jr
Flashing Landing Lights?
Sun Jun 27, 1999 5:45 am
Today I saw a canadian 737-200 on approach into DFW with its landing lights flashing or blinking if you will (as opposed to being just turned on). Is that supposed to mean something ?
Thanks in advance.
I've flown on 9V-SPK.
RE: Flashing Landing Lights?
Sun Jun 27, 1999 6:53 am
I don't know if this has any significance, but I have seen Canadian 737-200s do the same thing on the aproach for YWG.
JETPILOT
Sun Jun 27, 1999 9:14 am
I believe the landing lights during daylight have a selection for the lights to flash. This makes the aircraft much easier to spot in a terminal environment by controllers and traffic. Landing lights are used during the day only to make the aircraft more visable, and serve no other purpose. The flashing makes the plane much more noticable in my experience.
Enroute at flight level I will flash my landing lights at oncoming traffic comming the other direction on the same airway at night. At different altitudes of course. This is a common practice.
Martyn
Sun Jun 27, 1999 9:41 am
It is also supposed to prolong the life of the bulbs. They are not actually turning off, just dimming significantly. This prevents the filament from shock cooling and as they are not constantly on full power the bulb lasts longer.
Sun Jun 27, 1999 6:57 pm
Flashing landing lights are a common procedure in the US? That´s interesting, because normally that should be an urgency signal, like the radio call "PAN PAN PAN".
L1011
Mon Jun 28, 1999 12:52 am
I've seen it done from inside the aircraft. It is very noticable when you are in cloud at night, because the whole cloud lights up. At first I thought it was lightning, but lighting flashes are more irregular.
Bob Bradley
Richmond, VA
Fly Eastern's Golden Falcon DC-7B
L1011
Mon Jun 28, 1999 6:23 am
What you have seen lightening up the clouds were most probably the strobe lights, not the landing lights.
