BA-747
How Big Is The A330 Compared To Say The 747
Thu Sep 06, 2001 4:25 pm
so how big is it?
jwenting
RE: How Big Is The A330 Compared To Say The 747
Thu Sep 06, 2001 5:02 pm
Tiny. When you have one sitting between two 747s, you hardly see it.
In capacity, it is about the size of a 763.
I wish I were flying
Thu Sep 06, 2001 5:22 pm
It looks pretty big from inside.
Joni
Thu Sep 06, 2001 10:09 pm
An 330 can carry about 300 passengers, and 747 about 400, so the 747 is larger.
Mr.BA
Thu Sep 06, 2001 10:29 pm
It looks spacious and big inside the A330, but comparing it to the B747, nah.
alvin
Boeing747 万岁!
Thu Sep 06, 2001 10:53 pm
typical A330 3 class config holds about 250-275 passengers
typical 767-300 3 class config holds about 185-210
typical 747-400 3 class config holds about 350-400
A330 is closer to the 777-200 in capacity.. in fact the A330 has a little more room for cargo than the 777.
Boeing Nut
Fri Sep 07, 2001 3:02 am
The A330-300 is almost identical in cargo capacity as the 777-200. Both aircraft hold up to 32 LD3's in the cargo hold.
Source: a.net aircraft data.
