TS-IOR
Aircrafts Registration...
Sat Nov 10, 2001 1:18 am
D-AIAX LR-KP.
What do these two groups of letters (LR-KP) refer to ?
On which basis are they chosen ?
Thank you !!!
David_itl
RE: Aircrafts Registration...
Sat Nov 10, 2001 1:32 am
They are known as the Sel-Cal codes (short for SELective CALling).
When flying a long distance, so that the pilots don't have to keep a listening watch all the time, ATC inputs the four letter code into a machine so that it "chimes" inside the cockpit of the aircraft concerned to alert the pilots to get in touch with ATC.
The same code can be in existence for 2 or 3 different aircraft so they tend to make sure that all the planes do not operate in the same area in case the wrong plane answers.
The codes are designated by an independent body (which I can't think of the name at the moment...Airinc?)
David/MAN: 258 days and counting to the next Commonwealth Games
BLACK BOX
Sat Nov 10, 2001 1:55 am
Correct, but it's used mainly to avoid listening out on shitty HF frequencies, which can be pretty bad at times, however It's not really used within VHF range.
