I Like To Fly
Neither Of The Voice Recorders Worked
Sat Sep 15, 2001 5:37 am
They have been trying to get the info out of the block boxes of the plane that hit the Pentagon & the one crashed in PA all day. It doesn't sound good. The voice recorders, that are considered much more important than the data recorders in this investigation are not providing any info from either plane. The one in PA is mysteriously blank and they think a software glitch contributed to it not recording anything, however they are still looking into it. The one from the Pentagon is VERY burned and they don't think it will be of any use. It apparently burned at very high temperatures for many hours, they are built to survive 2,000 degrees F for only 1 hour. The data recorders did apparently survive, but the FBI is saying they don't really need that info since they know what the planes were doing before the crashes and why they went down. Damn, I would have found it very interesting to know the conversations in the cockpit and how the terrorists got in for sure.
Anyone know if the flight data recorders less sensitive than the voice recorders and that's why they survived and the voice recorders didn't? Or is this just bad luck that the ones we really need don't work?
B808/A400
RE: Neither Of The Voice Recorders Worked
Sat Sep 15, 2001 5:40 am
I think there's a general idea of what went on in the cockpit. Heavily accented threats of bombs, etc. I can say one thing for certain, no such accident will ever happen again. From now on, any hijacking attempt will be viewed as a Ram-a-landmark attempt, and people passengers/crew will try to stop it from happening.
ryu2
Sat Sep 15, 2001 5:41 am
The terrorists probably pulled the circuit breaker to the CVR/FDR, turning it off. The same thing was done in 1997 in the SilkAir crash, which many people think was a pilot suicide.
I Like To Fly
Sat Sep 15, 2001 5:43 am
B808/A400, we still DON'T KNOW exactly how they got entry into the cockpit and that's what we hoped to find out.
sotomayor
Sat Sep 15, 2001 5:44 am
I believe those voice recorders used real tape, so the tape must be damaged by the intensity of the fire (very high temperatures), especially at the Pentagon site. I haven't heard anything about a voice recorder box for the UA93 plane. The flight data recorders are storing data in memory (solid state devices) which apparently are less sensitive to the conditions of the crash.
sotomayor
I Like To Fly
Sat Sep 15, 2001 5:50 am
Ryu2, they were aparently educated and I suppose could do that. But why? As long as they got the job done they didn't care. I mean they didn't bother to cover their tracks anyplace else so why on the plane? They left evidence everywhere else it was them and one even left a note, so they are proud of what they did and I would imagine would also want their voices heard. Doesn't make sense to turn them off.
H. Simpson
Sat Sep 15, 2001 5:59 am
Ryu2, you stated the point, these terriost READ the MENAUL, they might really turn off the circuit breaker.
but we will see what really happen.
I Like To Fly
Sat Sep 15, 2001 6:24 am
H. Simpson, first of all why would they? Second, how will we find out what really happened without the voice recorders? You didn't support you statements that well. Confused
Joni
Sat Sep 15, 2001 6:28 am
Maybe they left false clues on the ground and turned the cockpit recorders off to conceal whatever "trade secrets" they have.
I Like To Fly
Sat Sep 15, 2001 6:42 am
Joni, I have to admit I never thought of that. But I don't know how likely that is. They are too proud of what they did to want to turn off the recorders.
Ryu2, the DATA was recorded and I think they would both not work if they pulled a circuit, at least from what I can gather.
Pilot1113
Sat Sep 15, 2001 7:01 am
According to the FARs all airliners MUST BE EQUIPPED with digital flight recorders as of March of this year. If they failed to meet this requirement, then the airliner would be considered 'unairworthy.'
- Neil Harrison
Ikarus
Sat Sep 15, 2001 7:19 am
Another little point for conspiracy theorists. How comes we can find voice data recorders for planes that crash right into the ocean (TWA, Egyptair) with information on them, when two out of two found recorders in this act of terrorism do not work. I eagerly await the other two recorders to be found. Should it be claimed that they were empty as well, I might just lose any faith in the "it was bin Laden" theory - that would smell too much of cover-up.
Until then, I wait. Disappointed, but still hopeful for REAL information... Especially the easily found Pittsburgh recorder should have provided that already. Empty tape, huh? Software glitch???
Ikarus
I Like To Fly
Sat Sep 15, 2001 7:21 am
Ikarus, they have already said that it is VERY unlikely that the two WTC plane recorders survived something that violent.
flashmeister
Sat Sep 15, 2001 7:57 am
I heard a couple of days ago that one of the cockpit radio mic's was left open and that ATC tapes picked some things up, so it may not be a total loss...
I Like To Fly
Sat Sep 15, 2001 8:57 am
Flashmeister, where did you hear that? I hope it's true! But I would think it would be big news if they did, but who knows. Anyone else hear this?
sotomayor
Sat Sep 15, 2001 12:29 pm
Your information is wrong, since by the time you started this thread only one cockpit voice recorder had been found, the one at the Pentagon. This one was probably destroyed by the heat, if in fact it was a tape used in that box.
They just found the UA93 (in PA) CVR about 3 hours ago. No word yet on whether it's usable or not, but I'm sure word will leak out in less than a day on whether the recording is usable or not.
sotomayor
gator17
Sat Sep 15, 2001 12:46 pm
EgyptAir and TWA had lots of seawater to extinguish any flames there might be on the ocean floor. All the data recorders for each plane was subject to many hours of intense heat, along with millions of tons of collapsing debris around it. Recorders are not built to survive a building collapse, or hellish infernos. So don't start up with these conspiracy theories.
LoneStarMike
Sat Sep 15, 2001 1:00 pm
Solomayer is right. They just found the second black box about 8:30 pm. You must be confusing the CVR with the FDR.
Pa. Flight's Second Black Box Found
SOMERSET, Pa. (AP) - The cockpit voice recorder from the hijacked United flight that crashed in western Pennsylvania was found Friday and sent to Washington for analysis.
Search crews found the ``black box´´ at about 8:30 p.m. some 25 feet deep in the crash site crater, FBI (news - web sites) spokeswoman Linda Vizi said. It was sent to the National Transportation Safety Board (news - web sites) in Washington.
FBI spokesman Bill Crowley said the recorder appears to be ``in fairly good shape,´´ citing descriptions by those who found it. The recorder, which is designed to capture at least the last 30 minutes of cockpit conversation, could provide more detail about what happened on board United Flight 93.
The plane's other black box, the flight data recorder, was found Thursday.
The Boeing 757 went down 10 miles from here, near rural Shanksville, after leaving Newark, N.J., for San Francisco. Radar showed the plane on route and heading over Cleveland when it abruptly turned back east, began losing altitude and flying erratically toward Maryland before it crashed.
Cell phone calls made by passengers to relatives before the crash suggested they planned to wrest control of the jet from the hijackers and prevent the plane from becoming a missile like the ones that toppled the World Trade Center and damaged the Pentagon (news - web sites).
Some have speculated that the hijackers planned to target Camp David, Md., the Capitol or even the White House. In a tribute Friday night that brought friends and relatives of the dead to tears, Gov. Tom Ridge called some of the passengers heroes for battling their captors.
``The passengers on that plane decided to fight back their hijackers,´´ Ridge said at a vigil attended by thousands. ``They undoubtedly saved hundreds, if not thousands, of lives in the process. They sacrificed themselves for others - the ultimate sacrifice.´´
``What appears to be a charred, smoldering hole in the ground is truly and really a monument to heroism,´´ he said.
About 80 friends and relatives, none who spoke at the service, were escorted by police and Red Cross workers past a crowd estimated at 3,000 to attend the vigil. Many cried as they waved candles and flags while singing ``God Bless America.´´
Earlier, volunteers at the crash site led a prayer service. Heeding President Bush (news - web sites)'s call for a national day of prayer, Salvation Army and Red Cross workers prayed and sang ``Amazing Grace.´´
LoneStarMike
Ikarus
Sat Sep 15, 2001 5:20 pm
Gator17, I like To Fly:
So they can find a closed section of the cockpit with a terrorist inside, a stewardess with her arms tied behind her back in the back section of the plane - but they cannot find the CVR or FDR - both (unlike human bodies) being devices designed to withstand extreme conditions, designed to survive airplane crashes?
If LoneStarMike is right, then there is still hope for proper information.
Ikarus
