Singapore 777
Need Help With Delta Flights
Sat Nov 10, 2001 9:09 pm
Anybody on this board can help me check out the aircraft type for the following flights:
23 May 2002
Delta Airlines 464, DTW-ATL, leaves 835a arrives 1038a
Delta Airlines 341, ATL-LAX, leaves 410p arrives 606p
*Both are on the same day.
Thank you.
RE: Need Help With Delta Flights
Sat Nov 10, 2001 9:18 pm
Look it up at http://delta.com, but it's too early too tell for sure, with all the switchings going on nowadays.
jessman
Sun Nov 11, 2001 6:24 am
currently they are scheduled:
DL464= 767-200
DL341= 767-400
Big777jet
Sun Nov 11, 2001 6:58 am
Check it out Delta.com and find "flight schedule" then select cities and date. I found DTW-ATL is possible using 757 Delta flight number #361 and ATL-LAX is the same flight number 341 using 767-400. I hope you'll get B767-400 to LAX. The plane is great! I flew on 764 twice. Good luck.
Big777jet
