, 2013 12:32 pm
Quoting Aesma (Reply 14):
I see where you're coming from....the car doesn't make a lot of sense in the city.
I do quite a bit of rural driving too however.
As an owner of 2 black cars in a warm country; I understand.
But nothing the AC can't fix, and it's the best looking color for most cars in my humble eyes.
Oh, it is! My doubt is the practicality!
Good question.
There are safety concerns, but so far I have had no issues with my (sharp looking) Mitsubishi 4*4.
Normally with a bit of common sense it's no problem moving around the country.
Quoting MD11Engineer (Reply 18):
That's not so bad.
I'm thinking along the lines of US$60.000,- (give or take) for a brand spanking 110 with all the "goodies".
That is quite a lot of money; import taxes etc are quite steep.
With "goodies" I mean the stuff that can't be installed locally, the "internal options" I'd prefer to have factory installed.
I once received a quote for a "full" Defender 110 including, from the top of my head:
-A winch + bullbar
-The fancy rims
-Roof in the same color as the car
-Electric windows
-Stereo with USB connection
-AC
-Arm rest forward
-Mud flaps (you pay to drive the Land Rover name around)
-Central locking
-Steel light covers
-Checker plating
-Roof rack
etc etc.
I think the total exceeded US$90K. (!!).
But I have come to realize that of that list, a lot of money can be saved by buying a more basic version, and save $$$ for instance with:
-Spray painting the roof locally
-Buying "local" rims
-Installing the roof rack locally, as well as any checker playing etc
-Buying mud flaps and the steel mesh light covers from E-bay
-Installing the winch / bull bar of my present car
Etc etc.
The issue is that stuff like electric windows, AC, the central arm rest etc are still options that I'd need; driving the prize (and the import tax) up considerably.
Apparently they are working on some kind of replacement.
http://www.caradvice.com.au/196221/l...er-defender-replacement-confirmed/
PlymSpotter
Sun May 05, 2013 12:41 pm
They do in the UK too, better than most other cars.
Quoting thesultanofwing (Reply 19):
Excellent, so long as the article is right that it won't look like the urban concept.
Dan
Superfly
Sun May 05, 2013 7:13 pm
Good question.
Well Mitsubishi isn't a high-end brand like Land Rover.
Yes we know that they have their stripped down utility line but a lot of criminals may not see it that way.
Kiwirob
Sun May 05, 2013 7:17 pm
Quoting Superfly (Reply 21):
Land Rover isn't a high end brand either, that's why they have Ranger Rover.
BMI727
Sun May 05, 2013 7:31 pm
Quoting kiwirob (Reply 22):
It's one of those things like BMW or Mercedes where they are considered more upscale in the US than elsewhere. I'd bet that most Americans, especially the ones buying Land Rovers, don't know what a Defender is. Here Land Rovers are for shopping, not land roving. We have Jeeps and Hummers for that.
MD11Engineer
Sun May 05, 2013 8:40 pm
I would never install aluminium rims on my Defender. I use the, up to 2002, standard 7.50 R16 steel rims for tube type tyres and last winter I bought the British military "Wolf" rims (also used on the 130 model) for winter, since nobody manufactures snow tyres anymore in 7.50 R16.
Jan
dl021
Mon May 06, 2013 7:50 pm
Just get the darned thing. It's a classic and it's awesome. They're incredible off road and up to hte challenge on any road.
I drove one across southern Africa last year and wish they imported them into the US.
Is my Pan Am ticket to the moon still good?
BMI727
Mon May 06, 2013 9:34 pm
Quoting dl021 (Reply 25):
There are some grey market Defenders that made it over here, but they can be pretty pricey I think.
dazbo5
Mon May 06, 2013 9:44 pm
I love Defenders, I've been driving them for work for 15 years now. They are so capable and take loads of abuse. I drive both the 110 and 130, doing up to 10,000 miles a year in them on-road, off-road and towing up to 3,000kg trailers. Reliability wise, I'm mixed as they have their problems, but that's more than made up for in their capabilities. I find the 2007-2011 model to be the less reliable based on the new 130 we got in 2007, but the 2011 onwards seems better built. Of all the 4x4's I've driven, I'd take a Defender anytime for it's capabilities. I wouldn't have one as an everyday runaround though, they aren't exactly fuel efficient although they are better than other 4x4's I've driven (diesel versions, not the V8 petrol). I find them quite comfortable to drive, I do 450 mile trips with trailers every month or two and find it as comfortable as many of the cars I drive. Comfort is hit and miss though, some like them, some don't. This is having a play in one the other month;
3 wheels and even 2 aren't a problem in a Defender!
Darren
[Edited 2013-05-06 14:48:08]
Braniff747SP
Mon May 06, 2013 9:49 pm
They where sold between 1993 and 1997 in the US. They can still be found, but they command similar prices to when they where brand new.
The 747 will always be the TRUE queen of the skies!
TheSultanOfWing
Fri May 17, 2013 12:26 pm
Bugger!
Import taxes would still take it to $90K plus, according to the importer!
I am double checking with other companies, but it doesn't look good!
Quoting dazbo5 (Reply 27):
Nice if you can get it!
Quoting MD11Engineer (Reply 24):
May I ask why?
Quoting BMI727 (Reply 26):
I believe so. Had a browse on Google the other day, they are very steep in the US!
There's a great selection in the UK though!
MD11Engineer
Fri May 17, 2013 2:15 pm
Quoting thesultanofwing (Reply 29):
May I ask why?
The standard and the military steel ones are much more durable than the aluminium ones. Also, I don´t want my truck to be too pretty. It use it sometimes offroads, e.g. going into the forets to get firewood. I´m not worried about minor scratches.
Btw., last week I went into the other extreme and bought myself a Smart For Two as a second car. I realised that 905% of the time I´m driving alone. And I don´t need to use a 3 ton truck to go to work or to the supermarket. I´m living in a rural area, but if I had to go to the nearest cities (e.g. Frankfurt or Koblenz) I always had two problems:
No chance to find parking space for a big truck like the Defender and since this Defender still has the very rugged old engine, it doesn´t fullfill some German antipollution laws and is therefore banned from most bigger cities. The Smart fullfills these rules and I can find parking space everywhere.
Also there is the difference between 10 lters Diesel / 100 km and 3.5 liters Diesel for 100 km.
In a few weeks my old 1970s BMW motorbike will be finally restored as well, so I will use this "rubber calf" as well.
(the German nickname for the old opposed engine BMW motorbikes is "Gummikuh" (Rubber cow) because of their habit of lifting the rear when opening the throttle (like a cow getting up). Since mine, an R45, was the smallest of this group, a colleague, who restores old BMW bikes and their Russian clones (Ural, Dnepr), cvalled it the "Gummikalb", rubber calf.
Jan
TheSultanOfWing
Fri May 17, 2013 2:57 pm
Quoting MD11Engineer (Reply 30):
Fair enough! I thought you had a more technical reason as well, like "wider tires are bad off road" or something like that.
The original (basic) tires and rims are quite narrow on a Defender.
It doesn't have to be pretty, but do you happen to have a pic of your work horse?
I didn't realise there were regulations like that in Europe!
Hey, with a Defender you are well allowed to drive a "girly" car on the side!
The 2 more than compensate each other!
And yes, parking down town must be a bit of an issue in a 110.
I wonder if she would fit in some of the "malls" we have around here......height-wise!
Thanks.....
na
Sat May 18, 2013 10:02 am
The Defender is an icon, no doubt. Lots of coolness. Its sad if production will stop.
I once had a Defender in the best colourscheme of dark green/tan on a business travel in the Irish hinterland for a few days and beside the trucks I drove in the army long time ago it had the worst driving position of any car I ever steered. I wouldnt want to drive one every day of on longer trips. But girls love the Defender I can tell you!
Its also great fun to drive in a version where the windscreen and all uppers can be folded in vintage-car style.
Aesma
Sat May 18, 2013 12:37 pm
There is one in my street actually, and I'm nowhere near rough terrain (Paris' suburbs). It even has a roof rack with gas/diesel/water tanks and other equipment. And the color is a nice dark green. Apparently it's owned by a photographer who goes regularly to North Africa with it, more than 2000Km to get there ! The parking spots on the street (each between two trees) are big enough for it.
MD11Engineer
Sat May 18, 2013 4:17 pm
Quoting na (Reply 32):
It really depends on the person. I´m 1,80m tall and I fit quite comfortably behind the wheel (having driven the Defender since 6 years now)
Bugger!
Which is stupid. Why would somebody pay $ 90K for a glorified farm tractor? I paid something like € 5000 for mine (used) back in 2007, but I have to say^that I spent quite a bit on restoring and repairing it (though I do as much as possible myself).
Quoting thesultanofwing (Reply 31):
Actually the standard tyres have a lower rolling resistance in sand than the wider aftermarket tyres, but they also have a higher area load.
I found that,with really coarse mud tyres (like tractor tyres) it would dig itself nicely through snowdrifts, where other cars would get stuck.
Jan
Kiwirob
Sat May 18, 2013 6:48 pm
Depends on what sort of off roading you're doing, in some situations a wider tyre is more beneficial than a narrow one.
I think what they are replacing it with will be better and find a much wider market
MD11Engineer
Sat May 18, 2013 8:40 pm
Quoting kiwirob (Reply 35):
Doesn´t look very versatile or utilitarian. What is missing is a small lorry type truck of up to 3.5 tons gross weight, where the upper structure is modulised and which can be altered without too many issues. I can´t imagine this vehicle to be converted e.g. into a camper and it can defintely carry less (volume and weightwise) than my Defender.
Jan
Kiwirob
Sat May 18, 2013 9:12 pm
Quoting MD11Engineer (Reply 36):
We really don't know what the actual vehicle will end up like, I highly doubt JLR will abandon it's traditional Defender buyers but I'm they want to expand it's market with something a tad more appealing for more people, I'm pretty sure they will want a piece of the pick-up market currently dominated by the Japanese, this new vehicle is supposed to come in multiple configurations after all.
BMI727
Sat May 18, 2013 11:21 pm
You'd hope so, and I think it's likely. Jeep still sells plenty of Wranglers, although they seem quite common among affluent buyers who don't need to use them as primary vehicles.
It's also theoretically possible that some other car maker might buy the Defender design and build them in small quantities, not unlike the Lotus Seven.
garpd
Wed May 22, 2013 1:07 pm
Top gear once did a test with the latest 4x4s of the time. The test was simple. A small grass hill that was wet. To pass the test, get all the way to the top. Only 3 things made it to the top: Landcruiser, Range Rover and a 30 year old Defender that towed the BMW, Mercedes, Porsche and other contenders up the hill.
Besides, the British Armed Forces have been using the Defender since pretty much it's launch.
If I could afford the tax and fuel, I'd have one in a heart beat.
[Edited 2013-05-22 06:29:18]
arpdesign.wordpress.com
TheSultanOfWing
Sun Jun 02, 2013 1:34 am
Quoting garpd (Reply 39):
Nice one!
I hear you!
I have just been told that the new local regulations state that every new vehicle requires a double airbag from this year onwards! That is pretty much the last nail in my plan's coffin, I'm afraid!
Perhaps there are exceptions with regards to industrial vehicles or something.....but if not, Kiwirob's possible design could become the one for me.
Problem is, if it really becomes a more regular type of Jeep (SUV?) it will lose its appeal a bit as Joe Average will be driving it too, you know what I mean?!
Now it's just farmers and enthusiasts that operate these privately, not some trendy young working Mom or a sensible guy that loves the fuel economics and trade-in value!
Braniff747SP
Sun Jun 02, 2013 7:58 am
Quoting thesultanofwing (Reply 40):
I don't think it will loose the appeal because Joe Average drives it; it will loose appeal because it must become a Joemobile for that to happen, so it'll become like an X5.
Users browsing this forum: BartSimpson, LittleFokker, SoJo and 1 guest
