N80NA
Tail Height On 738's & 739's
Wed Aug 22, 2001 7:49 am
this is weird,
check out these 2 links,
for the tail height on both the 738 and 739,
boeing lists 2 different tail heights : 41ft 2in and 41ft 3in
why the difference ?
also shows the 739 drawing with winglets....didn't realize it was an option
on the -900 ????
http://www.boeing.com/commercial/737-800/ext.html
http://www.boeing.com/commercial/737-900/ext.html
thanks......N80NA
AJ
RE: Tail Height On 738's & 739's
Wed Aug 22, 2001 4:38 pm
The tail height, at a guess, would be from ground to tip. If you look at the 737NG on the ground it has quite a nose low stance, therefore if you make the aircraft longer the tail would be higher!  Smile/happy/getting dizzy
N80NA
Thu Aug 23, 2001 7:11 am
according to the websites,
the 738 has 2 different tail heights and
the 739 has 2 different tail heights
i think the original post was misleading
anyone have a guess as to why this would be ?
hmmmmm  Wow!
L-188
Thu Aug 23, 2001 4:56 pm
depends on how much fuel was on the aircraft when they took the tape measure to the ones the measured.
