Sonic99
What's The Avg Length Of Long Runways At Airports?
Tue Aug 28, 2001 1:48 am
Hi all!
Most major int'l airports have at least 2 runways used regularly for arrivals and departures. In most cases, one is shorter than the other. What is the average length of the longer runways at major airports around the world (11,000', 13,000') ??
Stephan
SESGDL
RE: What's The Avg Length Of Long Runways At Airports?
Tue Aug 28, 2001 2:02 am
Well at MSP, the main runways are 10,000 and 8,000 feet. The cross runway used for NWA 747-200'S mostly is 11,000 feet. So, I'd estimate between 9,000 and 11,000 feet maybe, depends on the airport though.
RJ_Delta
Tue Aug 28, 2001 2:05 am
The average length of the runways are between the 3 and 4 kilometers. Of course all depend of the airport.
RJ_Delta.
hailstone
Tue Aug 28, 2001 3:28 pm
sin has parallell (sp?) ones at 4000 meters each
jwenting
Tue Aug 28, 2001 4:07 pm
All major runways at AMS are between 10K and 11K feet. The old Fokker rwy (22) is shorter, but used only for commuters, private aircraft and buzjets. It is also less wide.
I wish I were flying
AirOne
Tue Aug 28, 2001 10:35 pm
At Denver all the runways are 12,000ft long. I know the longest one at JFK is +14,000ft and they have another one that is +11,000ft
AirOne
cfalk
Tue Aug 28, 2001 10:52 pm
All the major airports which typically recieve heavies (747s, etc) have close to 4000m (12,000 foot) runways, at least those which had the room to build them. I'm not sure, but I think the longest runways in Europe are in Munich, which are not far from 5000 meters.
So I'd say the average length for the longest runways will be around 4200-4300 meters.
Charles
deltairlines
Tue Aug 28, 2001 11:40 pm
Our two longest runways at BOS are a little over than 10000 ft, then we have a 7000 ft, one at ~8000 ft and then a little 2000 ft strip for Cape Air and light planes.
Jeff
Sonic99
Wed Aug 29, 2001 8:45 am
What's the runway length required for an A380?
Sonic99
Vertigo
Sat Sep 08, 2001 7:07 am
I believe that the A380 will need about 11,000 thousand feet of runway to takeoff at sea level. This is just slightly more than a 747 requires.
Sonic99
Sat Sep 08, 2001 7:30 am
So does that mean that an A380 could land at any airport having a runway of at least 11,000 feet?
n521na
Sat Sep 08, 2001 9:20 am
LAS has the second longest runway in the world or US, I dont remember. It was something like 14,300 feet.
BA
Sat Sep 08, 2001 9:40 am
LAS currently has the longest commercial runway in the world. Its 14,505ft. long.
Denver (DEN) is building a 16,000ft. runway however which will be the longest in the world.
Regard.
"Generosity is giving more than you can, and pride is taking less than you need." - Khalil Gibran
KCLE
Sat Sep 08, 2001 9:43 am
CLE, though not that busy of an international airport, receiving no pax. widebody service, our paralell runways are 9000 feet and 7000 feet. Within 5 years, they will be 11250 and 9000 feet. Although you may think 9000 feet is not a lot, a 777, DC-10, and 747 can all take-off and land on this runway before.
Sonic99
Sat Sep 08, 2001 10:16 am
I'm just wondering whether or not existing facilities (runways in particular) will accomodate the new generation of widebodies/longreach arcraft, i.e. the A380, perhaps some new version of a Concorde, the proposed Sonic Cruiser...
It seems that many airports have runways in the 10,000 - 13,000 range. I presume the avg would be 11,000 so if that's the case will this be enough concrete?
S
Vertigo
Sat Sep 08, 2001 2:32 pm
Could someone with greater technical knowledge than me please answer Sonic99’s question. I am unsure of FAA regulation regarding the length of runway needed for an aborted takeoff beyond that actually used by the aircraft during its takeoff run.
Example: Would an A380 need a 12, 13 or 14,000 foot runway to meet regulations for a takeoff run, even if it only actually uses 11,000 feet of that?
Vertigo
SailorOrion
Sat Sep 08, 2001 10:05 pm
MUC does indeed have some of the longest runways in Europe (not couting millitary) but they are 'only' 4000m x 60m (which is 13,123ft by 197ft) sounds a lot, but the elevation is 1497 ft. It will be perfectly enough for any version of the A380 to liftoff.
The 747 at 0ft and (I think +15°C, no winds) needs 10,000 ft of runway (3048m).
DEN is building a 16,000 which is the longest CIVIL runway afaik.
I think the longest ACTIVE runway is one of Edwards AFB's 30 runways, it is somewhere in the high 20k ft or even 30k ft long.
The required takeoff length depends on a HUGE number of factors which include: Mass at takeoff, elevation of runway, current outside air temperature, SLOPE of the runway (quite important if high), etc
SailorOrion
mandala499
Sun Sep 09, 2001 3:02 am
Even CGK (Jakarta) have 2x 3600m (60m wide) at 2800m apart...
Mandala499
Dasa
Sun Sep 09, 2001 4:04 pm
Why is DEN building such a long (16,000 ft) runway? When would such a length be needed?
SailorOrion
RE: Dasa
Sun Sep 09, 2001 6:20 pm
As I said, it is mainly due to the elevation of the airport
SailorOrion
