milemaster
Sleeping Gas In Passenger Cabin
Fri Oct 12, 2001 8:35 am
Some of you may have heard this as well yesterday(Wednesday) morning on the Howard Stern show. The interview was with Donald Trump about an unrelated subject, but it deviated to the topic of 9/11.
On a phone interview...Mr. Trump suggested all cockpits be installed with a big red button that when pushed, fills the passenger cabin with sleeping gas to take control over a terrorist situation. Yes, it would put everyone to sleep..including all the passengers(the pilots would have gas masks of some sort). The plane would then land at the nearest airport and remove the threat of another impact.
What do you think? I'm in favor of the idea personally...
fspilot747
RE: Sleeping Gas In Passenger Cabin
Fri Oct 12, 2001 8:43 am
That's actually a genious idea. That's a VERY good idea. And it isn't as dangerous as using guns. I'd go for it.
take care
FSPilot747
dtswi
Fri Oct 12, 2001 8:44 am
YES !
I had the exact same idea right after 9/11 !
But then: risk that gas numbs pilots too or may cause death to some weak pax ?
I still think the idea should be pursued...
Jer32382
Fri Oct 12, 2001 8:47 am
Let me present this idea to you. Ok, we have this new gasing system installed on the planes. So a terrorist who has connections with the ground service people (i.e. food service, cleaning service, etc.) has one of his contacts tape into the gas supply and place a strain of anthrax for example in the supply. The plane goes up, the terrorist causes a problem, the pilot pushes that big red button and bam. You have a plane full of people infected with anthrax or some other deadly virus. The plane lands, the people come on board to get the unconscious passengers off and then they get infected without even knowing it. It just keeps spreading and we have a nightmare on our hands and a potentially deadly epiodemic. Call me a conspiracy theorist, but I really think that is a legitimet (sp?) cause for concern about this gassing system.
Jer - Ohio State
Re-Heat
Fri Oct 12, 2001 8:54 am
Terrorist puts on gas mask, red button is pushed. Terrorist moves without any resistence to the cockpit..... Makes job even easier.
Jer32382
Fri Oct 12, 2001 8:55 am
I was just going to add that to my post. Good point
Tripleseven
Fri Oct 12, 2001 8:57 am
I'd hope a gas mask would be detected before it can find it's way onto a plane.
Then again, you may have a point. Is it illegal to bring one on? It's not a weapon. I suppose if it isn't, it'd have to be in this scenario.
Jer32382
Fri Oct 12, 2001 8:59 am
As far as the gasmask goes, a terrorist would be ore apt to use a smokehood. They are cheaper and they are definatly legal to take onto an airplane.
coboeing777
Fri Oct 12, 2001 9:03 am
why? they could just tap into the current air supply of an airliner. No need to have to wait for a special gassing system. Let's face it, we can not prepare for EVERY single even that may happen. It's impossible. I hate to say it but there are ways around everything. I'm not going to even stress over possible attacks. If it happens, it happens. Nothing I can do but deal with it if it comes.
Jer32382
Fri Oct 12, 2001 9:05 am
Good point
Fri Oct 12, 2001 9:08 am
I like the idea. But I think that with every good idea comes a few downpoints.
airbus380
Fri Oct 12, 2001 9:14 am
I like the idea. But, I don't like being knocked out.
sfointern
Fri Oct 12, 2001 9:18 am
You'd have to have *A LOT* of sleeping gas tanks... The expense would be astronomical.
I still think the best security starts at the checkpoints.
milemaster
Fri Oct 12, 2001 9:29 am
My further opinion...
As far as an inside job for anthrax (so very remote) being put into an aircraft, it would take a great deal to get access to the ventillation system and rig it up. Also, anthrax can't be distributed in a gas form and would be a visible "powder or dust" that would be obviously out of the norm. Secondly, testing people for anthrax spores is a simple process and can be done very quickly if there is any suspicion. From what I've heard, anthrax cannot be spread from person to person so an epidemic simply wouldn't happen.
It certainly would take a lot of sleeping gas to knock out an entire passenger cabin.. but only if it were even just enough to weaken the threat just enough to get the plane safely on the ground. The cost would be no more astronomical then staffing an air marshall for a year or two.
I would hate to be in any situation where terrorists try to seize control of an aircraft I'm on. But I'm sure all of you would rather be knocked out than crash into a building of some sort at 500+ mph.
Just my humble opinion.
sccutler
Fri Oct 12, 2001 9:58 am
I have occasionally allowed a bit of gas to slip out while I was sleeping in the cabin...
...oh, never mind.
...three miles from BRONS, clear for the ILS one five approach...
FlyVirgin744
Fri Oct 12, 2001 10:12 am
I think its a great idea even without the whole terrorists situation. Have you ever been a trans-oceanic flight and couldn't fall asleep? Have the Fa's come around, gas people who want it, and bamm. Ofcourse it wouldnt be that simple, but its something to think about.  Big grin
Sometimes I go about in pity for myself and all the while a great wind carries me across the sky.
777gk
Fri Oct 12, 2001 10:34 am
Sleeping Gas?
What a riot...
We are trained, in a hijacking (or similar) situation, to depressurize the cabin of the aircraft to do the same thing as a sleeping gas would. In doing this, it reduces the bloodflow to the brain, which will effectively knock out the pax and allow us to land the plane with minumum hassle. The oxygen mask system is manually overridden, and only the pilots and possibly the flight attendants would be protected against it through the use of oxygen. However, this process could take in excess of 20-25 minutes to have an effect on the passengers, and if by chance during this period a terrorist walks into the cockpit and see the pilots with oxygen masks on, well, if one of the guys doesn't have a quick imagination, then there could be trouble.
This would not kill the passengers, it would simply put them in a "hibernation" mode until normal air pressure can be restored. The downside is that by doing this, you run the risk of having to evacuate a planeload of unconscious passengers in the event of an emergency, which definitely could get hairy.
Fri Oct 12, 2001 2:38 pm
Replace "sleeping gas" with "sarin nerve gas"...
Sounds much more plausible than the anthrax outbreak (which isn't contagious and takes ages to kill someone). The sarin would immediately put everyone who inhaled it to rest.
You now have a terrorist threat on the aeroplane and from memory these fundamentalists don't care if they die or not.
LV
Fri Oct 12, 2001 2:54 pm
Im on a prescription medication that can't be mixed with sleeping gas. Whenever I have surgery it has to be IV induced. So you hit the button, I die. Think I'm ever going to buy a ticket again. Heck no
Stratofish
Fri Oct 12, 2001 9:13 pm
Hmmm, good points from everyone but I definetely prefer the sleeping gas option over armed sky marshalls. But whatever is done onboard the planes it must be combined with better security checks on the ground.
Stratofish
The Metro might be the Sub(optimal)way
Fri Oct 12, 2001 9:27 pm
I'm in favor of it, but it's expensive! So you might not see it happen.
Aloha 737-200!!  Wink/being sarcastic
Greg
Fri Oct 12, 2001 10:34 pm
Ok..this is about the dumbest thing I ever heard!
Should follow the thread last year about putting parachutes on planes.....
Fri Oct 12, 2001 11:16 pm
Not mention Greg, its impossible.
Some of you guys need to actually read about jetliners before you write about them. Posts like these would get trashed by the second message.
The reason its impossible is that cockpit and the cabin are pressurized together, hence the pilot can go into the cabin and flight attendents into the cockpit during flight. Its essential for this access...more so than the possibility of a hijacking.
This was all clearly explained recently...in The Wall Street Journal...no less.
