donder10
Where In The UK Can I Buy An Antenna For My Scanne
Sat Oct 13, 2001 7:35 am
Does anybody know where in the UK I can order an antenna to replace the antenna that came with my yupiteru VT7100 scanner?Thanks,Alex
A330-243
RE: Where In The UK Can I Buy An Antenna For My Scanne
Sat Oct 13, 2001 8:52 am
Donder10,
I have that scanner too. Its proper!
I have replaced the normal antenna with a nine section aerial. It cost me £10.
See the following websites. Contact via email or mail to receive their catalogue so you can compare prices.
http://www.javiation.co.uk/
http://www.airsupply.co.uk/
http://www.lowe-electronics.com/cgi-hobbyist/acatalog/index.html
If you send a Stamp Addressed Envelope to this address they will mail you their catalogue.
S. R. P. Radio Centre
1686 Bristol Road South Rednal
Birmingham
B45 9TZ
Tel: 0121 460 1581
There are other websites but all the above have specialist knowledge of airband scanners.
Good luck on your purchase  Smile
donder10
Sat Oct 13, 2001 7:10 pm
'I have replaced the normal antenna with a nine section aerial. It cost me £10. '
Hi, A330-243, do you mind if you tell me where you bought your antenna and what model is was?Has it improved the reception alot?Thanks,Alex
A330-243
Mon Oct 15, 2001 8:03 am
Hi again,
Yes the antenna does improve reception when compared to the rubber duck aerial which came with the scanner.
I bought it from Tandy's. Its called Sky Scan Telescopic Aerial. Unfortunately I haven't been able to find any pictures online to show you. So, I took a picture of mine with my digital camera to show you.  Big thumbs up
http://www.geocities.com/nac743/7100.html
It is a nine section telescopic aerial that stretches out to about 65cm in length. Remember VHF reception depends on the 'line of sight' rule. The higher you are the better reception. For example with this aerial if I was to go to my attic I could listen to Heathrow Approach clearly. I live near BHX.
For a mobile antenna it is not bad at all given the cost.
