hkgspotter1
SQ A343 To HKG 09/11/01.
Sat Nov 10, 2001 10:07 am
How come this aircraft did a flight to Hong Kong, did the 773 go tech or is it just a lack of passengers ??. I think it was SQ859/860
lubcha132
RE: SQ A343 To HKG 09/11/01.
Sat Nov 10, 2001 10:09 am
note-
the date is written in D/M/Y format so its for november 9th
9V-SPK
Sat Nov 10, 2001 10:55 am
A343 has the smalleset capacity after the A310 under 3 class-configuration, probably an aircraft switch, not low capacity as SIA has cut SQ851/SQ852 already.
Anyways, good to see a SQ A340 in Hong Kong, as in September saw a SQA340 with removed liveries on its tail but only the SQ paints on the fuselage, waiting to recieved by CX.
Best Regards
hkgspotter1
Sat Nov 10, 2001 11:19 am
I'm talking about the NORMAL date format. Not the American format (why do they have to change everything ??)
dynkrisolo
Sat Nov 10, 2001 11:42 am
What do you mean by *normal*? I believe the most widely used format is YYYY-MM-DD.  Wink/being sarcastic
