XAM2175
Thread-starter appears after first reply
Thu Mar 01, 2018 3:44 pm
I've noticed a few new threads are appearing with the first reply above the original post.
One such thread is here: viewtopic.php?p=20212157
Cheers.
Moose135
Re: Thread-starter appears after first reply
Thu Mar 01, 2018 4:07 pm
That's a known issue, I think it has to do with time stamps on the posts. The mods are aware of it - I know it's been mentioned here in the Site Related section previously.
ETA: Found the earlier thread on it:
viewtopic.php?f=12&t=1373943
atcsundevil
Thu Mar 01, 2018 4:50 pm
Cheers.
Yeah, unfortunately it is a known issue, and the developers are aware of it. It's been an issue for at least six months. I wouldn't say it's common, but it probably comes up about once every week or two. Just report the post to us so we can fix it. We can't change the post sequence, but we'll either delete the post that's out of sequence, or we'll sometimes quote the user before deleting it — that way, their post is still visible. It's not ideal, but hopefully it'll be fixed soon. It affects down thread posts too, but that's less noticeable (usually you only notice it when a post quotes a post that is displayed below it) and doesn't require fixing.
XAM2175
Sun Mar 04, 2018 12:59 pm
Thanks very much. I do see it every now and again - at least with the "Topic Starter" bar it's not so hard to work it out!
readytotaxi
Wed Mar 07, 2018 12:15 pm
Growing older, but not up.
atcsundevil
Wed Mar 07, 2018 8:20 pm
readytotaxi wrote:
Please just report the post as being out of sequence. It's usually the only way we can get to it in a timely manner.
readytotaxi
Thu Mar 08, 2018 6:48 pm
I thought that was what I was doing. Advice pls.
Moose135
Fri Mar 09, 2018 12:30 am
Use the "Report Post" function - the little triangle with the exclamation point icon - to send a report directly to the moderators. Posting in a thread here may not be seen right away.
atcsundevil
Fri Mar 09, 2018 12:51 am
To add to what Moose135 said, using the Report Post function is the only guaranteed way to draw our attention to something. Users will often write "Mods" thinking it will alert us, but it doesn't. That just means we have to find it by eventually reading it ourselves. That's hardly a quick process. Reporting a post doesn't necessarily mean someone has broken a rule, it's just to draw our attention.
Aircellist
Tue Mar 27, 2018 2:29 am
Thanks. I'll definitely use it.
"When I find out I was wrong, I change my mind. What do you do?" -attributed to John Maynard Keynes
TVNWZ
Wed Mar 28, 2018 7:43 pm
This issue appears to be getting more frequent in the last week.
VapourTrails
Fri Mar 30, 2018 10:09 am
Thank for this. It seems to be worse today and happens when replies are posted close together. :crowded: e.g. less than two minutes?
scbriml
Fri Apr 06, 2018 8:59 am
Any update on progress towards fixing this issue? It seems to be getting worse. I saw one thread a couple of days ago where there was three or four replies to a post that appeared after them.
vhtje
Thu Apr 19, 2018 9:38 am
I concur: it is getting much worse over the last two weeks. It is making reading the forums confusing and difficult.
I only turn left when boarding aircraft. Well, mostly. All right, sometimes. OH OKAY - rarely.
Users browsing this forum: No registered users and 34 guests
