VS744
Broken Wings And Falling Engines...
Mon Oct 15, 2001 7:43 pm
Has a wing ever snapped in flight? I noticed that during heavy turbulance, the wing moves a lot, and I know this is tested and designed to flex, but has a wing ever snapped, either in its entirety, or just the end part?
As for engines - has an a/c ever lost an engine in flight because of turbulance?
petertenthije
RE: Broken Wings And Falling Engines...
Mon Oct 15, 2001 7:51 pm
An El-Al 747 cargo plane lost a engine prior to the Bijmer-crash in Amsterdam (1992 or something). I don't know if it had to do with turbulence, I believe not.
Attamottamotta!
trident3
Mon Oct 15, 2001 7:58 pm
wasn't that due to fatigue/corosion in the engine mounting pins?
"We are the warrior race-Tough men in the toughest sport." Brian Noble, Head Coach, Great Britain Rugby League.
paulc
Mon Oct 15, 2001 8:02 pm
Early Lockheed Electra's suffered from wing loss during flight as a result of resonance from the engines etc.
English First, British Second, european Never!
VS744
Mon Oct 15, 2001 8:14 pm
so there are no reported cases of it happening recently?
petertenthije
Mon Oct 15, 2001 8:15 pm
You're right Trident3. I got this from http://www.aviation-safety.net
PROBABLE CAUSE: "The design and certification of the B747 pylon was found to be inadequate to provide the required level of safety. Furthermore the system to ensure structural integrity by inspection failed. This ultimately caused - probably initiated by fatigue in the inboard midspar fuse-pin - the no.3 pylon and engine to separate from the wing in such a way that the no.4 pylon and engine were torn off, part of the leading edge of the wing was damaged and the use of several systems was lost or limited. This subsequently left the flight crew with very limited control of the airplane. Because of the marginal controllability a safe landing became highly improbable, if not virtually impossible."
Attamottamotta!
Mon Oct 15, 2001 8:18 pm
BOAC Flt 911, March 5th, 1966. Sideswiped inflight by 7.5G mountain wave nr Mt Fuji, Japan. Right wing snapped in half + all four engines torn off.
zb74
Rick
Mon Oct 15, 2001 8:22 pm
I used to fly on Delta's DC-8's back in the mid 70's a lot when I was a kid, and I used to love sitting over/behind the wing, because the wings on those planes would really move up and down a lot. The engines roared and made a ton of noise which I liked as well.
Tue Oct 16, 2001 10:35 am
I know the 737 1 and 200 series engines are designed to where they will seperate under certain circumstances, but whether they'll come off automatically or intentially I'm not sure.
bacardi182
Tue Oct 16, 2001 11:58 am
I once read on the NTSB web site about a JAL 747 that lost an engine in turbulance and had to land in alaska.
