AA 738's To DFW In Dec.
Mon Nov 12, 2001 10:48 am
Here's a first for AA
On Dec. 15, they will start flying their 737-800's out of DFW. Routing Baltimore - Dallas/Ft Worth- Belize.
AA 2193 BWI - DFW 9:13am 11:40pm
DFW- BZE 12:40pm 3:35pm
AA 2194 BZE - DFW 4:40pm 7:44pm
DFW- BWI 8:49pm 12:32am
tguman
RE: AA 738's To DFW In Dec.
Mon Nov 12, 2001 11:01 am
That is both great and sad to hear. First, for spotters down there, they will get a chance to photograph the 738. Unfortunately, that means the 727 are really on the beginning of the end in AA colors. What a shame.
RyAn
Life is a Mine Field.
yyz717
Mon Nov 12, 2001 11:29 am
Why would AA only just be adding the 738 to DFW now? This is their largest hub.
I dumped at the gybe mark in strong winds when I looked up at a Porter Q400 on finals. Can't stop spotting.
deltaflyertoo
Mon Nov 12, 2001 11:59 am
Although DFW is their largets hub, AA found greater efficiencies by flying the 738 out of ORD and MIA to points all across the US. ORD doesn't prefer 727 flights there so the 727s went to DFW and the MD-80s due a good and efficient job in flying nonstop to most points from DFW. So therefore, a narrowbody that is designed primarily for long hauls was not that needed at DFW.
Mon Nov 12, 2001 12:19 pm
Actually, if you'll notice, ORD has very few 757 ops. Only 14 daily for Nov. versus DFW which has significantly more.
yyz717
Mon Nov 12, 2001 1:38 pm
Thanks guys.
Neil
The Coachman
Mon Nov 12, 2001 1:54 pm
I heard there are noise-restrictions and hence 727 ops out of ORD were not especially encouraged?
The Coachman
M88, 722, 732, 733, 734, 73G, 73H, 742, 743, 744, 752, 762, 763, 772, 773, 77W, 320, 332, 333, 345, 388, DH8, SF3 - want
727LOVER
Mon Nov 12, 2001 8:40 pm
AA seems to have been replacing 727 with 738 one hub at a time. ORD was completely doneby end of 1999. At 9/11/01 MIA was halfway done, and DFW not touched. I am guessing on Dec 15 if 738 is going to DFW, then MIA is completely done.  Sad
"We must accept finite disappointment, but never lose infinite hope." - Martin Luther King, Jr.
AA737-823
Tue Nov 13, 2001 1:19 am
Well, I recently checked for flights from Dallas to Dulles, in January, and found that ALL have been switched to 727s. That should have been a clue, that fleet ops were changing, because until recently, several had been upgraded (or dowgraded I suppose) to MD-80s.
But, bottom line is, there is STILL a chance to fly the 727 on AA, get in while you can!
Randy
AA767400
Tue Nov 13, 2001 1:31 am
They will start DFW-CUN as well. when I find out when I will post it.
"The low fares airline."
Tue Nov 13, 2001 8:10 am
MIA & DFW still has a fair number of 727 flights, and at least through Jan, the above mentioned flights are the only 738's through DFW
doug
Tue Nov 13, 2001 8:54 am
The AA 727's in Miami are going away at a rapid rate.The AA 738 is slowly but surely becoming the dominant ac for AA in Miami.I am glad to here that DFW will finally see the ac.
ATA L1011
RE: AA 738's To DFW In Dec.(Tguman)
Tue Nov 13, 2001 2:11 pm
Well Tguman Delta has plenty 738's coming in to DFW serving that hub for spotters to snap everyday.
Treat others as you expect to be treated!
